06-12-2010, 05:29 | #17 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @BackSlash_cu It is not box problem but more on USB Timing of each PC. I get this message as well on 2 laptops here with me. But my 4 year old HP centrino does not show this error. I will adjust it more in next release... But once you get a readout after Reset Box, then there is nothign to worry about. B/R |
06-12-2010, 15:28 | #18 (permalink) | |
No Life Poster Join Date: Sep 2008
Member: 859702 Status: Offline Sonork: 100.1619060 Thanks Meter: 78 | Quote:
in my hand have 5advance turbo flasher.. 4box done.. 1box problem.. please give me solution for this in port driver i see usb conveter a and usb converter b | |
06-12-2010, 16:39 | #19 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @iwan8818 Download MPROG 3.5 from FTDI Chip Home Page Here is the Direct Link: http://www.ftdichip.com/Resources/Ut...s/MProg3.5.zip So extract, run it, and write EEPROM to your Box... EEPROM File is here: C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept Then disconnect ATF from USB, Connect it again... Install Drivers etc... Done B/R |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
06-21-2010, 11:53 | #23 (permalink) |
Junior Member Join Date: May 2005 Age: 41
Member: 145546 Status: Offline Thanks Meter: 6 | can't update FTDI eeprom ... when i open ...... ******* FTDI EEPROM is not Updated ******** Go to "Product Support" Click "UPDATE FTDI EEPROM" AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.30.10 Software Version : v5.30 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... after Go to "Product Support"..Click "UPDATE FTDI EEPROM"... show:::::atfeep.bin not found... what can i do ???? thanks for help |
07-01-2010, 19:43 | #27 (permalink) |
Freak Poster Join Date: May 2007 Location: Romania
Member: 513613 Status: Offline Thanks Meter: 25 | ATF box Dead About 2 days ago my ATF box was working fine, the next day nothing worked with it. I launch the program and its ok my box fimware ok, but cannot boot or check any phone. Nor info. It says Vbat off Vbat on etc for over about 3 times. The phone doesnt blink nor does it power on nothing. Tried installing, uninstalling, 2 different pc plus 1 laptop. Nothing works. Also only the yellow led on the RJ45 port lights up, the green one doesn't. My question, do I need to replace the box or I can fix it myself? Am I having the same issue as a few members here? Thanks in advance. Regards |
The Following User Says Thank You to Robi-K For This Useful Post: |
07-01-2010, 19:48 | #28 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: around the globe
Member: 418852 Status: Offline Sonork: 100:1587670 Thanks Meter: 839 | Quote:
I think possible you may have the same problem with some users here.. please bear with us.. now, please trackback to the first post of this thread.. try every possible suggestion to fix your box.. if it wont cost you that much to ship the box to your reseller you may do so and we'l ask them to ship you a pre-moded box, or from the instruction (how to fix) and still this box will be on warranty. br frozenice | |
The Following 3 Users Say Thank You to frozenice For This Useful Post: |
07-08-2010, 21:12 | #30 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | if LT1930 is bad can we replce it with any other equivalent regulator , it seems that my my box regulator is gone there is no green light on box software open [erfectly but cant detect any phone |
