04-02-2011, 07:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1351542 Status: Offline Thanks Meter: 31 | Pls help 7210 flashing MCU: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 359310026063339 Model : Nokia 7210 Supernova Product Serial Number: DTD130606 Product Code : 0572571 Module Code : 0203868 Basic Production Code: 0563951 Default SN Type : 0 MCU SW Version : V 07.23 17-07-09 RM-436 (c) Nokia I BT MCM Version : 2222-143C PPM Version : V 07.23 17-07-09 RM-436 (c) Nokia HW Version : 1001 RFIC Version : 064c0601 DSP Version : ICPR72_09w17 LCD Version : SHARP AHNE Version : 30 Retu Version : 15 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: 002012 Status : OK PM 120 Found... PM 308 Found... SimLock Certificate Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\359310026063339\SL2_certifica te_V 07.23 17-07-09 RM-436 (c) Nokia_359310026063339_Not Locked_115816.pm Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 80608712 (0xC8) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 04700110 ID DWORD 1 : 98F67C56 ID DWORD 2 : 6AC84AE7 ID DWORD 3 : 3EBD3C72 ID DWORD 4 : D305DCF2 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 0F SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv30_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 37 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 RAP3Gv30_XSR14_alg.fg First Algo byte : 56 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv30_XSR14_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 START READING RPL DATA Reading : NPC OK Reading : VARIANT VARIANT : Empty Reading : CCC OK Reading : HWC OK Reading : R&D OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359310026063339\3593100260633 39_115852.rpl FlashInfo.RestartMode : 2 Processing Image File : rm436__07.23.mcusw CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 0 Entry Point: 0x0000 Page Format : -1 MAX PAGE : 0x00000000 Operations Failed.... |
04-02-2011, 07:52 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @harishlalwani You loaded flash files manually and you are using OLD VERSION of ATF ATF Software. Download and install version 7.20 from here: http://rapidshare.com/files/45176213..._Installer.rar or Hotfile.com: One click file hosting: ATF_v7.20_Full_Installer.rar or Download ATF_v7.20_Full_Installer.rar from Mirrorcreator - Upload files to multiple file sharing sites |
The Following User Says Thank You to Advance-Box For This Useful Post: |
