11-02-2013, 12:43 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Please Help ATF Supporters Please Give Me Solution ATF Supporters I Have Not PM Backup But I Have RPL Backup Is OK. After Downgrade SP Data Corrupt. Here Is RPL Backup Upload Mediafire Reason I Have Attachment Problem. 358253039230910 WBR. Arsalan gsm2000. |
11-02-2013, 16:35 | #4 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | try use recovery button level 1 & 2 and post full logs here. supporter well check and identify simlock status |
11-02-2013, 18:42 | #8 (permalink) |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Here Log Level 1 From Phone So? STATUS: Mounting Flash Dump... REPORT: Simlock Hashes was NOT FOUND! REPORT: Simlock Signature was NOT FOUND! REPORT: Simlock Recovery FAILED! REPORT: Try Level 2 or Level 3 Recovery REPORT: Total Elapsed Time 00:46:23 WBR. Arsalan gsm2000. |
11-03-2013, 13:02 | #9 (permalink) |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Level 2-Recover From Phone. STATUS: Mounting Flash Dump... STATUS: PMM Storage Found at 0x0007E000 ERROR: Phone is not Authorized Authorize the Phone via The ATF Network REPORT: Total Elapsed Time 00:43:40 Level 1 & 2 Not Recover But RPL Backup Is Ok After Write SP Data Still Corrupted Help ATF Supporter. WBR. Arsalan gsm2000. |
11-03-2013, 16:13 | #10 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
br P0l@c0 | |
11-03-2013, 21:56 | #12 (permalink) | |
No Backup Simlock ... Maybe ATF Team have a solution. Good Luck p0l@c0 Last edited by el-polaco; 11-03-2013 at 22:00. Reason: keep dreaming :) | |
11-04-2013, 06:48 | #13 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
What you have backup B4 erase the phone ? Only RPL or RPL & PM ? The PM you attached here is not backup B4 erase ( No Sim Lock data inside it ) Br - srinibas | |
