11-03-2014, 03:41
#1 (permalink)
Member: 1911593
Sonork: 100.1645151 Thanks Meter: 130 | Pinout eMMC SM-N900T OK Tks Team ATF !
Log ATF: Quote:
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 1501004D4247344743007E0D4BDC
CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Boot Information
Revision 1.x (For MMC v4.x)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 31268536320 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : MBG4GC
Product Rev : 0.0
Product SN : 7E0D4BDC
Manufactured : January 1998
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRANS_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
1501004D4247344743007E0D4BDC_C35520AC.ext_csd
Backup Directory:
D:\Brick Repair\ATF\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
1501004D4247344743007E0D4BDC_68B1EBF7.ext_csd
Backup Directory:
Task Selected: Normal Factory Erase
For eMMC Revision 1.2 (for MMC v4.2) and LOWER
--> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB
For eMMC Revision 1.3 (for MMC v4.3) and HIGHER
--> This will ONLY ERASE USER AREA
This eMMC is: Revision 1.x (For MMC v4.x)
Factory Erasing Supported FLASH AREA...
Normal Factory Erase Done!
WARNING - WARNING - WARNING - WARNING - WARNING
1. WRITE BOOT1 Image if Needed
2. WRITE BOOT2 Image if Needed
3. WRITE USER AREA Image if Needed
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
1501004D4247344743007E0D4BDC_75D97115.ext_csd
Backup Directory:
Task Selected: Samsung Factory Format
For eMMC Revision 1.5 (for MMC v4.41) and LOWER
--> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries
For eMMC Revision 1.6 (for MMC v4.5) and HIGHER
Samsung Factory Format Start...
Format Done!
1. WRITE Back EXT_CSD Backup if Needed
2. WRITE BOOT1 Image if Needed
3. WRITE BOOT2 Image if Needed
4. WRITE USER AREA Image if Needed
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
1501004D4247344743007E0D4BDC_868AAE81.ext_csd
Backup Directory:
Start Writing 0x003E8000 Blocks at 0x00000000
Partition Selected: USER AREA
Total Elapsed Time 00:57:43
Write Success! | |
