Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-18-2014, 16:09   #46 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@X-Shadow,
I've just make these Sdc file from these 4 Firmware how you had wrote to me:
G7102XXUBNG4
G7102XXUBNG8
G7102XXUBNH3
G7102XWUBNH1
Have used "Verbatin" Card but of 16GB, and for the be onest i have tried only BNG4 and BNH3 becouse was out of my city, but now i've buyed all size of "San Disk" Card.
No..ahah impossible i ask you how remove Sd Card with Battery, Sd Card can remove w/o problem with battery, is more high of this.
This is Qualcomm platform and i think haven't need also Jig, N9005 repaired i've insert Sd Card then device vibrate and goes in D.Mode only with Power Button, after this flashad with odin 4 files +Pit, solved.
Now i want apply over this phone and fault to me only SMG7102XXUBNH6_4.4.2_8GB.sdc but have seen Angel has posted also this.
Time...time fault but now is arrived the time for repair this G7102, always thanks for you Tips,
allumts
Old 09-19-2014, 06:42   #47 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Originally Posted by Advance-Box View Post
@.:MobileLife:.
Some Important Questions before you try to fix phone:
1. What is ORIGINAL FIRMWARE VERSION before phone was DOWNGRADED ?
Please do not tell me 4.4.2... I need specific answer like "G7102DXUBNH1" which you can see in "Settings" ---> "About Device"
2. What FLASH FILE did you use to KILL PHONE?
3. What ODIN Version did you use to KILL PHONE?
So also for additional INFO...
1. For SM-G7102, you must ONLY USE 8GB SD card for SDC Repair
If you use 2 GB SD Card... it will not work
If you use 4 GB SD Card... it will not work
If you use 16 GB SD Card... it will not work
If you use 32 GB SD Card... it will not work
etc...
SO you understand what I am saying here?
I have SM-G7102 phone with me now and I found out that this phone is very easy to repair if only end users will follow instructions about how to repair phone. 90% of the time, they do not follow instructions.
First I am trying with 16GB SD card as ATF software asking.
Customer bought phone with hang on Samsung Logo I flashed with this file "G7102XXUBNG4_G7102ODDBNG4_INU" Odin3 v3.07.
My phone Kill by SPT box with file version 4.3 "G7102XXUAML7" .
I think my fault is 16GB SD card now I will try with 8GB sd and post reuslt.
With Best Regards.
Siddeque.
Old 09-19-2014, 07:08   #48 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
8GB writing problem with SDC tool?
Sir, as you say use 8GB SD card I am trying to write SD card but getting error.
After click yes.
Old 09-19-2014, 09:54   #49 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@.:MobileLife:.
Hi,
Use this:
SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc
Make sure your battery has enough POWER.
Your battery should measure above 4.0 Volts on your Multimeter.
That SDC File I Put in the link will work with 8GB card and it has a high bootloader version. It should work on any DEAD SM-G7102 if the problem is just software side.
HOLD VOLUME DOWN + HOME BUTTON + POWER FOR 5 SECONDS TOGETHER.
After 5 SECONDS, RELEASE THE POWER BUTTON and KEEP PRESSING THE VOLUME DOWN AND HOME BUTTON UNTIL YOU SEE SDC PARTITION RESTORE MENU OR DOWNLOAD MODE MENU.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-19-2014, 10:41   #50 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
@.:MobileLife:.
Hi,
Use this:
No luck may be my problem turn towards Hardware side because yesterday I tried in emmc tool with self made adopter.
Old 09-19-2014, 11:04   #51 (permalink)
allumts's Avatar
Member: 1564612
I've done Sd Card, Original San Disk card of 8GB, with this sdc file: SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc also to me Atf have advised of small size and asking for more big card, but anyway have write sdc file totally and w/o any "Restries", how another Verbatin card.
In all case phone not vibrate, any signal of life, want to try with all sdc done and ready if not working open device and goes for .mmc tp...or have any other way?...
allumts
Old 09-19-2014, 14:29   #52 (permalink)
Member: 651945
@.:MobileLife:.
@allumts
You need 2 people to perform the following steps below:
Disassemble phone.
Connect 4.30v power supply to battery terminal (DO NOT USE BATTERY)
Connect USB Cable to phone port, but do not connect it to you PC PORT Yet....
Use TWEEZER and short CMD Resistor (BLUE TP).
Now ask another person to press and hold both VOLUME DOWN and HOME BUTTON.
So while SHORTING CMD RESISTOR + HOLD VOLUME DOWN + HOLD HOME BUTTON, now connect USB CABLE TO YOU PC.
Wait for atleast 40 seconds while still
SHORT CMD RESISTOR
VOLUME DOWN BUTTON
HOME BUTTON
After 40 seconds, remove tweezer short, stop pressing home and volume down.
Press Volume Up 1 time, and wait until you will see phone in ODIN.
If this does not work for you, then it means it could be a hardware problem.
DO NOT FORGET TO REMOVE SD Card Before Flashing with ODIN.
Also, just flash phone with SAME VERSION as SDC File Version only!!!
Even if eMMC is 100% Erased, SDC repair will still work... but of course phone will hang up in Samsung Logo after flashing, because phone will not have EFS etc... repair with other tools the EFS.
B.R.
The Following 11 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-19-2014, 14:34   #53 (permalink)
Member: 651945
I almost forget...
When flashing with ODIN a phone booted by SDC, you need to always include PIT File and select Re-Partition.
For SM-G7102, you can use flash files in Samsung Updates | Latest News and Firmware for your Samsung Devices! ... they are complete for SM-G7102.
B.R.
The Following 4 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-20-2014, 05:17   #54 (permalink)
Member: 651945
Hi,
Here is G7102XXUBNH6 (Highest Version as of Sept-20-2014)
Android 4.4.2
BOOTLOADER Version: G7102XXUBNH6
SM-G7102_4.4.2_8GB_G7102XXUBNH6.sdc
This Should work on any 4.4.2 phone which was killed by downgrade.
Check post #52 and #53 for more info if this SDC not automatically works on your phone.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-20-2014, 12:35   #55 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 14,047
Hi,
Android 4.4.2
Ture the version you said before will work also
i have fixed over 50 PCS using this ... and don,t ask me for PIC
Old 09-20-2014, 13:50   #56 (permalink)
Member: 2252546
hi
thank you for every thing
i do what you say step by step
8G card and not -china-
my sdc that my phone dead on it when i try to dwongrade
from G7102XXUBNG4 4.4.2 to 4.3 on Odin3_v3.09
but it didn,t work and still dead
Old 09-20-2014, 14:07   #57 (permalink)
Member: 2252546
and i try to writ this sdc SM-G7102_4.4.2_8GB_G7102XXUBNG4
on my 8G card but it not done
the box say no space it need 16G card
so what can we do
Old 09-21-2014, 05:30   #58 (permalink)
Member: 1683660
Thanks Meter: 14
so what can we do
Try this has been successfully written by me
Hi,
Android 4.4.2
Old 09-21-2014, 07:28   #59 (permalink)
Member: 651945
@ALL
These new SDC files will work with 8GB card and above...
1. They are fully tested against completely erase eMMC.
2. Phone which was downgraded from 4.4.2 OTA to 4.3 via USB flashing
SM-G7102_4.4.2_8GB_G7102XXUBNH6.sdc <----- This will be enough for all phones as of September 21, 2014
SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc <----- This will also work, since bootloader has same version "bits" written in efuse
SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc <----- This will also work, since bootloader has same version "bits" written in efuse
If you cannot make it work, please read entire thread and do not be lazy. There is no shortcut if you want to fix phone and earn Money. Everything is already inside this thread, just read and understand it.
I also have full 8GB Dumps of 4.3 and 4.4.2 fully working phones, but again I will repeat that UNBRICK via SDC is enough to fix your phone. Unbrick via SDC is the FUTURE, if you do not learn how to do it now, then your shop will remain in the PAST.
UNBRICK via SDC is 100% FREE for ALL ATF USERS.
If until today you do not know how to use it, then it means you are losing $$$.
B.R.
The Following 3 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-21-2014, 09:15   #60 (permalink)
Member: 95960
Sonork: 100.1574721
True ... Really thanks for your time telling People all of there
@all X shadow is giving these free to you while some people paying money for this also the result of research for 2-3 weeks
Page generated in 0.21846 seconds with 9 queries
