Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 10-25-2014, 16:14   #1 (permalink)
Member: 2280006
Thanks Meter: 15
plz help i need file pm for nokia 808 rm-807
scan phone
MCU Version: V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia
IMEI Plain : 351965051133626
IMEI Spare : A351965051133620
IMEI SV : 33519650511336232F
Phone Model: Nokia 808 PureView
Category : Classic Phone
Phone Type : RM-807
Extended Phone Information
Product Serial Number: C7G826477
Product Code : 059M7N0
Basic Production Code: 059M5B9
Long Production SN : 0
MCU SW Version : V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia
HW Version : 4010
RFIC Version : |Alli_4.b.1
DSP Version : 79u_sr2_12w20_2
APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3696.
AHNE Version : 21
APE SW Core Version : 113.010.1508
Variant Version : 113.010.1508113.010.1508.01.01113.010.1508.C09.01
RETU Version : 35
TAHVO Version : 00
APE HW Version : 256
APE ADSP SW Version : 256
Wireless LAN ID : D0B:32:AD:25:30
Bluetooth ID : D0B:32:A8:43:30
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII
Simlock Information
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
SECURITY_CODE : ENCRYPTED
CMLA_KEY : ABSENT
SUPER_DONGLE_TEST : PASSED
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
PHONE_MODE : RF INACTIVE
WARNING: DCC Unavailable in Current State
Change Phone Mode to TEST MODE
scan phone pm sx4
Phone Type : RM-807
SX4 Custom Keys Stand Alone Edition
>>> : SX4 Auth Successfull
Selected PM File: D:\351965051133626\imp_351965051133626_RM-807_173718.pm
Start Uploading PM...
Field : 1 Sub : 0 Byte(s): 12 - Ok
Field : 1 Sub : 1 Byte(s): 96 - Ok
Field : 1 Sub : 2 Byte(s): 112 - Ok
Field : 1 Sub : 4 Byte(s): 12 - Ok
Field : 1 Sub : 6 Byte(s): 112 - Ok
Field : 1 Sub : 7 Byte(s): 452 - Ok
Field : 1 Sub : 8 Byte(s): 12 - Ok
Field : 1 Sub : 13 Byte(s): 112 - Ok
Field : 1 Sub : 15 Byte(s): 32 - Ok
Field : 1 Sub : 16 Byte(s): 32 - Ok
Field : 1 Sub : 17 Byte(s): 32 - Ok
Field : 1 Sub : 18 Byte(s): 32 - Ok
Field : 1 Sub : 19 Byte(s): 32 - Ok
Field : 1 Sub : 22 Byte(s): 24 - Ok
Field : 1 Sub : 26 Byte(s): 12 - Ok
Field : 1 Sub : 27 Byte(s): 36 - Ok
Field : 1 Sub : 28 Byte(s): 112 - Ok
Field : 1 Sub : 29 Byte(s): 12 - Ok
Field : 1 Sub : 30 Byte(s): 36 - Ok
Field : 1 Sub : 31 Byte(s): 24 - Ok
Field : 1 Sub : 32 Byte(s): 216 - Ok
Field : 1 Sub : 33 Byte(s): 36 - Ok
Field : 1 Sub : 35 Byte(s): 24 - Ok
Field : 1 Sub : 36 Byte(s): 24 - Ok
Field : 1 Sub : 38 Byte(s): 216 - Ok
Field : 1 Sub : 39 Byte(s): 36 - Ok
Field : 1 Sub : 40 Byte(s): 24 - Ok
Field : 1 Sub : 41 Byte(s): 216 - Ok
Field : 1 Sub : 43 Byte(s): 36 - Ok
Field : 1 Sub : 44 Byte(s): 216 - Ok
Field : 1 Sub : 45 Byte(s): 216 - Ok
Field : 4 Sub : 1 Byte(s): 200 - Ok
Field : 4 Sub : 3 Byte(s): 12 - Ok
Field : 4 Sub : 4 Byte(s): 8 - Ok
Field : 4 Sub : 5 Byte(s): 8 - Ok
Field : 4 Sub : 9 Byte(s): 8 - Ok
Field : 4 Sub : 28 Byte(s): 4 - Ok
Field : 120 Sub : 0 Byte(s): 944 - Ok
Field : 120 Sub : 1 Byte(s): 160 - Ok
Field : 120 Sub : 2 Byte(s): 132 - Ok
Field : 120 Sub : 3 Byte(s): 112 - Ok
Field : 308 Sub : 1 Super Dongle Key Found
Field : 308 Sub : 1 Write Super Dongle Key - OK
Field : 308 Sub : 1 CMLA Key Found
Field : 308 Sub : 1 Write CMLA Key - Failed
Field : 309 Sub : 0 Byte(s): 4 - Ok
Field : 309 Sub : 1 Byte(s): 4 - Ok
Field : 309 Sub : 2 Byte(s): 12 - Ok
Field : 309 Sub : 3 Byte(s): 36 - Ok
Field : 309 Sub : 4 Byte(s): 12 - Ok
Field : 309 Sub : 7 Byte(s): 12 - Ok
Field : 309 Sub : 17 Byte(s): 12 - Ok
Field : 341 Sub : 0 Byte(s): 4 - Ok
Field : 341 Sub : 3 Byte(s): 4 - Ok
Field : 341 Sub : 4 Byte(s): 4528 - Ok
Field : 341 Sub : 12 Byte(s): 328 - Ok
Field : 341 Sub : 15 Byte(s): 940 - Ok
PM Upload Done!...
Old 10-26-2014, 18:28   #2 (permalink)
Member: 2280006
Thanks Meter: 15
plzzzzz heeeelpee me
Old 11-13-2014, 18:15   #3 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
What is your situation? This problem has not yet resolved? In fact, it is easy to solve because I tried, my solution is to back up all the Certificates, and then erases and re-FLASHING, write RPL, repair super dongle, SX4 Auth, write FULL PM, writes PP completely factory settings,
Old 11-14-2014, 16:32   #4 (permalink)
LOKEMUNFU's Avatar
Member: 2100013
Thanks Meter: 125
WARNING! ! Now absolutely beyond repair£¡£¡
NOKIA 808_RM-807 PureView ASHA 311_RM-714
ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A
Not ERASE! Otherwise, data can not be repaired!
Old 12-07-2014, 13:45   #5 (permalink)
Member: 1012044
Sonork: 100:1668956
Thanks Meter: 131
Thumbs up plz help................
nokia 808 full pm file
Page generated in 0.16888 seconds with 8 queries
