Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-01-2012, 21:04   #271 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@Miangee911
@khalidjan
Both your PCBs are newer Revisions and they should not get Green Light Problems.
Is the ATF Box detected in the Device Manager?
Old 12-02-2012, 10:43   #272 (permalink)
Member: 505446
Thanks Meter: 45
Originally Posted by Advance-Box View Post
@Miangee911
@khalidjan
Sir!if you see my PCB's picture,you will see itr shows blue light,not green light problem.
And yes my box is detected in device manager.And also usb operations(flashing) is working fine only fbus cables dont work.
i have tried latest software versions and also the older software versions,still same problem.
Old 12-02-2012, 11:14   #273 (permalink)
Member: 505446
Thanks Meter: 45
also my box gets hot during usb flashing and only blue light stays on,no other light blinks even,not during the usb flash and not while box is plugged to computer and is on standby.
Old 12-04-2012, 08:00   #274 (permalink)
Member: 505446
Thanks Meter: 45
still waiting for the help
Sir X-Shadow!i am still waiting for the solution.
Old 12-04-2012, 08:09   #275 (permalink)
Member: 1847810
Old 12-04-2012, 09:05   #276 (permalink)
Member: 505446
Thanks Meter: 45
my AtF new pcb fbus not working
Originally Posted by kerug-bali View Post
problem solved thx all
Sir i have tried the above trick of New PCB.bat but still same.
My box's blue light is always on,usb flashing/operations work 100% but fbus flashing/operations do not work at all.
Old 12-05-2012, 20:34   #277 (permalink)
Member: 217170
Thanks Meter: 43
and i have same problem
Old 12-07-2012, 10:24   #278 (permalink)
Member: 505446
Thanks Meter: 45
Where are the supporters now?
Old 12-15-2012, 14:13   #279 (permalink)
Member: 505446
Thanks Meter: 45
waiting for the product supporter "mr.Advance box" please help.
Old 12-16-2012, 07:34   #280 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Knock me on SONORK
Br - srinibas
Old 12-21-2012, 09:25   #281 (permalink)
Member: 505446
Thanks Meter: 45
Sir!i do not have snorok!please can you give any other alternative to PM you.
Br,
A.Rehman
Old 12-21-2012, 10:38   #282 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Br,
A.Rehman
Check your PM inbox
Br - srinibas
Old 12-22-2012, 14:09   #283 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
usb flash ok fbus problems
dear sir
After update 9.30 i can not do fbus flashing but flashing ok with usb mode.
my atf big box show only blue ligt. during try to restore box in box tools area box show three light is work, also after completing update farmware box show only one light i,e blue.
i try to modify pbc but still same.
please help
Old 12-22-2012, 14:35   #284 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Originally Posted by sahed07860 View Post
dear sir
please help
Have you Restore Modified firmware after box modification ?
Br - srinibas
Old 12-24-2012, 20:19   #285 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
Br - srinibas
thanks sir
after restore box using modified pbc now box is 100% ok
Page generated in 0.21658 seconds with 10 queries
