09-18-2014, 16:09 | #46 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | I've just make these Sdc file from these 4 Firmware how you had wrote to me: G7102XXUBNG4 G7102XXUBNG8 G7102XXUBNH3 G7102XWUBNH1 Have used "Verbatin" Card but of 16GB, and for the be onest i have tried only BNG4 and BNH3 becouse was out of my city, but now i've buyed all size of "San Disk" Card. No..ahah impossible i ask you how remove Sd Card with Battery, Sd Card can remove w/o problem with battery, is more high of this. This is Qualcomm platform and i think haven't need also Jig, N9005 repaired i've insert Sd Card then device vibrate and goes in D.Mode only with Power Button, after this flashad with odin 4 files +Pit, solved. Now i want apply over this phone and fault to me only SMG7102XXUBNH6_4.4.2_8GB.sdc but have seen Angel has posted also this. Time...time fault but now is arrived the time for repair this G7102, always thanks for you Tips, Br allumts |
09-19-2014, 06:42 | #47 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
First I am trying with 16GB SD card as ATF software asking. Customer bought phone with hang on Samsung Logo I flashed with this file "G7102XXUBNG4_G7102ODDBNG4_INU" Odin3 v3.07. My phone Kill by SPT box with file version 4.3 "G7102XXUAML7" . I think my fault is 16GB SD card now I will try with 8GB sd and post reuslt. With Best Regards. Siddeque. Last edited by .:MobileLife:.; 09-19-2014 at 06:46. Reason: Wrong text. | |
09-19-2014, 07:08 | #48 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | 8GB writing problem with SDC tool? Sir, as you say use 8GB SD card I am trying to write SD card but getting error. After click yes. |
09-19-2014, 09:54 | #49 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.:MobileLife:. Hi, Use this: SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc Make sure your battery has enough POWER. Your battery should measure above 4.0 Volts on your Multimeter. That SDC File I Put in the link will work with 8GB card and it has a high bootloader version. It should work on any DEAD SM-G7102 if the problem is just software side. HOLD VOLUME DOWN + HOME BUTTON + POWER FOR 5 SECONDS TOGETHER. After 5 SECONDS, RELEASE THE POWER BUTTON and KEEP PRESSING THE VOLUME DOWN AND HOME BUTTON UNTIL YOU SEE SDC PARTITION RESTORE MENU OR DOWNLOAD MODE MENU. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
09-19-2014, 10:41 | #50 (permalink) | |
09-19-2014, 11:04 | #51 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | I've done Sd Card, Original San Disk card of 8GB, with this sdc file: SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc also to me Atf have advised of small size and asking for more big card, but anyway have write sdc file totally and w/o any "Restries", how another Verbatin card. In all case phone not vibrate, any signal of life, want to try with all sdc done and ready if not working open device and goes for .mmc tp...or have any other way?... Br allumts |
09-19-2014, 14:29 | #52 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.:MobileLife:. @allumts You need 2 people to perform the following steps below: Disassemble phone. Connect 4.30v power supply to battery terminal (DO NOT USE BATTERY) Connect USB Cable to phone port, but do not connect it to you PC PORT Yet.... Use TWEEZER and short CMD Resistor (BLUE TP). Now ask another person to press and hold both VOLUME DOWN and HOME BUTTON. So while SHORTING CMD RESISTOR + HOLD VOLUME DOWN + HOLD HOME BUTTON, now connect USB CABLE TO YOU PC. Wait for atleast 40 seconds while still SHORT CMD RESISTOR + VOLUME DOWN BUTTON + HOME BUTTON After 40 seconds, remove tweezer short, stop pressing home and volume down. Press Volume Up 1 time, and wait until you will see phone in ODIN. If this does not work for you, then it means it could be a hardware problem. DO NOT FORGET TO REMOVE SD Card Before Flashing with ODIN. Also, just flash phone with SAME VERSION as SDC File Version only!!! Even if eMMC is 100% Erased, SDC repair will still work... but of course phone will hang up in Samsung Logo after flashing, because phone will not have EFS etc... repair with other tools the EFS. B.R. |
The Following 11 Users Say Thank You to Advance-Box For This Useful Post: |
09-19-2014, 14:34 | #53 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | I almost forget... When flashing with ODIN a phone booted by SDC, you need to always include PIT File and select Re-Partition. For SM-G7102, you can use flash files in Samsung Updates | Latest News and Firmware for your Samsung Devices! ... they are complete for SM-G7102. B.R. |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
09-20-2014, 05:17 | #54 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, Here is G7102XXUBNH6 (Highest Version as of Sept-20-2014) Android 4.4.2 BOOTLOADER Version: G7102XXUBNH6 SM-G7102_4.4.2_8GB_G7102XXUBNH6.sdc This Should work on any 4.4.2 phone which was killed by downgrade. Check post #52 and #53 for more info if this SDC not automatically works on your phone. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-20-2014, 12:35 | #55 (permalink) | |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Quote:
Ture the version you said before will work also i have fixed over 50 PCS using this ... and don,t ask me for PIC | |
09-20-2014, 13:50 | #56 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2252546 Status: Offline Thanks Meter: 0 | hi thank you for every thing i do what you say step by step 8G card and not -china- my sdc that my phone dead on it when i try to dwongrade from G7102XXUBNG4 4.4.2 to 4.3 on Odin3_v3.09 but it didn,t work and still dead |
09-21-2014, 05:30 | #58 (permalink) | ||
Insane Poster Join Date: Nov 2011 Age: 42
Member: 1683660 Status: Offline Thanks Meter: 14 | Quote:
09-21-2014, 07:28 | #59 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL These new SDC files will work with 8GB card and above... 1. They are fully tested against completely erase eMMC. 2. Phone which was downgraded from 4.4.2 OTA to 4.3 via USB flashing SM-G7102_4.4.2_8GB_G7102XXUBNH6.sdc <----- This will be enough for all phones as of September 21, 2014 SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc <----- This will also work, since bootloader has same version "bits" written in efuse SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc <----- This will also work, since bootloader has same version "bits" written in efuse If you cannot make it work, please read entire thread and do not be lazy. There is no shortcut if you want to fix phone and earn Money. Everything is already inside this thread, just read and understand it. I also have full 8GB Dumps of 4.3 and 4.4.2 fully working phones, but again I will repeat that UNBRICK via SDC is enough to fix your phone. Unbrick via SDC is the FUTURE, if you do not learn how to do it now, then your shop will remain in the PAST. UNBRICK via SDC is 100% FREE for ALL ATF USERS. If until today you do not know how to use it, then it means you are losing $$$. B.R. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
09-21-2014, 09:15 | #60 (permalink) |
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | True ... Really thanks for your time telling People all of there @all X shadow is giving these free to you while some people paying money for this also the result of research for 2-3 weeks |
