10-29-2014, 08:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Please help with this issue in atf "themida error" screenshot here: please help team.. I use Win (ultimate) 7 64Bit , AVG antivirus , Sometimes Malwarebytes (i have added aft folder to exception list in both softwares) |
10-29-2014, 13:36 | #2 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Atf box donot work Up this thread , Please help me with this issue.! i can't use atf box CANNOT OPEN ATF BOX SOFTWARE Themida- -File corrupted ! This program has been manipulated and may be its infected by virus or cracked. This file won't work anymore! |
10-29-2014, 15:01 | #4 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | not yet fixed Hello. it works only one time after installation ,even after 11.70 if i want to work second time themida error blocks, i have to re-install everytime |
10-30-2014, 09:52 | #7 (permalink) | |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Tired with atf now Quote:
;Removed antivirus ;Completely Removed ATF software ;Restarted the computer ;Re-installed atf 11.70 full installer ;Opened Software , Clicked buscheck, took long time, Software got stuck & hanged ; Ended process by Task manager ;Reopened ATF software , took long & didnt get opened but ATF logo on TaskBar available, when clicked nothing happened it has been a week im trying to flash a phone with atf, Very tired now! | |
10-30-2014, 10:10 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
If yes. - uninstall totally Atf sw from you pc, also cancel folder where you have Atf - unzip New download and install 11.70 Full setup - if not have icon Atf in desktop create manually and open Atf 11.70 - Update files from Sw Update tabulate - set "Nokia Files" from Setting tabulate Post result here. IMPORTANT: if you have AV, put in Exclusion List all .exe file in Atf Folder, also shortcut in desktop, make all this steps above with AV CLOSED. If have always problems i think you "Malwarebytes" used is cause of all this, and the short way is format you pc. Br allumts | |
10-30-2014, 14:22 | #9 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Not fixed .. removing,installing,removing,installing,downloadin g,installing.. for a week now, can there be a problem with atf box? i bought the box a week ago |
10-30-2014, 14:39 | #10 (permalink) | |
BR allumts | |
10-31-2014, 09:59 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have advised in first reply that "Malvarebytes" often damage NOT repair pc from Virus and Malware, this see Malware in other sides, but him not have listen me of Format or use other pc..... |
11-10-2014, 14:10 | #14 (permalink) | |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Quote:
ok, which version of windows i have to install now? im going to reserve a computer for only atf . Also sometimes, Atf software stuck with ATF box connected & Works immediately after removed atf. other times Invalid Response from server(now ok) & everytime .. Themida- -File corrupted ! This program has been manipulated and may be its infected by virus or cracked. This file won't work anymore! | |
11-11-2014, 16:12 | #15 (permalink) | ||||
Read about THEMIDA HERE: Quote:
BR allumts | ||||
