02-24-2010, 03:15 | #8 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | check it here http://forum.gsmhosting.com/vbb/showthread.php?t=934629 |
02-24-2010, 03:15 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @xerraco It not the same as MT to JAF converter bcause MT to JAF converter does not make the VPP Pin available to the JAF 7-PIN cable. It is not the same, but the MT to JAF converter will STILL WORK with ATF without any modifications. That is if you are not interested in using the VPP PIN to make slow based NOR phones erase their flash chips faster. If you are interested in using the VPP of you MT 10 PIN cable, you need a little modification. Connect the VPP PIN of the 10 PIN cable to PIN 2 of the JAF 8 PIN Converter. In all JAF cables, PIN 2 (beside PIN 1 VBATT) is not used. The OFFICIAL pinout of ATF is 1:1 with JAF with an optional VPP Pin on PIN 2 which is not used by JAF. Heres the Pinout for the ATF 8-PIN FLASHBUS 1 - VBATT 2 - VPP 3 - BSI 4 - FBUS_TX 5 - FBUS_RX0 6 - FBUS_CLK / MBUS 7 - GROUND 8 - FBUS_RX1 B.R. X-S 6 - Last edited by Advance-Box; 02-24-2010 at 03:24. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
***3710A fbus 8 & 10 pin cable ready for shipping *** | DITS | LATEST DITS GSM NEWS | 7 | 03-12-2010 04:34 |
the nokia cables is wit 8 or 10 pins? | onecomunicaciones | Universalbox | 3 | 11-03-2009 04:47 |
mt box 8 to 10 pin adopters and mt to uni adopter | a2b2t | MT-BOX | 2 | 03-31-2009 19:23 |
My Infinity Box's RJ-45 Jack Not Working Need Help | AsiaGSM™ | Infinity-Box | 12 | 01-08-2008 17:59 |
my x-3 code is it 8 or 10 digit.? | bonanza | ARM9 BASED M62 / M62+ | 2 | 09-04-2003 10:26 |
