Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-25-2014, 12:37   #1 (permalink)
Member: 1870916
Sonork: amakid
Thanks Meter: 3
pls help my nokia 105 unable to flash with ATF box written image file block
pls help my nokia 105 unable to flash with ATF box written image file block any solution pls.......... tnx in advance
Old 03-25-2014, 13:14   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Post error log or screenshot . Probably flash file problem
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-26-2014, 10:55   #3 (permalink)
Member: 1870916
Sonork: amakid
Thanks Meter: 3
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Spansion Electronics Corp.
Flash Chip Type: 64 Mbit (4Mb x 16) NOR
Extended Information: Mirrorbit / Multi-Bank / 1.8v
Processing Image File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-908\rm908_004.350
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00000000~0x0001FFFE
ERROR: Erase IMAGE Block Failed !!!
Flashing ERROR
Old 03-28-2014, 08:53   #4 (permalink)
Member: 1870916
Sonork: amakid
Thanks Meter: 3
friends any solution??????????????????????
Page generated in 0.13399 seconds with 8 queries
