03-26-2014, 12:55 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: gujrat pakistan
Member: 1462894 Status: Offline Sonork: 100.1609879 Thanks Meter: 47 | plzzzz help me c5-00 its sl data is corupted and i want to recover from flash dump or any other method plzzzzz guid me |
03-26-2014, 13:25 | #3 (permalink) | |
Member: 1462894 Status: Offline Sonork: 100.1609879 Thanks Meter: 47 | i try but nothing Quote:
FlashInfo.RestartMode : Test Mode ================================================== ===== ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: Searching for Simlock Table... STATUS: Simlock Table FOUND! STATUS: Simlock Signature FOUND! REPORT: Simlock Hashes was NOT FOUND! REPORT: Simlock Recovery FAILED! REPORT: Try Level 2 or Level 3 Recovery REPORT: Total Elapsed Time 00:00:45 | |
03-26-2014, 14:22 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @pakistan786 You need to make LEVEL 2 From PHONE Recovery and NOT via Full Dump. If you already erased and flashed the phone, then no solution to get simlock back. Only Nokia RPL file. BR |
03-27-2014, 08:49 | #5 (permalink) | |
Freak Poster Join Date: Oct 2009 Location: India Age: 33
Member: 1140128 Status: Offline Sonork: 100.1649199 Thanks Meter: 2 | Quote:
same problem here i have rpl backp and i already erased and flashed the phone now unable to read sp data need help... | |
