03-04-2011, 11:53 | #1561 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | Nokia 1616-2 flashed successfully Code: [IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_004.100 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: C552 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2092160 bytes Data Checksum: DFEC Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_004.10ms PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003B2A7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1714816 bytes Data Checksum: B630 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai04.10ms CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00EF92BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 299712 bytes Data Checksum: 12DF Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:14 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 04.10 26-03-10 RH-125 (c) Nokia IMEI: 352704044614528 Mastercode : 5440060204 Product Serial Number: I8A612998 Product Code : 0595840 Module Code : 0204343 Basic Production Code: 0583104 MCU SW Version : V 04.10 26-03-10 RH-125 (c) Nokia MS ADSP Version : p V 04.10\n26-03-10\nRH-125\n(c) NMP\nms PPM Version : V 04.10 26-03-10 RH-125 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : INNO:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK Changing Phone Mode... (Wait for 5 seconds) Successfully set to : Normal |
03-04-2011, 12:07 | #1562 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | Nokia 1616-2 flashed successfully NOKIA 1616-2 FLASHED SUCCESSFULLY Code: [IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_004.100 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: C552 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2092160 bytes Data Checksum: DFEC Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_004.10ms PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003B2A7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1714816 bytes Data Checksum: B630 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai04.10ms CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00EF92BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 299712 bytes Data Checksum: 12DF Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:14 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 04.10 26-03-10 RH-125 (c) Nokia IMEI: 352704044614528 Mastercode : 5440060204 Product Serial Number: I8A612998 Product Code : 0595840 Module Code : 0204343 Basic Production Code: 0583104 MCU SW Version : V 04.10 26-03-10 RH-125 (c) Nokia MS ADSP Version : p V 04.10\n26-03-10\nRH-125\n(c) NMP\nms PPM Version : V 04.10 26-03-10 RH-125 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : INNO:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK Changing Phone Mode... (Wait for 5 seconds) Successfully set to : Normal |
03-04-2011, 13:18 | #1563 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia X3-00 Flash Done With ATF BOX Number of Image Files: 3 Processing Image File : rm540__08.54.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 136 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm540__08.54.ppm_meaa CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 22 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm540__08.54.image_meaa_0584330_006 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 56 Entry Point: 0x0154 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02054100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1DA00210 ID DWORD 1 : 16235440 ID DWORD 2 : 58942DAE ID DWORD 3 : 6534C35C ID DWORD 4 : FAF46DF1 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 START FLASHING RawLoaderExtract: Processing rm540__08.54.mcusw CMT Secondary Loader: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 354865042378438 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\354865042378438\3548650423784 38_51301.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 PAPUB Keys Hash : CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-540\ ImadeFilename: rm540__08.54.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 02720000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 02CC0000 Size : 04B00000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 077C0000 Size : 00380000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 07B40000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xE1 (225) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-000203FF 1 : 00060000-0009FFFF 2 : 000A0000-0025FFFF 3 : 003E0000-005DFFFF 4 : 005E0000-010DFFFF 5 : 01EC0000-01EDFFFF 6 : 027C0000-02CBFFFF 7 : 077C0000-07B3FFFF 8 : 010E0000-01EBFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B Successfully erased.. Total blocks to write : 136 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-540\ ImadeFilename: rm540__08.54.ppm_meaa StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01EE0000-027BFFFF ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74 Successfully erased.. Total blocks to write : 22 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-540\ ImadeFilename: rm540__08.54.image_meaa_0584330_006 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02CC0000-077BFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90 ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully erased.. Total blocks to write : 56 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:01:10 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... SW: V 08.54 25-10-10 RM-540 (c) Nokia IMEI: 354865042378438 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 85588 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
03-04-2011, 14:13 | #1564 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 2323c flashed successfully nokia 2323c flashed successfully Code: ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-512\rm512__09.55.mcusw PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 191 Entry Point: 0x00D8 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : 65 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 849B19C57B70C942F47FFE7FC8 DecodedMSID: 842C40BAE9005FE932A8000000 EncodedFAID: BE9472E3B8906C5BB4E41683 Authentication : SUCCESSFULL Erasing address: >> 01000000 : 0101FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) >> 01020000 : 01CFFFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:42 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Making delay between files for 6000ms ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-512\rm512__09.55.ppm_ssa_f PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 33 Entry Point: 0x00D4 Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : 65 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 8411465D973027EF649A3301AE DecodedMSID: 843E4EBAE9005FE932A9000000 EncodedFAID: 1A85D393B7B85D15BB40EFEF Authentication : SUCCESSFULL Erasing address: >> 01D00000 : 0217FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:06 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Making delay between files for 6000ms ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-512\rm512__09.55.image_ssa_f_brown PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 3160 > 3161 > 3162 > 3164 > 3166 > 3168 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 224 Entry Point: 0x00DF Is128k: True Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0089 - INTEL DevId0 : 8981 - NU48F256 ExtId0 : 0000 RevId0 : 9221 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0089 - INTEL DevId1 : 8981 - NU48F256 ExtId1 : 0000 RevId1 : 9221 SectorSize1: 11 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : 65 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 8477B17B27CC5FB01BCA6C2FCE DecodedMSID: 84D26EBAF1005FE932AA000610 EncodedFAID: BA0AE6EC1B8F48D71FEA55BA Authentication : SUCCESSFULL Erasing address: >> 02180000 : 02E7FFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) >> 02E80000 : 02FBFFFF BB_PROGRAMMING_STATUS_REQUEST : 04 FF ProgrammingStatus_DCT4 : No Error - 0 (0x00) Erasing Done Flashing ImageFile ContinueFlash_DCT4 Complete Write Time Elapse : 00:00:17 FLASH Mode Set to : PHONEMODE_FLASHBUS ProgrammingStatus_DCT4 BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status First Byte OK Second Byte OK BB_PERM_DATA_RESTORE_REQ : 18 FF BB_RESTART : 07 FF MCURestart : SUCCESS Time Elapse : 00:04:34 Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 09.55 12-11-09 RM-512 (c) Nokia IMEI: 355248030219394 Model : Nokia 2330c-2 Mastercode : 3535643662 Product Serial Number: IQE926550 Product Code : 0584547 Module Code : 0204048 Basic Production Code: 0569925 Default SN Type : 0 MCU SW Version : V 09.55 12-11-09 RM-512 (c) Nokia SSA BT MCM Version : 2222-302 PPM Version : V 09.55 12-11-09 RM-512 (c) Nokia HW Version : 2000 UEM Version : 4386 UPP Version : 12648 RFIC Version : 0500 DSP Version : ICPR72_09w39_U LCD Version : SUEZ Content Pack Version : Content: ssa_f_brown V 09.55 12-11-09 RM-512 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D101260C213402 DCC Ver: 001008 Status : OK Quick RPL DATA1 Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355248030219394\355248030219394_BACKUP.RPL FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK Changing Phone Mode... (Wait for 5 seconds) Successfully set to : Normal |
03-04-2011, 14:32 | #1565 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | NOKIA e-75 FLASHED SUCCESSFULLY NOKIA e-75 FLASHED SUCCESSFULLY Code: ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110628 (0xE4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01031103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 10000112 ID DWORD 1 : 79790052 ID DWORD 2 : CBD7431D ID DWORD 3 : 49B6C511 ID DWORD 4 : E4AD57EB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum B5 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C29DF97EC55AABC28ACB9029D2E577CA237E7179 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 02DE0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02E60000 Size : 07120000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 09F80000 Size : 057A0000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F8C0000 Size : 00160000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF0000000400000003000000020008000002DE0000000000040000000202E6000007120000000000080000000109F80000057A00000000000A000000010F8C00000016000043 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-003FFFFF 2 : 00800000-00D5FFFF 3 : 00D60000-09F7FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 000000000000000A0000000000000002000000640000000300000001000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:01 Flashing Speed: 5.00 Mhz Processing : rm412_2111201_prd.c00 Total blocks to write : 430 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:56 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-412\rm412_2111201_prd_prdapps.rofs3.v35 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 36 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 No partition info.... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 08B80000-09F7FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz Processing : rm412_2111201_prd_prdapps.rofs3.v35 Total blocks to write : 36 >> CMT Rootkey Hash CERT : SOS+ROFS3 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:05 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-412\rm412_2111201_prd_prdapps.rofs2.v35 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 52 Entry Point: 0x00FF Page Format : -1 MAX PAGE : 0x00040000 No partition info.... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 07200000-08B7FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz Processing : rm412_2111201_prd_prdapps.rofs2.v35 Total blocks to write : 52 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:07 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-412\rm412_2111201.11U CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 72 Entry Point: 0x00F9 Page Format : -1 MAX PAGE : 0x00040000 No partition info.... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09F80000-0F71FFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz Processing : rm412_2111201.11U Total blocks to write : 72 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:11 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-412\RM412_ENO_A_2009wk42v0.031.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 14 Entry Point: 0x0138 Page Format : -1 MAX PAGE : 0x00040000 No partition info.... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz Processing : RM412_ENO_A_2009wk42v0.031.fpsx Total blocks to write : 14 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000002 Additional Bad : 00000002 Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:02 Total Flash Write Time (Flashing Only) : 00:01:22 Total Flashing Time (Booting + Erase + Flashing) : 00:01:24 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V ICPR72_10w04.vic02 18-06-10 RM-412 (c) Nokia IMEI: 356855020616444 Model : Nokia E75 Product Serial Number: CNJ896253 Product Code : 0570134 Basic Production Code: 0558819 Default SN Type : 0 PPM Version : V ICPR72_10w04.vic02 18-06-10 RM-412 (c) Nokia HW Version : 0500 RFIC Version : |Vapaus_4.0 | Aura_?.? DSP Version : ICPR72_10w01 Content Pack Version : 211.12.01 AHNE Version : 11 APE SW Core Version : 211.12.01 APE Variant Version : 211.12.01_rofs2211.12.01_rofs3 APE Test Version : RM412ENOx0942v0.031 Retu Version : 15 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
03-04-2011, 14:51 | #1566 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia 2690 Flash Done With ATF BOX Number of Image Files: 3 Processing Image File : rm635__10.10.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1165 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm635__10.10.ppm_m_c CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 198 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm635__10.10.image_m_c_black CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 408 Entry Point: 0x00C8 Page Format : -1 MAX PAGE : 0x00004000 []: Found 1 active devices. [Nokia 2690 USB Phonet]: Opening Connection [Nokia 2690 USB Phonet]: Port opened OK! SW: V 10.10 22-04-10 RM-635 (c) Nokia IMEI: 353411043417106 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\353411043417106\USB_FULL_BACK UP_V 10.10 22-04-10 RM-635 (c) Nokia_353411043417106_Not Locked_63204.pm Reading battery value : 3823 mV IMEI : 353411043417106 CMT_RAP_PUBLIC_ID : 1960020644360156AE47E7DBA11A4245E6EE9849 CMT_ROOT_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_PAPUB_Keys_Hash : C6B9354E81AC464DED33FC7B90295086150F4539 START FLASHING UpdateAgentDataExtract: Processing rm635__10.10.mcusw UpdateAgentDataExtract: Found matching Rootkey Hash CERT Block UpdateAgentDataExtract: Found DATA Block UpdateAgentDataExtract: Consolidating DATA Blocks PASUBTOCCertExtract: Processing rm635__10.10.mcusw PASUBTOCCertExtract: Found matching Rootkey Hash CERT Block Update Agent Sent.. Waiting for phone to ADL ... (Make take a while) Found Nokia BB5 ADL Loader USB Generic.. EraseFile: Processing rm635__10.10.mcusw Erasing area 0x00000000 - 0x000006BF, Type: NOR, Subsystem: CMT Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR, Subsystem: CMT Erasing area 0x00040000 - 0x000BFFFF, Type: NOR, Subsystem: CMT Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR, Subsystem: CMT Erasing area 0x00140000 - 0x0137FFFF, Type: NOR, Subsystem: CMT Erasing area 0x01380000 - 0x0151FFFF, Type: NOR, Subsystem: CMT Processing : rm635__10.10.mcusw Total blocks to write : 1165 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Continue Flash Complete : : No Error - 0 (0x00) EraseFile: Processing rm635__10.10.ppm_m_c Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR, Subsystem: CMT Processing : rm635__10.10.ppm_m_c Total blocks to write : 198 Continue Flash Complete : : No Error - 0 (0x00) EraseFile: Processing rm635__10.10.image_m_c_black Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR, Subsystem: CMT Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR, Subsystem: CMT Processing : rm635__10.10.image_m_c_black Total blocks to write : 408 Continue Flash Complete : : No Error - 0 (0x00) Flashing Done.. Total Flashing Time (Erase + Flashing) : 00:15:33 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... Elapsed Time: 25 Seconds... SW: V 10.10 22-04-10 RM-635 (c) Nokia IMEI: 353411043417106 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 12345 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
03-05-2011, 11:10 | #1567 (permalink) |
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 5130c flashed successfully nokia 5130c flashed successfully Code: ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110596 (0xC4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27100113 ID DWORD 1 : 6B8C7D56 ID DWORD 2 : 0D551382 ID DWORD 3 : 167A468C ID DWORD 4 : E8009D1A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 98 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354179030882736\354179030882736_31801.rpl FlashInfo.RestartMode : 2 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110628 (0xE4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27100113 ID DWORD 1 : 6B8C7D56 ID DWORD 2 : 0D551382 ID DWORD 3 : 167A468C ID DWORD 4 : E8009D1A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 98 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VAR ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 Certificate 4 Name : CCC ASIC Index : CMT 0 Certificate 5 Name : HWC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x36 (54) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0137FFFF 5 : 01380000-0151FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:37 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.mcusw Total blocks to write : 1178 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:49 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_mh CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 450 Entry Point: 0x00BE Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01DBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:38 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.ppm_mh Total blocks to write : 450 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:17 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_CTV_INDIA_HINDI_red CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 536 Entry Point: 0x00D0 Page Format : -1 MAX PAGE : 0x00004000 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01DC0000-0215FFFF 1 : 02160000-03FBFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:03:58 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm495__07.97.image_CTV_INDIA_HINDI_red Total blocks to write : 536 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:20 Total Flash Write Time (Flashing Only) : 00:01:26 Total Flashing Time (Booting + Erase + Flashing) : 00:07:41 FlashInfo.RestartMode : 2 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 354179030882736 Model : Nokia 5130c-2 Product Serial Number: IIN356118 Product Code : 0583448 Module Code : 0204024 Basic Production Code: 0567772 Default SN Type : 0 MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MH BT MCM Version : 2222-302 PPM Version : V 07.97 13-09-10 RM-495 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_10w01 LCD Version : SHARP Content Pack Version : Content: ctv_india V 07.97 13-09-10 RM-495 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK Changing Phone Mode... (Wait for 5 seconds) Successfully set to : Normal |
03-05-2011, 14:19 | #1569 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia 5130c Flash Done With ATF BOX Number of Image Files: 3 Processing Image File : rm495__07.95.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1178 Entry Point: 0x5057 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm495__07.95.ppm_mena_b CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 404 Entry Point: 0x00BE Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm495__07.95.image_mena_b_blu CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 528 Entry Point: 0x00D0 Page Format : -1 MAX PAGE : 0x00004000 []: Found 1 active devices. [Nokia 5130 XPressMusic USB Phonet]: Opening Connection [Nokia 5130 XPressMusic USB Phonet]: Port opened OK! SW: V 06.65 01-04-09 RM-495 (c) Nokia IMEI: 356040037221377 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\356040037221377\USB_FULL_BACK UP_V 06.65 01-04-09 RM-495 (c) Nokia_356040037221377_Not Locked_60159.pm Reading battery value : 4018 mV IMEI : 356040037221377 CMT_RAP_PUBLIC_ID : 091001079E397F56E2F5B29F613BF5491F2E6BEE CMT_ROOT_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_PAPUB_Keys_Hash : 0C917F11196FDB7378C18EF7260698CA4489DCA0 START FLASHING UpdateAgentDataExtract: Processing rm495__07.95.mcusw UpdateAgentDataExtract: Found matching Rootkey Hash CERT Block UpdateAgentDataExtract: Found DATA Block UpdateAgentDataExtract: Consolidating DATA Blocks PASUBTOCCertExtract: Processing rm495__07.95.mcusw PASUBTOCCertExtract: Found matching Rootkey Hash CERT Block Update Agent Sent.. Waiting for phone to ADL ... (Make take a while) Found Nokia BB5 ADL Loader USB Generic.. EraseFile: Processing rm495__07.95.mcusw Erasing area 0x00000000 - 0x000006BF, Type: NOR, Subsystem: CMT Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR, Subsystem: CMT Erasing area 0x00040000 - 0x000BFFFF, Type: NOR, Subsystem: CMT Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR, Subsystem: CMT Erasing area 0x00140000 - 0x0137FFFF, Type: NOR, Subsystem: CMT Erasing area 0x01380000 - 0x0151FFFF, Type: NOR, Subsystem: CMT Processing : rm495__07.95.mcusw Total blocks to write : 1178 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW Continue Flash Complete : : No Error - 0 (0x00) EraseFile: Processing rm495__07.95.ppm_mena_b Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR, Subsystem: CMT Processing : rm495__07.95.ppm_mena_b Total blocks to write : 404 Continue Flash Complete : : No Error - 0 (0x00) EraseFile: Processing rm495__07.95.image_mena_b_blu Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR, Subsystem: CMT Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR, Subsystem: CMT Processing : rm495__07.95.image_mena_b_blu Total blocks to write : 528 Continue Flash Complete : : No Error - 0 (0x00) Flashing Done.. Total Flashing Time (Erase + Flashing) : 00:13:12 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... Elapsed Time: 25 Seconds... SW: V 07.95 03-02-10 RM-495 (c) Nokia IMEI: 356040037221377 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
03-05-2011, 16:44 | #1570 (permalink) |
Insane Poster Join Date: Nov 2010
Member: 1434222 Status: Offline Thanks Meter: 21 | 2220S unlock Ok.. Code: Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 31 lsbUPP_ID : 68 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 03 NumFlash : 02 DevAddr0 : 01 ManuId0 : 0020 - ST DevId0 : 883C - Type not in database ExtId0 : 0000 RevId0 : 9321 SectorSize0: 11 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00 CheckSum : 69 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_intel.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 8487353C014F44A4AC8607618E DecodedMSID: 84CDF1BAEF0043D547AA00024D EncodedFAID: CFB172DE8942EF705BE5299F Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 09.55 12-11-09 RM-590 (c) Nokia IMEI: 355371048......... Model : Nokia 2220s Mastercode : 0345226145 Product Serial Number: HVA956628 Product Code : 059C0Q4 Module Code : 0204340 Basic Production Code: 0582851 Default SN Type : 0 MCU SW Version : V 09.55 12-11-09 RM-590 (c) Nokia T Content Pack Version : Content: vodafone AU V 09.55 12-11-09 RM-590 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 5050300014981890 PROFILE_BITS : 800000000003000B Asic : 11 Provider : Vodafone;Australia Unable to completely read SL Table.. ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D1012601022E05 DCC Ver: 001007 Status : OK Quick RPL DATA1 Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355371048743179\355371048743179_BACKUP.RPL Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... MCU: V 09.55 12-11-09 RM-590 (c) Nokia IMEI: 3553710............ Model : Nokia 2220s Mastercode : 0345226145 Product Serial Number: HVA956628 Product Code : 059C0Q4 Module Code : 0204340 Basic Production Code: 0582851 Default SN Type : 0 MCU SW Version : V 09.55 12-11-09 RM-590 (c) Nokia T PPM Version : V 09.55 12-11-09 RM-590 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 12648 RFIC Version : 0500 DSP Version : ICPR72_09w46_U LCD Version : SUEZ Content Pack Version : Content: vodafone AU V 09.55 12-11-09 RM-590 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 5050300014981890 PROFILE_BITS : 800000000003000B Asic : 11 Provider : Vodafone;Australia Unable to completely read SL Table.. ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D1012601022E05 DCC Ver: 001007 Status : OK MCU: V 09.55 12-11-09 RM-590 (c) Nokia IMEI: 355371.................... Model : Nokia 2220s Mastercode : 0345226145 Product Serial Number: HVA956628 Product Code : 059C0Q4 Module Code : 0204340 Basic Production Code: 0582851 Default SN Type : 0 MCU SW Version : V 09.55 12-11-09 RM-590 (c) Nokia T PPM Version : V 09.55 12-11-09 RM-590 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 12648 RFIC Version : 0500 DSP Version : ICPR72_09w46_U LCD Version : SUEZ Content Pack Version : Content: vodafone AU V 09.55 12-11-09 RM-590 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100014981890 PROFILE_BITS : 000000000003000B Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D1012601022E05 DCC Ver: 001007 Status : OK |
03-06-2011, 08:43 | #1571 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia N8 Flash Done With ATF BOX Number of Image Files: 3 Processing Image File : RM-596_013.016_79.92_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 548 Entry Point: 0x01E9 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-596_013.016_C06.01_MEA_3_79.92_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 2 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00002200 Processing Image File : RM-596_013.016_14.01_MEA_C_79.92_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 124 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00040000 []: Found 1 active devices. [Nokia N8-00 USB Phonet]: Opening Connection [Nokia N8-00 USB Phonet]: Port opened OK! SW: V 92PS1_10w34.3 10-09-10 RM-596 (c) Nokia IMEI: 356237040043117 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\356237040043117\USB_FULL_BACK UP_V 92PS1_10w34.3 10-09-10 RM-596 (c) Nokia_356237040043117_Not Locked_123646.pm Reading battery value : 4173 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 Cant verify BootRom! AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 Cant verify BootRom! AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 Cant verify BootRom! AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeded After 4 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 10C00109 ID DWORD 1 : F8D00344 ID DWORD 2 : C1BAE3D4 ID DWORD 3 : EE2E4D7F ID DWORD 4 : 47899C63 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B START FLASHING RawLoaderExtract: Processing RM-596_013.016_79.92_prd.core.fpsx CMT Secondary Loader: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 356237040043117 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\356237040043117\3562370400431 17_123726.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 PAPUB Keys Hash : D172C32473AE199B213465ABB3853246F9631231 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-596\ ImadeFilename: RM-596_013.016_79.92_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 02E60000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02FA0000 Size : 0B9E0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0EA00000 Size : 10600000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 1F000000 Size : 00400000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 00020014000002E60000000000040000000202FA00000B9E00 0000000008000000010EA00000106000000000000A00000001 1F000000004000003E PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-0007FFFF 1 : 000C0000-008BFFFF 2 : 00DC0000-0E97FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x03000000 Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000E97FFFF7F ERASE_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025 Successfully erased.. Total blocks to write : 548 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-596\ ImadeFilename: RM-596_013.016_C06.01_MEA_3_79.92_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0DA80000-0E97FFFF ERASE_REQUEST_BB5 : 5001120B0003000DA800000E97FFFF86 Successfully erased.. Total blocks to write : 2 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-596\ ImadeFilename: RM-596_013.016_14.01_MEA_C_79.92_prd.rofs2.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 09F40000-0DA7FFFF ERASE_REQUEST_BB5 : 5001120B00030009F400000DA7FFFF2F Successfully erased.. Total blocks to write : 124 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000007 Additional Bad : 00000007 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:25 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
03-06-2011, 08:55 | #1572 (permalink) |
No Life Poster Join Date: Feb 2010 Location: pakistan(Timergara) Age: 37
Member: 1224733 Status: Offline Thanks Meter: 158 | 7020 flashed in 15 sec Number of Image Files: 3 Processing Image File : rm497__10.00.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 459 Entry Point: 0x01E2 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm497__10.00.ppm_meac CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 108 Entry Point: 0x00FA Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm497__10.00.image_meac_0579869_007 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 257 Entry Point: 0x0134 Page Format : -1 MAX PAGE : 0x0000E000 []: Found 0 active devices. []: Not Found! Reading battery value : 0 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005331 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 55016686 ID DWORD 1 : 0C23EAD7 ID DWORD 2 : 6A684021 ID DWORD 3 : 38A871DE ID DWORD 4 : D6770F11 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A START FLASHING RawLoaderExtract: Processing rm497__10.00.mcusw CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 356073036890686 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356073036890686\3560730368906 86_113248.rpl Pabub KEY Request No PAPUBKeysHash Returned ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-497\ ImadeFilename: rm497__10.00.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : RND ASIC Index : CMT 0 Certificate 5 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00020000 Size : 027E0000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 02800000 Size : 04D40000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 07540000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 07B40000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000027E000000000008000000010280000004D400 000000000A0000000107540000006000000000000B00000001 07B4000000180000ED PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x80 (128) ERASE Blocks : 0x03 (3) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00020000-000203FF 2 : 00060000-01FFFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000000000001FFFF120B0003000002000000 0203FF120B0003000006000001FFFFFF93 ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B Successfully erased.. Total blocks to write : 459 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : GENIO_INIT ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-497\ ImadeFilename: rm497__10.00.ppm_meac StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02000000-027FFFFF ERASE_REQUEST_BB5 : 5001120B00030002000000027FFFFF5D Successfully erased.. Total blocks to write : 108 ImagePath: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-497\ ImadeFilename: rm497__10.00.image_meac_0579869_007 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02800000-0753FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B000300028000000753FFFF04 ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully erased.. Total blocks to write : 257 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:15 (Booting time is NOT Included) |
03-06-2011, 09:51 | #1573 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | nokia 3110c flashed successfully nokia 3110c flashed successfully Code: ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110628 (0xE4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1120010E ID DWORD 1 : 12E97E56 ID DWORD 2 : F720C2F9 ID DWORD 3 : DAF874E6 ID DWORD 4 : 039E2DC2 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 72 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> NU48F256 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VAR ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 03 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 A2 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x4E (78) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:27 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm237__07.30.mcusw Total blocks to write : 945 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:50 Making delay between files for 5000ms Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.30.ppm_b CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 205 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110628 (0xE4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1120010E ID DWORD 1 : 12E97E56 ID DWORD 2 : F720C2F9 ID DWORD 3 : DAF874E6 ID DWORD 4 : 039E2DC2 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 72 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> NU48F256 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01080000-0151FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:19 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm237__07.30.ppm_b Total blocks to write : 205 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:09 Making delay between files for 5000ms Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.30.image_ora_pl CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 264 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.30.image_ora_pl_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 264 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 63110628 (0xE4) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1120010E ID DWORD 1 : 12E97E56 ID DWORD 2 : F720C2F9 ID DWORD 3 : DAF874E6 ID DWORD 4 : 039E2DC2 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 72 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> NU48F256 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21 Flash Descriptor Manufacturer Code : 0089 Device ID : 8981 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01FDFFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:12 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm237__07.30.image_ora_pl_128k Total blocks to write : 264 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:17 Total Flash Write Time (Flashing Only) : 00:01:17 Total Flashing Time (Booting + Erase + Flashing) : 00:04:29 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 353183037333199 Model : Nokia 3110c Product Serial Number: MLH331671 Product Code : 0581523 Module Code : 0203291 Basic Production Code: 0542523 MCU SW Version : V 07.30 07-05-09 RM-237 (c) Nokia. B BT MCM Version : 06cc-P9.1 PPM Version : V 07.30 07-05-09 RM-237 (c) Nokia. HW Version : 5008 RFIC Version : 17211721 DSP Version : ICPR61_08w10 Content Pack Version : Content: ora_pl V 07.30 07-05-09 RM-237 (c) Nokia. AHNE Version : 11 Retu Version : 32 Tahvo Version : 53 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK Changing Phone Mode... (Wait for 5 seconds) Successfully set to : Normal |
03-06-2011, 12:57 | #1574 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia 2720a Unlock Done With ATF BOX MCU: V 08.20 30-06-09 RM-519 (c) Nokia IMEI: 359350034173431 Model : Nokia 2720a-2 Mastercode : 4712673425 Product Serial Number: IQH463697 Product Code : 0589538 Module Code : 0204102 Basic Production Code: 0572278 Default SN Type : 0 MCU SW Version : V 08.20 30-06-09 RM-519 (c) Nokia AE BT MCM Version : 1673-46032 PPM Version : V 08.20 30-06-09 RM-519 (c) Nokia HW Version : 1001 UEM Version : 4386 UPP Version : 12648 RFIC Version : 0500 DSP Version : ICPR72_09w24_U LCD Version : SUEZ Content Pack Version : Content: ae_blac_uk TESCO UK V2 30-06-09 RM-519 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 2340000300000000 PROFILE_BITS : 800000000003000B Asic : 11 Provider : Tesco Mobile (3510i);United Kingdom Unable to completely read SL Table.. ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D10126095A1F87 DCC Ver: 001004 Status : OK MCU: V 08.20 30-06-09 RM-519 (c) Nokia IMEI: 359350034173431 Model : Nokia 2720a-2 Mastercode : 4712673425 Product Serial Number: IQH463697 Product Code : 0589538 Module Code : 0204102 Basic Production Code: 0572278 Default SN Type : 0 MCU SW Version : V 08.20 30-06-09 RM-519 (c) Nokia AE BT MCM Version : 1673-46032 PPM Version : V 08.20 30-06-09 RM-519 (c) Nokia HW Version : 1001 UEM Version : 4386 UPP Version : 12648 RFIC Version : 0500 DSP Version : ICPR72_09w24_U LCD Version : SUEZ Content Pack Version : Content: ae_blac_uk TESCO UK V2 30-06-09 RM-519 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100300000000 PROFILE_BITS : 000000000003000B Asic : 11 Provider : Unknown Provider Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : GR0103D10126095A1F87 DCC Ver: 001004 Status : OK |
03-06-2011, 17:03 | #1575 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Nokia 6700c Flash Done With ATF BOX Number of Image Files: 3 Processing Image File : rm470__13.10.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 229 Entry Point: 0x021B Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm470__13.10.ppm_mb CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 44 Entry Point: 0x011D Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm470__13.10_ISM_018.image_mb_pk_chrome CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 184 Entry Point: 0x014C Page Format : -1 MAX PAGE : 0x00020000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02011104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C34 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1CA00008 ID DWORD 1 : 915C0344 ID DWORD 2 : 58C31468 ID DWORD 3 : A540C7C5 ID DWORD 4 : A3480024 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 3E273BF6 CRC 1 : 37BE26FA START FLASHING RawLoaderExtract: Processing rm470__13.10.mcusw CMT Secondary Loader: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 353181035168716 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\353181035168716\3531810351687 16_85403.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 PAPUB Keys Hash : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-470\ ImadeFilename: rm470__13.10.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 02860000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 02FC0000 Size : 0C300000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F2C0000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 0F8C0000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002860000000000080000000102FC00000C3000 000000000A000000010F2C0000006000000000000B00000001 0F8C0000001800003D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xD1 (209) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x3B (59) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-000203FF 1 : 00060000-0009FFFF 2 : 000A0000-0041FFFF 3 : 00420000-0069FFFF 4 : 006A0000-01F1FFFF 5 : 02900000-02FBFFFF 6 : 0F2C0000-0F8BFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info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uccessfully erased.. Total blocks to write : 229 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : ISA+DYNSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-470\ ImadeFilename: rm470__13.10.ppm_mb StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01F20000-028FFFFF ERASE_REQUEST_BB5 : 5001120B00030001F20000028FFFFF5C Successfully erased.. Total blocks to write : 44 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-470\ ImadeFilename: rm470__13.10_ISM_018.image_mb_pk_chrome StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02FC0000-0F2BFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B00030002FC00000F2BFFFFA8 ERASE_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully erased.. Total blocks to write : 184 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:13 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... FACTORY SET TO : Factory Set Full OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Production Tuning OK FACTORY SET TO : Reset User Code OK FACTORY SET TO : Service Centre OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : User Data OK RESET LIFE TIMER TO : 0000:00 OK |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
