04-17-2014, 09:39 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: <INDIA> % <CHINA>
Member: 1359320 Status: Offline Sonork: 100.1620477 Thanks Meter: 79 | Plz help atf team strange problem Asha 305 asha 305 contact service log :- Booting Phone via USB... ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 42500811A7032828 Original Product Code: 059Q5G3 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_15901.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_CERTIFICATE_12993D55.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355213051914885\3552130519148 85_PMM_PROT_AE148545.bin Security Code: 12345 Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 07.42 07-05-13 RM-766 (c) Nokia IMEI Plain : 355213051914885 IMEI Spare : A355213051914880 IMEI SV : 33552130519148840F IMEI (2nd) : 355213051914893 IMEI Spare : A355213051914890 IMEI SV : 33552130519148940F Phone Model: Nokia 305 Category : Classic Phone Phone Type : RM-766 ================================================ Extended Phone Information ================================================ Product Serial Number: A48495DAH Product Code : 059Q5G3 Module Code : 0204884 Basic Production Code: 059K4Q4 Long Production SN : 0 PPM SW Version : V 07.42 07-05-13 RM-766 (c) Nokia MH BT MCM Version : 19b5-22012 MCU SW Version : V 07.42 07-05-13 RM-766 (c) Nokia HW Version : 1000 RFIC Version : Dummy RFIC version LCD Version : TPO Content Pack Version : Content: mh_059K9H4 V 07.42 07-05-13 RM-766 (c) Nokia AHNE Version : 11 Bluetooth ID : B0:35:8D:4F:2E:AC CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000030000 ASIC : 11 PROVIDER : Unknown Provider LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 115B6002 DCC Ver: 004020 Status : OK ================================================== ==== Selected VPL File: RM766_059P553_07.42_049.vpl ================================================== ==== Variant Details : RM-766 VAR INDIA-MH IN CV DGREY Software Version : 07.42 Product Type : RM-766 Product Code : 059P553 Variant Version : 049 ================================================== ==== Selected VPL File: RM766_059Q5G3_07.42_016.vpl ================================================== ==== Variant Details : RM-766 VAR INDIA-MH IN CV SWHITE Software Version : 07.42 Product Type : RM-766 Product Code : 059Q5G3 Variant Version : 016 |
04-17-2014, 10:45 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @>Amit< What was the problem in phone that you flashed it? If it was already in Contact Service problem, and you don't have proper backup, then only Nokia RPL will solve this problem. BR |
04-17-2014, 10:55 | #3 (permalink) |
Member: 1359320 Status: Offline Sonork: 100.1620477 Thanks Meter: 79 | the hanset was in contact service costomer ask me that so code is ask in the handset a saw it was restricted code after opening the sim i saw its contact service so i flashed and same and same |
04-17-2014, 11:14 | #4 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | If I understand you post correct: It was already in contact service? If so, then return it back to customer, as there is no solution for it except you buy RPL file. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
