09-24-2012, 08:07 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: india
Member: 627040 Status: Offline Thanks Meter: 58 | pls help lumia 800 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Sending Boot Failed! Check your Test Point Soldering! Total Elapsed Time 00:00:02 successfull unlock br help me |
09-24-2012, 08:14 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @manekmobile07 1. Make sure your wires are not more than 5 inches 2. Make sure you soldered the CORRECT wires to the CORRECT Locations on the PCB 3. DO NOT USE BATTERY + DO NOT CONNECT THE USB CABLE TO THE PHONE!!! 4. Click "Test Connection" ... Does ATF Software tell you to connect the USB cable to the Phone?? |
