08-26-2012, 15:57 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | possible to erase the infinion x2-02 and flash? Is it possible to erase and flash the infinion x2-02....means ..Is it supported..? If yes the pleas give me any steps thanks. |
08-27-2012, 07:09 | #3 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Then I full flash the phone....but now phone is on but no signal .... also when I go to camara...phone restart I flash the set 4 times...but same... thanks. | |
08-27-2012, 10:42 | #6 (permalink) |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Log Number of Image Files: 3 Processing Image File : rm694__11.63.mcusw Processing Image File : rm694__11.63.ppm_ea Processing Image File : rm694__11.63.image_ea_059D1V4 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Sections : 04 Current File : rm694__11.63.mcusw Compile Name: rm694__11.63.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27528584 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 04 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CCF5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 04 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ACE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 04 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: C2AC Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 04 FIRMWARE Erase Block: 0x40280000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 26214400 bytes Data Checksum: 8013 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm694__11.63.ppm_ea Compile Name: package_ea.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5165008 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41C00000~0x422FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5161664 bytes Data Checksum: F796 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm694__11.63.image_ea_059D1V4 Compile Name: package_ea_059D1V4.image.fls Image Type : CONTENT Package Data Size : 14290192 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x42300000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14286848 bytes Data Checksum: 5AAB Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:08:26 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 11.63 29-05-12 RM-694 (c) Nokia IMEI Plain : 3524******* IMEI Spare : A352********* IMEI SV : 3352********* Phone Model: K X2-02 Category : Entry Phone Type : RM-694 ================================================ Extended Phone Information ================================================ Product Serial Number: 8696275AH Product Code : 059D1V4 Module Code : 0204922 Basic Production Code: 059C943 Long Production SN : 0 PPM SW Version : V 11.63 29-05-12 RM-694 (c) Nokia EA BT MCM Version : 19e2-47026 MCU SW Version : V 11.63 29-05-12 RM-694 (c) Nokia HW Version : 1000 RFIC Version : Dummy RFIC version LCD Version : TPO FWID Version : jV 11.63 29-05-12 RM-694 (c) Nokia V 11.63 29-05-12 RM-694 (c) Nokia EA 059D1V4 001 Content Pack Version : Content: ea_059D1V4 V 11.63 29-05-12 RM-694 (c) Nokia Bluetooth ID : 50:2D:1D:72:17:A4 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================== ==== Selected VPL File: RM694_059D1V4_11.63_032.vpl ================================================== ==== Variant Details : RM-694 SEAP_EA_DSILVER_LATIN_LK Software Version : 11.63 Product Type : RM-694 Product Code : 059D1V4 Variant Version : 032 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Thanks. |
08-27-2012, 14:43 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @sky_finder Try to flash phone with other firmwares, lower/higher doesn't matter for this phone.. Flashing cannot make phone "no signal and camera" problem, its hardware issue. BR |
08-27-2012, 16:15 | #10 (permalink) | |
Phone is came to my shop for only security code. Before the phone work perfectly With signal is ok.But for camera I did not check. Also if I downgrade the phone then...Are you sure that No imei damaged? No sim lock damaged.? Thanks. | |
08-27-2012, 16:28 | #11 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Yes, there is no downgrade prevention in those XGOLD phones. All you need do is simple flashing with selected lower version files. BR | |
08-29-2012, 17:13 | #12 (permalink) | |
I upload the screen capture to see the self test.Could you please check this and tell me? x2-02 clip.avi - 4shared.com - file sharing - download movie file Thanks. | |
08-31-2012, 14:48 | #15 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Please upload screen shot here on forum.. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
