Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-17-2012, 07:24   #1 (permalink)
Member: 613449
Sonork: 100.1614074
please help, ATF Box is not in USB 2.0 Mode
Old 06-17-2012, 07:59   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Do step by step
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. Re Install ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers from - C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS
Br - srinibas ( ATF Team )
The Following User Says Thank You to srinibas For This Useful Post:
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.17976 seconds with 11 queries
