Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-12-2012, 12:09   #241 (permalink)
yapanit's Avatar
Member: 498957
Thanks Meter: 270
bump!
i cant belive it my box no need to modify...
my atf box works fine now
thanks x-shadow
i just follow this solution.
http://forum.gsmhosting.com/vbb/8215231-post1.html
micro sd card can read now
1 ATF Box Found...
ATF Software has already paired itself
with this ATF Box.
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x00
Application ID :
Product Name :
Product Revision : 0.0
Serial Number : 00xxxxxxxxx
Manufacture Date: December 2011
Card CID: 0000002020202020000040215600BC75
Card CSD: 007FFF325F5A83BAF6DBDFFF8E800049
Card SCR: 0225000000000000
Card OCR: 0080FF8000
Maximum Speed: 25000000 Hertz
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
and FBUS flashing works perfect...
Old 03-12-2012, 17:58   #242 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
Originally Posted by mobile_hotman View Post
Bro see this if any other suggestion, would be appreciated,
I think no solutions for this type of problem.
Old 04-02-2012, 19:09   #243 (permalink)
kindo's Avatar
Member: 300886
Thanks Meter: 61
Originally Posted by leventc View Post
atf lightning small box repair solution add please
Try this
http://forum.gsmhosting.com/vbb/f609...-fbus-1448881/
b.r
kindo
Old 04-04-2012, 13:37   #244 (permalink)
IRFANMOBILEZ's Avatar
Member: 1569848
Sonork: 100.1593338
Thanks Meter: 97
Thumbs up thnks ATF team
now my box is working
Old 04-16-2012, 08:54   #245 (permalink)
Member: 544692
help me sir
ATF Box is not in USB 2.0 Mode
NEW PCB PCB v1.3
http://www.4shared.com/photo/Z5TV_sOB/Shot03.html
http://www.4shared.com/photo/JKD-1-lz/Shot04.html
Old 04-16-2012, 09:36   #246 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Originally Posted by himshivhare View Post
Attach direct here or contact me on messenger
Br - srinibas ( ATF Team )
The Following User Says Thank You to srinibas For This Useful Post:
Old 04-21-2012, 15:55   #247 (permalink)
birdonsky's Avatar
Member: 1491073
Sonork: 100.1608050
Thanks Meter: 49
after update my box to new version problem
i have modified my box long time ago it was working fine but after last update now box no green light i followed all procidured to repair it but no way success
need help please or should i buy new bux
thanks
Old 04-22-2012, 13:54   #248 (permalink)
birdonsky's Avatar
Member: 1491073
Sonork: 100.1608050
Thanks Meter: 49
Hello ATF Team i need one Person of team to check my box because i done like losse atf box
I have three other box for nokia service but the futures in atf box not find in other box , i cant work without atf box
Thanks
[email protected]
Old 04-23-2012, 17:04   #249 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 236
hello all
my atf problem F bus not find phone ? after SD Card update
and i am modif pcb diferent pcb ?
help me fix this problem ..
thx
Old 04-23-2012, 17:11   #250 (permalink)
birdonsky's Avatar
Member: 1491073
Sonork: 100.1608050
Thanks Meter: 49
kerug-bali
update ur software and important file if nor working then update ur correct firmware
Old 04-23-2012, 17:26   #251 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 236
Originally Posted by kerug-bali View Post
hello all
thx
Old PCB <-- This PCB can be modified
New PCB <-- This PCB CANNOT BE MODIFIED BECAUSE IT DOES NOT NEED TO BE MODIFIED...
The Problem with the New PCB is when you accidentally put "modified box" firmware to
it. Since Firmware inside the Box will be WRONG,, that is why it cannot power ON
Phones anymore and you will just see "BLUE" and "ORANGE" lights all the time.
The solution is simple...
(Take note this is for BIG ATF BOX with NEW PCB written PCB v1.3)
1. Download this:
http://174.120.45.27/tmp/NEW_PCB_81510.rar
2. Disconnect ALL BOXES from USB Port (DISCONNECT ATF BOX AS WELL)
3. Close ATF Software
4. Connect ATF Box to USB Port
5. Extract "NEW_PCB_81510.rar" and inside you will find "new_pcb.bat"
6. Run "new_pcb.bat" and wait for 3 minutes or until it will finish without errors.
*** Take note that all LEDs should be ON during firmware is updating ***
problem solved thx all
Old 05-09-2012, 13:58   #252 (permalink)
Crazy Poster
Member: 764794
Thanks Meter: 8
atf not found in divice manager
Do you see
USB to Serial Converter A
and
USB to Serial Converter B ??? PLEASE HELP ME SIR URJENT
Old 05-10-2012, 06:03   #253 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Do you see
and
Here is your solution - http://forum.gsmhosting.com/vbb/8330894-post6.html
Driver location - C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS
Old 05-13-2012, 23:53   #254 (permalink)
Member: 1133543
Dear sir..after modify my BIG ATF BOX pcb ver 1.2.. BB5 bus chk or scan is perfect ..bt when i am tryng flashing then flashing hang 19% or 8% ..spcly 5130c mcu ppm write ok bt cnt file write error in 8% ..i am also change fbus synch time bt no result.. whats the problem ??? plz help me ATF TEAM...THANKS..
Old 05-14-2012, 05:52   #255 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Try to restore box with modified firmware
Post result
Page generated in 0.28187 seconds with 10 queries
