09-14-2011, 17:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | problem while flashing nokia 5130c... ATF Software Version v7.77 ATF Lightning FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Programmi\Cyclone Box\ciaoa\rm495__07.90.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 25D00118 ID DWORD 1 : 6B9D7D56 ID DWORD 2 : 979E3916 ID DWORD 3 : 305FD038 ID DWORD 4 : 2CECA461 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 84 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VARIANT ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 Certificate 4 Name : CCC ASIC Index : CMT 0 Certificate 5 Name : HWC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x36 (54) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00.00.00 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.90.mcusw Total blocks to write : 1178 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ================================================ INFO: RX2 PIN is OK ================================================ >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 01 Error Spec : 06 Of*****ng Address : 00040000 Expected Content : 00000000 Detected Content : 00000000 Try to change the Flashing clock... Flashing FAILED BB5_WRITE_FlashFile_0 Go to Settings --> Nokia Settings --> FBUS DDR&2TX Synchronization Timeout Change the current value selected to a higher value and Restart AdvanceBox.exe software to apply it Operations Failed.... im using cyclone flash files,what am i supposed to do now to make it work? thanks a lot in advance P.S: i obviously already set the value to the highest value,so now whats next? Last edited by SicilianBoy; 09-14-2011 at 17:50. |
09-15-2011, 21:34 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
It looks like cable problem... If you are sure about cable that is fine,, maybe it not attached well with phone, you may put some rubber bands on it. after flash again - all will be OK BR | |
