Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks: 19
| <<<o>>> <<< Resolve GREEN LIGHT Problems >>> <<<o>>> GREEN Light Problems can also be caused by Old FTDI Drivers. How to detect if your Problem is Hardware or Software? Software Problem Symptoms: 1. ATF Box is NOT DETECTED by the ATF Software. 2. Device Manager shows Driver Version "2007", "2006" etc... 3. You have just recently installed JAF, UFS, SE, UB, etc... any other box that uses FTDI Chip Easy fix for GREEN Light Software Problems is: 1. Remove ATF Box from USB Port 2. Remove ATF Drivers using this: C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 3. Reconnect ATF Box to USB Port and install the Proper Drivers. If you are still having Problems after the reinstalling the Drivers, then maybe you need to modify the PCB. Read first this thread before modifying your PCB. Q: What is really the Problem ??? A: One batch of LT1930 ordered from Linear Tech was plagued with problems. Q: Was this caused by Short-Circuit Phones ??? A: No, sometimes they malfunction even when they are idle. Q: My Box is still OK, but getting Hot... Is this the same Problem ??? A: Unfortunately, Yes... Q: So I need to buy Replacement Parts ? A: No, you just need to remove the LT1930 and it's 3 supporting components Q: So with "less" parts, do I get "less" features out of my Box ? A: No, all Functions will be the same and you get extra 1.5 GB bandwidth for the first 6 months (Box Warranty Period). Q: Do I loose 6 Months Warranty if I open my Box ? A: No, but you must put the "Special Firmware" inside the box in so that your Warranty will still be Valid. Q: My box is 100% ok, but I want free 1.5 GB extra Bandwidth. Can I put "Special Firmware" inside my box even without Modifying the PCB ? A: No, You will Kill your box. Special Firmware is only for Modified PCB. After putting Special Firmware inside the box, you cannot go back to Regular Firmware unless you make a Manual Request to the Product Supporters. Q: My Box already has Special Firmware Inside, what happens if I click "Restore Box" from the Software? A: It is 100% safe. The Server will detect your Special Firmware and restore the correct Firmware for your PCB. Q: Ok, I am ready to modify my ATF box, where do I get the FULL Instructions ? A: Here you go: http://www.advance-box.com/modify_pcb/modify_pcb.rar Please Post on this Thread if you have more Questions. B/R Last edited by Advance-Box; 06-11-2010 at 06:44. |
| | #2 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: May 2005 Location: Malaysia Age: 38
Member: 144914 Status: Offline Thanks: 61
| Thanks ,now my ATF can boot DCT4 ![]() ![]() Code: Boot Check, Please wait...
DCT-4 Protocol Settings Loaded...
MCUID Response
MessageID : 92
msbUPP_ID : 31
lsbUPP_ID : 62
Boot OK
Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia
DataLen : 000009D8
Boot OK!
MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
DCT4 Mess 9F MUL3 Mess 9F
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 00EC - SAMSUNG (SEC)
DevId0 : 2208 - K8F5615ETM/K5G5629ATD
ExtId0 : 0000
RevId0 : 9121
SectorSize0: 11
Reserved0 : 00
DevAddr1 : 02
ManuId1 : 0000 - Flash
DevId1 : 0001 - not used
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
CheckSum : F6
ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
SearchForBootstrap_DCT4 : No Error
Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_amd.fia
ALGO SENT..
Perform AUTHENTICATION..
MSID: 849D14B32A9307525C466820E5
DecodedMSID: 84CDF1BAEF0005E915AA00024D
EncodedFAID: DFDC01C18BD83212DFFD806E
Authentication : SUCCESSFULL
Repowering Phone....
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
Done! |
| The Following 11 Users Say Thank You to express For This Useful Post: |
| | #5 (permalink) |
| @anilanil Link works 100 + 1 %... Just click it ... if some problem, then it is your browser or Anti-Virus. B/R |
| The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: Bangladesh (Sezan point) Age: 32
Member: 772645 Status: Offline Sonork: 100.1591509 Thanks: 36
| @Advance box Thank you supporter for your usefull post. That can easy to reaper ATF box all user which can face the problem................... br. dreams_bd |
| The Following User Says Thank You to dreams_bd For This Useful Post: |
| | #9 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok Age: 43
Member: 611 Status: Offline Sonork: 100.33333 Thanks: 15
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: ((((((((0)))))))) Age: 30
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks: 452
| i have same problem GREEN light of after launch ATF software and show only TURBO on software....... I uninstall box driver and install new box drivers and my problem is solved...... Guljee |
| The Following 2 Users Say Thank You to guljee786 For This Useful Post: |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2008
Member: 859702 Status: Offline Sonork: 12345 Thanks: 62
| after compelet make it, i can flash 1phone, now box not detect.. please help me advance box.. in port driver i see usb conveter a and usb converter b |
| | #14 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Bangladesh Age: 28
Member: 619931 Status: Offline Sonork: 100.1593005 Thanks: 162
| link working Link works 100 + 1 %... Just click it ... if some problem, then it is your browser or Anti-Virus. B/R i am agree with him |
| The Following User Says Thank You to vistasamir For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
