03-02-2011, 11:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | PA_SL3/PA_SIMLOC30 SuperDongle Successful repaired Please, be so nice and put in this thread all successfuly repaired SD phones - New/Old hashes.. Credits consumption: - Box must be activated for ATF Network account. - Each SD repair will cost you 5 ATF Network credits. Where to buy ATF Network credits? You can get it from 'ATF Store' tab, It located in ATF Main Software next to 'ProductSupport' tab. And You can also get credits from Authorized Distributors or Resellers. Here are logs from X-Shadow post: Here the phone shows SUPER DONGLE Problem When we try with "Stand-Alone" SD Repair, you will see this message So go to "The ATF Network" and Authorize this Phone... After it is "Authorized" you can stand alone SD Repair it! Now SD is repaired... but.... We need to SX-4 this phone and upload PM 1 and 309 as well So here SX-4 was a Success (Stand Alone as well) SD Check Button shows everything is OK Self Tests show everything is OK as well PS: Keep this thread clean for successfuly repaired phones. All posts which are not releated to this topic will be deleted! BR Last edited by ..::Angel::..; 03-02-2011 at 11:55. |
The Following 50 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-05-2011, 05:24 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | @ ..::Angel::.. one que ... if i have a done super dongle in x3 and ok rpl save in atf then i receive after some day same pic x3 with sd problem can i repair with my ok save rpl ? or need 5 logs again for it ? |
03-05-2011, 08:02 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | yes kalpesh has good point, if we need again 5 credits to repair sd for a fone which was previously sd repaired with atf with 5 credits or the server recognises the imei of the handset previously repaired with credits |
03-05-2011, 08:05 | #6 (permalink) | |
Member: 116314 Status: Offline Thanks Meter: 147 | Quote:
03-05-2011, 08:11 | #7 (permalink) | |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | Quote:
BR Thomas | |
The Following 3 Users Say Thank You to gsmfun For This Useful Post: |
03-05-2011, 16:59 | #8 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 6700c RM-470 SL3 SD repair 6700 RM-470 (STEP 1 : Authorize Phone with ATF Network) Code: VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 12000105 ID DWORD 1 : F35E0344 ID DWORD 2 : F94C11C7 ID DWORD 3 : D04429C9 ID DWORD 4 : 25882C72 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA Checksum D7 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 28 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Patch Loader Found! C:\AdvanceBox Turbo Flasher\Nokia\loader\CustomLoader_RAPUv11.ldr Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Reading NPC IMEI... 356943033497372 Connecting to The ATF Network Network Connection Accepted Requesting Authorization Code Authorization Code Received Verifying Authorization Code Authorization Code is OK Saving Authorization Code File Saving Complete!!! ====================================================== Phone was Successfully Authorized ====================================================== Super Dongle Repair and Stand Alone SX-4 is NOW ENABLED for this Phone... ====================================================== Thank you for using The ATF Network FlashInfo.RestartMode : 2 Time Taken to Complete Tasks: 00:00:16 Code: MCU: V 13.21 12-01-11 RM-470 (c) Nokia IMEI: 356943033497372 Model : Nokia 6700 classic Product Serial Number: CVC807887 Product Code : 0571128 Module Code : 0204199 Basic Production Code: 0590482 Default SN Type : 0 MCU SW Version : V 13.21 12-01-11 RM-470 (c) Nokia C BT MCM Version : 410B-v190 PPM Version : V 13.21 12-01-11 RM-470 (c) Nokia HW Version : 2001 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR81_10w09 LCD Version : TPO Content Pack Version : Content: ctv DE V 13.21 12-01-11 RM-470 (c) Nokia AHNE Version : 11 Retu Version : 34 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 8000000000000002 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : FAILED > Try "Repair Super Dongle" Code: =================================================== Super Dongle RPL Stand Alone Edition =================================================== Generating Super Dongle RPL... (This may take upto 30 Seconds on New RAPIDO HASH) Sending Superdongle RPL... OK: Super Dongle RPL accepted Successfully done. ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-470.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 116 - Ok Field : 1 Sub : 2 Byte(s): 12 - Ok Field : 1 Sub : 4 Byte(s): 112 - Ok Field : 1 Sub : 6 Byte(s): 12 - Ok Field : 1 Sub : 7 Byte(s): 216 - Ok Field : 1 Sub : 8 Byte(s): 112 - Ok Field : 1 Sub : 13 Byte(s): 12 - Ok Field : 1 Sub : 16 Byte(s): 208 - Ok Field : 1 Sub : 18 Byte(s): 208 - Ok Field : 1 Sub : 20 Byte(s): 208 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 26 Byte(s): 112 - Ok Field : 1 Sub : 28 Byte(s): 12 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 31 Byte(s): 208 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 376 - Ok Field : 1 Sub : 35 Byte(s): 16 - Ok Field : 1 Sub : 37 Byte(s): 4 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 16 - Ok Field : 1 Sub : 41 Byte(s): 184 - Ok Field : 1 Sub : 42 Byte(s): 4 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 184 - Ok Field : 1 Sub : 45 Byte(s): 184 - Ok Field : 1 Sub : 46 Byte(s): 64 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... Code: MCU: V 13.21 12-01-11 RM-470 (c) Nokia IMEI: 356943033497372 Model : Nokia 6700 classic Product Serial Number: CVC807887 Product Code : 0571128 Module Code : 0204199 Basic Production Code: 0590482 Default SN Type : 0 MCU SW Version : V 13.21 12-01-11 RM-470 (c) Nokia C BT MCM Version : 410B-v190 PPM Version : V 13.21 12-01-11 RM-470 (c) Nokia HW Version : 2001 RFIC Version : |Vapaus_5.1 | Aura_?.? DSP Version : ICPR81_10w09 LCD Version : TPO Content Pack Version : Content: ctv DE V 13.21 12-01-11 RM-470 (c) Nokia AHNE Version : 11 Retu Version : 34 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 8000000000000002 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : ISL2TI020000093E2F30 DCC Ver: 001007 Status : OK |
03-05-2011, 17:15 | #10 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | C5-00 Super Dongle Problem C5-00 Super Dongle Problem Code: MCU: V ICPR82_10w08 26-02-10 RM-645 (c) Nokia IMEI: 359345030184325 Model : Nokia C5-00 Product Serial Number: CUD529440 Product Code : 0593564 Module Code : 0204492 Basic Production Code: 0591907 Default SN Type : 0 PPM Version : V ICPR82_10w08 26-02-10 RM-645 (c) Nokia HW Version : 6000 RFIC Version : |Vapaus_5.1 | Mikki_1.1 DSP Version : ICPR82_10w08 AHNE Version : 11 APE SW Core Version : 031.022 APE Variant Version : 031.022031.022.13.01031.022.C00.01 APE Test Version : 10wk48v0.001_APEONLY Retu Version : 35 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : FAILED > Try "Repair Super Dongle" ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST MODE Code: AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27E00012 ID DWORD 1 : 2C770E49 ID DWORD 2 : DECA7C54 ID DWORD 3 : 3D9607FE ID DWORD 4 : 65DC805E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum CC SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 54 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Patch Loader Found! C:\AdvanceBox Turbo Flasher\Nokia\loader\CustomLoader_RAPUv11.ldr Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Reading NPC IMEI... 359345030184325 Connecting to The ATF Network Network Connection Accepted Requesting Authorization Code Authorization Code Received Verifying Authorization Code Authorization Code is OK Saving Authorization Code File Saving Complete!!! ====================================================== Phone was Successfully Authorized ====================================================== Super Dongle Repair and Stand Alone SX-4 is NOW ENABLED for this Phone... ====================================================== Thank you for using The ATF Network FlashInfo.RestartMode : 2 Time Taken to Complete Tasks: 00:00:14 Code: ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\7.00\sx4\RM-645.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 116 - Ok Field : 1 Sub : 2 Byte(s): 12 - Ok Field : 1 Sub : 4 Byte(s): 112 - Ok Field : 1 Sub : 6 Byte(s): 12 - Ok Field : 1 Sub : 7 Byte(s): 216 - Ok Field : 1 Sub : 8 Byte(s): 112 - Ok Field : 1 Sub : 13 Byte(s): 12 - Ok Field : 1 Sub : 16 Byte(s): 208 - Ok Field : 1 Sub : 18 Byte(s): 208 - Ok Field : 1 Sub : 20 Byte(s): 208 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 26 Byte(s): 112 - Ok Field : 1 Sub : 28 Byte(s): 12 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 31 Byte(s): 208 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 376 - Ok Field : 1 Sub : 35 Byte(s): 16 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 16 - Ok Field : 1 Sub : 41 Byte(s): 184 - Ok Field : 1 Sub : 42 Byte(s): 4 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 184 - Ok Field : 1 Sub : 45 Byte(s): 184 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... Code: MCU: V ICPR82_10w08 26-02-10 RM-645 (c) Nokia IMEI: 359345030184325 Model : Nokia C5-00 Product Serial Number: CUD529440 Product Code : 0593564 Module Code : 0204492 Basic Production Code: 0591907 Default SN Type : 0 PPM Version : V ICPR82_10w08 26-02-10 RM-645 (c) Nokia HW Version : 6000 RFIC Version : |Vapaus_5.1 | Mikki_1.1 DSP Version : ICPR82_10w08 AHNE Version : 11 APE SW Core Version : 031.022 APE Variant Version : 031.022031.022.13.01031.022.C00.01 APE Test Version : 10wk48v0.001_APEONLY Retu Version : 35 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : LOCAL MODE ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\7.00\sx4\RM-645.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 116 - Ok Field : 1 Sub : 2 Byte(s): 12 - Ok Field : 1 Sub : 4 Byte(s): 112 - Ok Field : 1 Sub : 6 Byte(s): 12 - Ok Field : 1 Sub : 7 Byte(s): 216 - Ok Field : 1 Sub : 8 Byte(s): 112 - Ok Field : 1 Sub : 13 Byte(s): 12 - Ok Field : 1 Sub : 16 Byte(s): 208 - Ok Field : 1 Sub : 18 Byte(s): 208 - Ok Field : 1 Sub : 20 Byte(s): 208 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 26 Byte(s): 112 - Ok Field : 1 Sub : 28 Byte(s): 12 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 31 Byte(s): 208 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 376 - Ok Field : 1 Sub : 35 Byte(s): 16 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 16 - Ok Field : 1 Sub : 41 Byte(s): 184 - Ok Field : 1 Sub : 42 Byte(s): 4 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 184 - Ok Field : 1 Sub : 45 Byte(s): 184 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok PM Upload Done!... MCU: V ICPR82_10w08 26-02-10 RM-645 (c) Nokia IMEI: 359345030184325 Model : Nokia C5-00 Product Serial Number: CUD529440 Product Code : 0593564 Module Code : 0204492 Basic Production Code: 0591907 Default SN Type : 0 PPM Version : V ICPR82_10w08 26-02-10 RM-645 (c) Nokia HW Version : 6000 RFIC Version : |Vapaus_5.1 | Mikki_1.1 DSP Version : ICPR82_10w08 AHNE Version : 11 APE SW Core Version : 031.022 APE Variant Version : 031.022031.022.13.01031.022.C00.01 APE Test Version : 10wk48v0.001_APEONLY Retu Version : 35 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : LOCAL MODE |
The Following User Says Thank You to gsmfun For This Useful Post: |
03-05-2011, 17:48 | #11 (permalink) |
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | 5233 Phone Killed by Software Upgrade to Latest Nokiyo version 5233 Phone Killed by Software Upgrade to Latest Nokiyo version Code: MCU: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia IMEI: 351514046780008 Model : Nokia 5230 Product Serial Number: 0 Default SN Type : 0 PPM Version : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia RFIC Version : 17141715 DSP Version : simon_ICPR72_10w05 APE BT Version : HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. Content Pack Version : v 001_000 05-03-10 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 20.6.007 APE Variant Version : V 20.6.007V 20.6.007 V 20.6.007 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** Unable to read SP Data.. ******** Reading SimLock ******** Unable to read SP Data.. SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED PHONE_MODE : LOCAL MODE Changing MODE : FLASH BOOTING BB5 Phone... ****************************************************** TIME STARTS HERE ****************************************************** CMT Hardware : 400C192101051103 CMT PUBLIC ID : 09500119F6890052BDB4BF8150AA156F99964B0A CMT ROOTHASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM_ID : 4B9B75103E691FF8 Send Loader... ================================================ This Phone is a "New HASH" Phone ================================================ You need to use The ATF Network and Authorize this Phone to enable Super Dongle Repair and Stand-Alone SX4. Visit The ATF Store for more Information Code: AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 09500119 ID DWORD 1 : F6890052 ID DWORD 2 : BDB4BF81 ID DWORD 3 : 50AA156F ID DWORD 4 : 99964B0A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 5B SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0231 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 13 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Patch Loader Found! C:\AdvanceBox Turbo Flasher\Nokia\loader\CustomLoader_RAPIDOv11.ldr Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Reading NPC IMEI... 351514046780008 Connecting to The ATF Network Network Connection Accepted Requesting Authorization Code Authorization Code Received Verifying Authorization Code Authorization Code is OK Saving Authorization Code File Saving Complete!!! ====================================================== Phone was Successfully Authorized ====================================================== Super Dongle Repair and Stand Alone SX-4 is NOW ENABLED for this Phone... ====================================================== Thank you for using The ATF Network FlashInfo.RestartMode : 2 Time Taken to Complete Tasks: 00:00:11 Code: MCU: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia IMEI: 351514046780008 Model : Nokia 5230 Product Serial Number: MYN008354 Product Code : 0589725 Basic Production Code: 0582715 Default SN Type : 0 PPM Version : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia HW Version : 0501 RFIC Version : 17141715 DSP Version : simon_ICPR72_10w05 Content Pack Version : v 001_000 05-03-10 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 20.6.007 APE Variant Version : V 20.6.007V 20.6.007 V 20.6.007 APE Test Version : rm588_ENO_x_09wk43v0.020 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : FAILED > Try "Repair Super Dongle" ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST MODE Code: MCU: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia IMEI: 351514046780008 Model : Nokia 5230 Product Serial Number: MYN008354 Product Code : 0589725 Basic Production Code: 0582715 Default SN Type : 0 PPM Version : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia HW Version : 0501 RFIC Version : 17141715 DSP Version : simon_ICPR72_10w05 Content Pack Version : v 001_000 05-03-10 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 20.6.007 APE Variant Version : V 20.6.007V 20.6.007 V 20.6.007 APE Test Version : rm588_ENO_x_09wk43v0.020 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE ================================================ SX4 Custom Keys Stand Alone Edition ================================================ *** WARNING: Current Super Dongle Keys are Invalid! *** Attempting to write New Super Dongle Keys... MCU: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia IMEI: 351514046780008 Model : Nokia 5230 Product Serial Number: MYN008354 Product Code : 0589725 Basic Production Code: 0582715 Default SN Type : 0 PPM Version : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia HW Version : 0501 RFIC Version : 17141715 DSP Version : simon_ICPR72_10w05 Content Pack Version : v 001_000 05-03-10 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 20.6.007 APE Variant Version : V 20.6.007V 20.6.007 V 20.6.007 APE Test Version : rm588_ENO_x_09wk43v0.020 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE =================================================== Super Dongle RPL Stand Alone Edition =================================================== Generating Super Dongle RPL... (This may take upto 30 Seconds on New RAPIDO HASH) Sending Superdongle RPL... OK: Super Dongle RPL accepted Successfully done. ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\351514046780008\351514046780008_0-400_122458.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 116 - Ok Field : 1 Sub : 2 Byte(s): 100 - Ok Field : 1 Sub : 4 Byte(s): 112 - Ok Field : 1 Sub : 6 Byte(s): 100 - Ok Field : 1 Sub : 8 Byte(s): 112 - Ok Field : 1 Sub : 13 Byte(s): 100 - Ok Field : 1 Sub : 16 Byte(s): 100 - Ok Field : 1 Sub : 18 Byte(s): 100 - Ok Field : 1 Sub : 20 Byte(s): 100 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 4 - Ok Field : 1 Sub : 26 Byte(s): 112 - Ok Field : 1 Sub : 28 Byte(s): 100 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 31 Byte(s): 100 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 80 - Ok Field : 1 Sub : 35 Byte(s): 16 - Ok Field : 1 Sub : 37 Byte(s): 4 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 184 - Ok Field : 1 Sub : 45 Byte(s): 184 - Ok Field : 2 Sub : 0 Byte(s): 448 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 1 Byte(s): 16 - Ok Field : 8 Sub : 2 Byte(s): 16 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 7 Byte(s): 4 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 8 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 10 Byte(s): 24 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 1064 - Ok Field : 12 Sub : 0 Byte(s): 104 - Ok Field : 26 Sub : 0 Byte(s): 16 - Ok Field : 26 Sub : 1 Byte(s): 68 - Ok Field : 31 Sub : 4 Byte(s): 16 - Ok Field : 44 Sub : 0 Byte(s): 4 - Ok Field : 50 Sub : 0 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 88 Sub : 0 Byte(s): 36 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 96 Sub : 1 Byte(s): 20 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 80 - Ok Field : 107 Sub : 2 Byte(s): 80 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 25 Byte(s): 132 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 117 Sub : 0 Byte(s): 4 - Ok Field : 117 Sub : 1 Byte(s): 4 - Ok Field : 117 Sub : 2 Byte(s): 8 - Ok Field : 117 Sub : 3 Byte(s): 4 - Ok Field : 117 Sub : 5 Byte(s): 12 - Ok Field : 117 Sub : 6 Byte(s): 8 - Ok Field : 117 Sub : 13 Byte(s): 4 - Ok Field : 117 Sub : 14 Byte(s): 4 - Ok Field : 117 Sub : 16 Byte(s): 40 - Ok Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 208 Sub : 1 Byte(s): 4 - Ok Field : 217 Sub : 0 Byte(s): 32 - Ok Field : 239 Sub : 0 Byte(s): 4 - Ok Field : 239 Sub : 1 Byte(s): 2308 - Ok Field : 239 Sub : 2 Byte(s): 2308 - Ok Field : 239 Sub : 3 Byte(s): 2308 - Ok Field : 239 Sub : 4 Byte(s): 2308 - Ok Field : 239 Sub : 5 Byte(s): 2308 - Ok Field : 291 Sub : 0 Byte(s): 92 - Ok Field : 308 Sub : 0 Byte(s): 4 - Failed Field : 308 Sub : 1 Byte(s): 8192 - Failed Field : 308 Sub : 2 Byte(s): 4 - Failed Field : 308 Sub : 3 Byte(s): 4 - Failed Field : 308 Sub : 4 Byte(s): 4 - Failed Field : 308 Sub : 6 Byte(s): 4 - Failed Field : 308 Sub : 7 Byte(s): 4 - Failed Field : 308 Sub : 9 Byte(s): 40 - Failed Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 329 Sub : 0 Byte(s): 8392 - Ok Field : 334 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 354 Sub : 0 Byte(s): 16 - Ok Field : 356 Sub : 0 Byte(s): 4 - Ok PM Upload Done!... Code: MCU: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia IMEI: 351514046780008 Model : Nokia 5230 Product Serial Number: MYN008354 Product Code : 0589725 Basic Production Code: 0582715 Default SN Type : 0 PPM Version : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia HW Version : 0501 RFIC Version : 17141715 DSP Version : simon_ICPR72_10w05 Content Pack Version : v 001_000 05-03-10 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 20.6.007 APE Variant Version : V 20.6.007V 20.6.007 V 20.6.007 APE Test Version : rm588_ENO_x_09wk43v0.020 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST MODE |
03-06-2011, 02:52 | #12 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | none of successfull log posted by ATF users yet all from ATF team i think its bcz of high price of activation .think once again about prices it will be better for both ATF team and atf users. Best Regard |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
03-06-2011, 05:27 | #14 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @german gsm team Yes,, After phone authorization,, SX4 and SD repair even without internet connection and for an unlimited number of times, just as long as you do not delete the authorization file for the said phone. If you delete it, then it will be like deleting an RPL file... You cannot get it back unless you authorize phone again with another 5 credits. |
03-06-2011, 10:35 | #15 (permalink) | |
http://forum.gsmhosting.com/vbb/f609...pdate-1220655/ He just post in wrong section, that is all. About price just caculate about Original RPL and our activation price. You can see which is more worth. BR Thomas | |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
5110 Contact Service Repairer via MBUS/FBUS | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-15-2010 04:17 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
