Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-25-2010, 09:03   #61 (permalink)
gsmdocter's Avatar
Member: 1294693
Sonork: 100.1591739
Originally Posted by zhizun888 View Post
How can i know if my box have LT1930 without open my ATF-BOX? Thanks
br
dont worry about open box
Q: Do I loose 6 Months Warranty if I open my Box ?
A: No, but you must put the "Special Firmware" inside the box in so that
your Warranty will still be Valid.
The Following User Says Thank You to gsmdocter For This Useful Post:
Old 08-26-2010, 20:08   #62 (permalink)
Member: 51715
Originally Posted by Advance-Box View Post
GREEN Light Problems can also be caused by Old FTDI Drivers.
How to detect if your Problem is Hardware or Software?
Software Problem Symptoms:
1. ATF Box is NOT DETECTED by the ATF Software.
2. Device Manager shows Driver Version "2007", "2006" etc...
3. You have just recently installed JAF, UFS, SE, UB, etc... any other box that uses FTDI Chip
Easy fix for GREEN Light Software Problems is:
1. Remove ATF Box from USB Port
2. Remove ATF Drivers using this:
C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
3. Reconnect ATF Box to USB Port and install the Proper Drivers.
If you are still having Problems after the reinstalling the Drivers, then maybe you need to
modify the PCB. Read first this thread before modifying your PCB.
Q: What is really the Problem ???
A: One batch of LT1930 ordered from Linear Tech was plagued with problems.
Q: Was this caused by Short-Circuit Phones ???
A: No, sometimes they malfunction even when they are idle.
Q: My Box is still OK, but getting Hot... Is this the same Problem ???
A: Unfortunately, Yes...
Q: So I need to buy Replacement Parts ?
A: No, you just need to remove the LT1930 and it's 3 supporting components
Q: So with "less" parts, do I get "less" features out of my Box ?
A: No, all Functions will be the same and you get extra 1.5 GB bandwidth for
the first 6 months (Box Warranty Period).
Q: My box is 100% ok, but I want free 1.5 GB extra Bandwidth. Can I put
"Special Firmware" inside my box even without Modifying the PCB ?
A: No, You will Kill your box. Special Firmware is only for Modified PCB. After
putting Special Firmware inside the box, you cannot go back to Regular
Firmware unless you make a Manual Request to the Product Supporters.
Q: My Box already has Special Firmware Inside, what happens if I click
"Restore Box" from the Software?
A: It is 100% safe. The Server will detect your Special Firmware and restore
the correct Firmware for your PCB.
Q: Ok, I am ready to modify my ATF box, where do I get the FULL
Instructions ?
A: Here you go:
http://www.advance-box.com/modify_pcb/modify_pcb.rar
Please Post on this Thread if you have more Questions.
B/R
Thank u ATF Today i have solved the problem with this procedure now my box is working perfect
The Following User Says Thank You to NSM TECHNOLOGIES For This Useful Post:
Old 08-27-2010, 22:56   #63 (permalink)
ahmedzameer's Avatar
Member: 431754
Pleez_ATF Teem Gide Me
After Modifi Box is Working perfect _ But (Circular Orange: VPP-LED Also On)
PLZ halp me-UFC 4 when i conect Box led Of _ other box is Wrking
thanks
Old 09-01-2010, 22:31   #64 (permalink)
Member: 257782
Box new.
I have done Step 3.
I had no problems with boxing.
Please give the original firmware is not modified.
Old 09-03-2010, 20:04   #65 (permalink)
GSM boy's Avatar
Member: 1375690
@ atf team
after modifying pcb all lights on (blue green yellow) is it normal ?????????????????
Old 09-04-2010, 06:09   #66 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: haidzam@yahoo.com
i need clear more about atf normal
my box when put in usb it show blue and green ,when press sfotware it turn off green and light it again when software open done,it normal?
Old 09-04-2010, 15:14   #67 (permalink)
Advance-Box's Avatar
Member: 651945
@GSM boy
YES, Normal
@freedomqn
YES, Normal
@mortan
I will prepare something for you.
The Following 3 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-07-2010, 09:13   #68 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
thanx ...
my prob.. is solved..
Old 09-12-2010, 10:30   #69 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Arrow
@GSM boy
YES, Normal
@freedomqn
YES, Normalhttp://forum.gsmhosting.com/vbb/newreply.php?do=newreply&p=6292271
@mortan
I have same problem and i tried to install/uninstall driver but no luck
can u guide me how can i repair this
Delower
Old 09-23-2010, 09:05   #70 (permalink)
Member: 686500
sir if i try for modification in pcb by opening box will i get warrenty for the atf box in future frm the reseller?
Old 09-23-2010, 17:11   #71 (permalink)
dharyadi's Avatar
Member: 369678
as i see so many user have problem with the box ( Hardware).
please fix hardware issue on new Productions, i plan to buy this tool, but now iam wondering.
Old 09-24-2010, 14:22   #72 (permalink)
m_choko's Avatar
Member: 88177
Sonork: 1594092
hi
i just get ATF box one day ago
i istalled all driver and soft, the box work perfectly!! but today my ATF cant connect any phone, the soft is ok, activation, restore box success...
but cant detect any phone.....
were the problem please help and advice to resolve this problem
thanks
Old 09-25-2010, 07:52   #73 (permalink)
vaghubha_sodha's Avatar
Member: 823633
Sonork: 9898260467
my atf box blue led show only
not conect any phone flash bus
atf prob please help
my box blue led pic here
Old 09-29-2010, 13:58   #74 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
perfect my box working again....
Old 10-02-2010, 19:54   #75 (permalink)
Member: 174203
yes...happy to see the ATF WORK AGAIN...U FELL THE POWER
Page generated in 1.41680 seconds with 11 queries
