09-02-2014, 10:23 | #31 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Origin: Vers. 4.3>>> G7102XXUANE2 Upgrade To Vers. 4.4.2 >> G7102XXUBNG4 Downgrade to Vers. 4.3>> G7102XXUANE2 Have tryed with Sdc create from fw SM-G7102_4.4.2_8GB_G7102XXUBNG4 V. 4.4.2 and Sdc from last India fw SM-G7102_4.4.2_8GB_G7102XXUBNH3 V.4.4.2 Boths sd card are not working, device not vibrate, no D.Mode..nothingh... @X-Shadow, want to try with eMMc direct TP, you think is more good to use the .mmc G7102XXUBNG4 or write direct last that you has uploaded the .mmc G7102XXUBNH3?? Is strange becouse also is Qualcomm how the N9005 (that had restored all with sdc) this device id totally Dead. Thanks for reply, Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
09-02-2014, 10:33 | #32 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts Hi, There are other issues involved. 1. How did customer update to 4.4.2, via OTA or via ODIN ? * If via ODIN, does he have specific FLASH FILE which he used to update to 4.4.2 ? 2. There is clearly another issue involved here, and it looks like it is not entirely about BOOT versions alone. I have some ideas now what else needs to be done, but I need some time to test it. Seems too many SM-G7102 dead phones are piling up in Samsung service centers. When I purposely killed mine via downgrade, they gave me a brand new mother board 5 days later. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
09-02-2014, 13:03 | #33 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @X-Shadow, Quote:
Customer had need to return this G7102 in Thailandia and has downgrade to original version that was in device the 4.3 G7102XXUANE2 but obvius it's dead... Yes, i have read and reported that in Samsung center are changing to many peoples directly the Pcb w/o 1€... and also at same moment, but i have reported this to my customer and him (not know Why), want test to repair this in any mode and send other time in Thailandia, it's all. What think, flash this with .mmc G7102XXUBNG4? or think that is more good Last India version G7102XXUBNG7??, Br allumts | |
09-02-2014, 17:44 | #34 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts There are currently 4 version of BOOTLOADER on SM-G7102 Kitkat 4.4.2... G7102XXUBNG4 G7102XXUBNG8 G7102XXUBNH3 G7102XWUBNH1 You can download flash files via: Firmware archive | Samsung Updates Now try first, 1 by 1 to make SDC File for each of the 4 versions... If nothing works, then that is the time you move to .mmc ... B.R. |
09-02-2014, 20:02 | #35 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok, thanks, These i've ready sdc file 4.4.2: G7102XXUBNG4 G7102XXUBNH3 These belowe want Download flash files from above link and make sdc file: G7102XXUBNG8 G7102XWUBNH1 For these last 2 above, not import Region/country or choose "THL" for boths? BR |
09-02-2014, 21:58 | #36 (permalink) | |
Insane Poster Join Date: Nov 2011 Age: 42
Member: 1683660 Status: Offline Thanks Meter: 14 | Quote:
G7102XXUBNG8 G7102XWUBNH1 | |
09-03-2014, 09:23 | #37 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @wissammic, not have need of wait me, just click in above link of "Samsung Firmware", download 4.4.2 version of G7102XXUBNG8 and G7102XWUBNH1 and from Atf Plus Tabulate>Create Immage, make sdc file for write in sd card, it's all. I've work in my shop and I do not know when I have a bit of time to create them, anyway who creates them before share it. BR Last edited by allumts; 09-03-2014 at 09:29. |
09-17-2014, 16:53 | #38 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
Sir, Samsung G7102 dead after downgrade flashing. I tried with available SDC files but not luck. I tried to create SDC file with PDA single file but software is asking pit file I searched full firmware not available anywhere. Please if have any SDC file for Indian firmware upload. This is Indian Firmware "G7102XXUBNH6" B.R. Siddeque. | |
09-18-2014, 10:25 | #39 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.:MobileLife:. Some Important Questions before you try to fix phone: 1. What is ORIGINAL FIRMWARE VERSION before phone was DOWNGRADED ? Please do not tell me 4.4.2... I need specific answer like "G7102DXUBNH1" which you can see in "Settings" ---> "About Device" 2. What FLASH FILE did you use to KILL PHONE? 3. What ODIN Version did you use to KILL PHONE? So also for additional INFO... 1. For SM-G7102, you must ONLY USE 8GB SD card for SDC Repair If you use 2 GB SD Card... it will not work If you use 4 GB SD Card... it will not work If you use 16 GB SD Card... it will not work If you use 32 GB SD Card... it will not work etc... SO you understand what I am saying here? I have SM-G7102 phone with me now and I found out that this phone is very easy to repair if only end users will follow instructions about how to repair phone. 90% of the time, they do not follow instructions. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
09-18-2014, 11:08 | #40 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @X-Shadov, i've created all Sdc file from all 4 Version of Bootloader, but i've write all in Sd Card of 16GB, not have used 8GB card, i've repaired N9005 Qualcomm with 16GB card and file was for 32GB but had woked w/o issue. So, you think is more good that i test with 8GB card first of open and repair with .mmc file? Br allumts |
09-18-2014, 11:23 | #41 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
PIT G7102_MS013G_EUR_OPEN_8G Br allumts | |
09-18-2014, 11:33 | #42 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts Yes, you should try a BRANDED 8GB Memory Card (NOT CHINA CLONE BRANDLESS). Like San.Disk, or Samsung should be OK. Download this SDC file which allows you to write to 8GB card: SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc I tested this FILE on my SM-G7102 which I purposedly killed via DOWNGRADE from 4.4.2 to 4.3 ... After phone enter DOWNLOAD MODE (VOLUME DOWN + HOME + POWER) click VOLUME UP to proceed, then remove SD CARD from phone. This is very important STEP to remove SD Card from phone... *** IF YOU DO NOT REMOVE SD CARD FROM PHONE, YOUR PHONE WILL STILL BE DEAD AFTER FLASHING *** SO maybe you ask me, how will I remove SD CARD from phone without removing battery???? Brother, try it first by yourself before you ask questions )) You will see that you can remove it easily without removing battery... So flash phone with G7102XXUBNG8 firmware and make sure you also select PIT File and put a Check on "Re-Partition" on ODIN v3.09 Today, maybe I will make full tutorial for this... Also, we can do eMMC repair using just 4 wires and no power supply needed... but we don't really need this, SDC is enough to repair this phone. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-18-2014, 11:41 | #43 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Flashing Phone after getting Download Mode from SDC: Phone alive after flashing (because SD card was removed before flashing) |
09-18-2014, 11:50 | #44 (permalink) | |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Quote:
Hello X Shadow well i have spent 2 weeks researching this issue and finally fix all this Damn G7102 issues really thanks for your time helping customers . anyway you help me on sonork first time i face this (if you remember ) 1. 16 GB card works fine (glass 10) 2. All G7102 phones works fine with me with this (creats SDC card from This )G7102XXUBNH3_G7102ODDBNG7_G7102DDUBNG1_HOME.tar 3. if card not work direct must do as i say exactly (Step By Step) open phone board and connect it to power supply press on CMD shown in X-shado pic then put card inside phone .. after this phone should works fine. | |
09-18-2014, 15:13 | #45 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Some new files for SM-G7102 uploaded at ATFSupport.com http://forum.gsmhosting.com/vbb/10564381-post6.html SM-G7102XXUANE2_4.3_8GB.sdc SM-G7102XXUBNG8_4.4.2_8GB.sdc SM-G7102XXUBNH3_4.4.2_8GB.sdc SM-G7102XXUBNH4_4.4.2_8GB.sdc SM-G7102XXUBNH6_4.4.2_8GB.sdc BR |
