05-27-2015, 11:47 | #5446 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 1 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:36 |
05-27-2015, 11:59 | #5447 (permalink) |
Freak Poster Join Date: Sep 2013 Location: INDIA
Member: 2023985 Status: Offline Sonork: WhatsApp Thanks Meter: 314 | Nokia 610n RM-849 Unlocked ATF JTAG Lucky Kapurthale Ton Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xE44272DC Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26-Nov-13 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...No Devices found in Chain! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 69662593 ACTIVE Level 1 PUK: 62584753 ACTIVE Level 2 PIN: 94405559 Level 2 PUK: 61254317 Level 3 PIN: 11442533 Level 3 PUK: 78054038 Level 4 PIN: 53386609 Level 4 PUK: 16786587 Level 5 PIN: 98414491 Level 5 PUK: 67903920 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== JTAG Interface Disconnected! |
05-29-2015, 16:10 | #5448 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Lumia 620 dead boot repair successfull Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...90014A48384732640401008A761EBF3C Flash Description: Hynix H8G2d, 7.23 GiB, SN 008A761E, Nov 2012 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5955 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 16m 29s. Code Download Speed 175 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
05-29-2015, 16:11 | #5449 (permalink) |
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Lumia 520 dead boot repair successfull Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001F3E5B5760E5 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1F3E5B57, Jun 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3241 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 8m 13s. Code Download Speed 351 KiB/sec. Boot Restore Done! |
06-04-2015, 20:09 | #5450 (permalink) |
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Nokia xl flashing successfull Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Processing QCSBL CONFIG Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing QCSBL Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing MODEM Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing OEMSBL HEADER Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing OEMSBL Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing APPSBOOT HEADER Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing APPSBOOT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing BOOT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing RECOVERY Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing PERSIST Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing SYSTEM Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing VARIANT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing CACHE Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing USERDATA Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing UDISK Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing PRELOAD Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Flashing Done! Total Flashing Time (Erase + Flashing) : 00:05:09 Rebooting to Normal Mode... |
06-07-2015, 08:21 | #5451 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 205 Flashing Done Code: Number of Image Files: 3 Processing Image File : rm862__04.71.mcusw Processing Image File : rm862__04.71.ppm_ma2 Processing Image File : rm862__04.71.image_ma2_059T5H4 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12402019A0072817 Original Product Code: 059Q046 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488055775926\355488055775926_15715 A.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488055775926\355488055775926_CERTIFICATE_31E22ADE.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355488055775926\355488055775926_PMM_PROT_5928DF9F.bin Security Code: 12345 Data Sections : 04 Current File : rm862__04.71.mcusw Compile Name: rm862__04.71.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217864 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: B10A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A56 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 85F5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24903680 bytes Data Checksum: 1AA0 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm862__04.71.ppm_ma2 Compile Name: package_ma2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4171872 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A40000~0x4207FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4168528 bytes Data Checksum: FEF5 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm862__04.71.image_ma2_059T5H4 Compile Name: package_ma2_059T5H4.image.fls Image Type : CONTENT Package Data Size : 16518416 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42080000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 16515072 bytes Data Checksum: 1B5C Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:07:50 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.71 15-10-13 RM-862 (c) Nokia IMEI Plain : 355488055775926 IMEI Spare : A355488055775920 IMEI SV : 33554880557759212F IMEI (2nd) : 355488055775934 IMEI Spare : A355488055775930 IMEI SV : 33554880557759312F Phone Model: K 205 Category : Phone Phone Type : RM-862 ================================================ Extended Phone Information ================================================ Product Serial Number: E54B5E5AH Product Code : 059Q046 Module Code : 0205222 Long Production SN : 0 PPM SW Version : V 04.71 15-10-13 RM-862 (c) Nokia MA2 MCU SW Version : V 04.71 15-10-13 RM-862 (c) Nokia HW Version : 1000 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: ma2_059T5H4 V 04.71 18-04-14 RM-862 (c) Nokia Bluetooth ID : 54:79:75:09:78:94 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 010009 Status : OK ====================================================== Selected VPL File: RM862_059T5H4_04.71_032.vpl ====================================================== Variant Details : RM-862 MEA_MA2_FBLACK_ARA_EG Software Version : 04.71 Product Type : RM-862 Product Code : 059T5H4 Variant Version : 032 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
06-09-2015, 14:21 | #5452 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | MCU: V 03.24 04-04-05 RM-47 6170 (c) Nokia. IMEI: 355016000848579 Model : Nokia 6170 Product Serial Number: SVH218081 Product Code : 0521610 Module Code : 0202487 Basic Production Code: 0518037 PPM SW Version : V 03.24 04-04-05 RM47_-48 XXXX (c) C ADSP Version : p ADSP_CAPELLA_2004_51 MCU SW Version : V 03.24 04-04-05 RM-47 6170 (c) Nokia. HW Version : 1008 UEM Version : 400 UPP Version : 4178 RFIC Version : p 10ff11ff0205 DSP Version : p TEB0421_0504 LCD Version : IZU_SEIKO Content Pack Version : V 03.211\n11-11-04\nRM47_-48\nXXXX\n(c) Nokia. ********** SIMLOCK INFO ********** CONFIG_DATA : 2343000000000000 PROFILE_BITS : 0000000000000006 ASIC : 6 PROVIDER : Software Cellular Network Ltd;UK [GSM] Block [1] 1:Close Block [2] 1:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 2305527634 PHONE_MODE : LOCAL Quick RPL DATA1 Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355016000848579\3550160008485 79_BACKUP.RPL Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... MCU: V 03.24 04-04-05 RM-47 6170 (c) Nokia. IMEI: 355016000848579 Model : Nokia 6170 Product Serial Number: SVH218081 Product Code : 0521610 Module Code : 0202487 Basic Production Code: 0518037 PPM SW Version : V 03.24 04-04-05 RM47_-48 XXXX (c) C ADSP Version : p ADSP_CAPELLA_2004_51 MCU SW Version : V 03.24 04-04-05 RM-47 6170 (c) Nokia. HW Version : 1008 UEM Version : 400 UPP Version : 4178 RFIC Version : p 10ff11ff0205 DSP Version : p TEB0421_0504 LCD Version : IZU_SEIKO Content Pack Version : V 03.211\n11-11-04\nRM47_-48\nXXXX\n(c) Nokia. ********** SIMLOCK INFO ********** CONFIG_DATA : 2343000000000000 PROFILE_BITS : 0000000000000006 ASIC : 6 PROVIDER : Software Cellular Network Ltd;UK [GSM] Block [1] 1:Close Block [2] 1:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 2305527634 PHONE_MODE : LOCAL Generating Simlock Table... Uploading Default Simlock Table... OK: Simlock Table Accepted MCU: V 03.24 04-04-05 RM-47 6170 (c) Nokia. IMEI: 355016000848579 Model : Nokia 6170 Product Serial Number: SVH218081 Product Code : 0521610 Module Code : 0202487 Basic Production Code: 0518037 PPM SW Version : V 03.24 04-04-05 RM47_-48 XXXX (c) C ADSP Version : p ADSP_CAPELLA_2004_51 MCU SW Version : V 03.24 04-04-05 RM-47 6170 (c) Nokia. HW Version : 1008 UEM Version : 400 UPP Version : 4178 RFIC Version : p 10ff11ff0205 DSP Version : p TEB0421_0504 LCD Version : IZU_SEIKO Content Pack Version : V 03.211\n11-11-04\nRM47_-48\nXXXX\n(c) Nokia. ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000000006 ASIC : 6 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 2305527634 PHONE_MODE : LOCAL Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
06-10-2015, 07:59 | #5453 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia 500DS Flash Done !! Code: Number of Image Files: 3 Processing Image File : rm934_14.0.6.mcusw.fls Processing Image File : rm934_14.0.6_059S9W9_i1.rofs.fls Processing Image File : rm934_14.0.6_059S9W9_i1.image.fls AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F016194200021C030101CAB21A0992CC8C2C279B4D00FFFF CPU Type: Intel XG221 Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: CAB21A0992CC8C2C Original Product Code: 059S9W9 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\358355058732666\358355058732666_120213.rpl Current File : rm934_14.0.6.mcusw.fls Number of Images: 2 rm934_14.0.6.mcusw.fls.fls rm934_14.0.6.mcusw.fls.fls Processing Data Block 0x00 Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40060000~0x401BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40340000~0x423B6496 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E00000~0x47E3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Current File : rm934_14.0.6_059S9W9_i1.rofs.fls Number of Images: 1 rofs_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x42880000~0x431DF906 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm934_14.0.6_059S9W9_i1.image.fls Number of Images: 1 rm934_14.0.6_059S9W9_i1.image.fls.image.fls Processing Data Block 0x00 Erase Block: 0x43800000~0x459DFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E40000~0x47F1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:02:17 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 14.0.6 10-07-14 RM-934 (c) Nokia IMEI Plain : 358355058732666 IMEI Spare : A358355058732660 IMEI SV : 33583550587326607F IMEI (2nd) : 358355058732674 IMEI Spare : A358355058732670 IMEI SV : 33583550587326707F Phone Model: 6 500 Category : Classic Phone Phone Type : RM-934 ================================================ Extended Phone Information ================================================ Product Serial Number: 47CA01CBH Product Code : 059S9W9 Module Code : 0205546 Basic Production Code: 059R4P6 Long Production SN : 0 PPM SW Version : ceee5001696e9f9edb13f0e320e622c61eb0539c BT MCM Version : 0101-0.1.A AEM Version : 4336b2-5.92.36.4 MCU SW Version : V 14.0.6 10-07-14 RM-934 (c) Nokia HW Version : 1100 UPP Version : MFR:0xff,DEV:0xff1a,REV:0x11 RFIC Version : Integrated to main ASIC LCD Version : TPO AHNE Version : 12 Variant Version : 0000000000000000000000000000000000000000 TAHVO Version : RM-934-14.0.6-059S9W9-14.0.6-14.0.6 Wireless LAN ID : DC:C7:93:18:13:53 Bluetooth ID : DC:C7:93:15:06:13 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : P PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0A350160 DCC Ver: 004015 Status : OK ====================================================== Selected VPL File: RM934_059S9W9_14.0.6_208.vpl ====================================================== Variant Details : RM-934 NDT INDIA I1 NULL IN Software Version : 14.0.6 Product Type : RM-934 Product Code : 059S9W9 Variant Version : 208 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Wbr, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
06-10-2015, 08:31 | #5454 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia Asha 305 Flash Done !! Code: Number of Image Files: 3 Processing Image File : rm766__07.42.mcusw Processing Image File : rm766__07.42.ppm_mh Processing Image File : rm766__07.42.image_mh_059K9H0 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 12401C062C05280E Original Product Code: 059P553 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354109057374465\354109057374465_124731.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354109057374465\354109057374465_CERTIFICATE_5411B91B.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354109057374465\354109057374465_PMM_PROT_73E8F465.bin Security Code: 12345 Data Sections : 04 Current File : rm766__07.42.mcusw Compile Name: rm766__07.42.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 29117832 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 1369 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 73CD Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4011FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 786432 bytes Data Checksum: 3B38 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40120000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 28065792 bytes Data Checksum: 1302 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm766__07.42.ppm_mh Compile Name: package_mh.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 7839672 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x423FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 7836328 bytes Data Checksum: 2D35 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm766__07.42.image_mh_059K9H0 Compile Name: package_mh_059K9H0.image.fls Image Type : CONTENT Package Data Size : 17042704 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42400000~0x43EDFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 17039360 bytes Data Checksum: 4620 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43F00000~0x43F7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:58 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 07.42 07-05-13 RM-766 (c) Nokia IMEI Plain : 354109057374465 IMEI Spare : A354109057374460 IMEI SV : 33541090573744640F IMEI (2nd) : 354109057374473 IMEI Spare : A354109057374470 IMEI SV : 33541090573744740F Phone Model: Nokia 305 Category : Classic Phone Phone Type : RM-766 ================================================ Extended Phone Information ================================================ Product Serial Number: 53D0EFDBI Product Code : 059P553 Module Code : 0204884 Basic Production Code: 059K4Q4 Long Production SN : 0 PPM SW Version : V 07.42 07-05-13 RM-766 (c) Nokia MH BT MCM Version : 19b5-22012 MCU SW Version : V 07.42 07-05-13 RM-766 (c) Nokia HW Version : 2000 RFIC Version : Dummy RFIC version LCD Version : TPO Content Pack Version : Content: mh_059K9H0 V 07.42 07-05-13 RM-766 (c) Nokia AHNE Version : 11 Bluetooth ID : DC:9F:A4:82:6D:93 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 115B6002 DCC Ver: 004020 Status : OK ====================================================== Selected VPL File: RM766_059K9H0_07.42_041.vpl ====================================================== Variant Details : RM-766 INDIA_MH_DGREY_NULL_IN Software Version : 07.42 Product Type : RM-766 Product Code : 059K9H0 Variant Version : 041 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Wbr, AniAXN |
06-10-2015, 08:39 | #5455 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia 501DS Flash Done !! Code: Number of Image Files: 3 Processing Image File : rm902_14.0.6.mcusw.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 81 Entry Point: 0x293D Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_14.0.2_059R3B3_i1_239_02_452067.rofs.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 20 Entry Point: 0x00B5 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_14.0.2_059R3B3_i1_239_02_452067.image.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 62 Entry Point: 0x00B8 Page Format : -1 MAX PAGE : 0x00080000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned Number of Sub Blocks 5 (0x05) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C20 ID DWORD 1 : 16100040 ID DWORD 2 : 49B22109 ID DWORD 3 : 9251C5C4 ID DWORD 4 : 47222500 2 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : D3FC3DCF ID DWORD 1 : F46A0767 ID DWORD 2 : 49B22109 ID DWORD 3 : 9251C5C4 ID DWORD 4 : 47222500 3 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 4 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 53588225 CRC 1 : 2F54C676 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg Secondary Loader Sent.... CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg Algorithm Loader Sent.... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 357898053088080 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI 1 : 357898053088080 IMEI 2 : 357898053088098 PRODUCT CODE : 059T1N0 WLAN ID : 2C:CC:15:B2:2E:40 BLUETOOTH ID : 2C:CC:15:AC:D7:10 PUBLIC_ID : D3FC3DCFF46A076749B221099251C5C447222500 PAPUB_KEYS_HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059T1N0 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : D3FC3DCFF46A076749B221099251C5C447222500 PRODUCT CODE : 059T1N0 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357898053088080\357898053088080_10521.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E Reading : ISA-USER... OK! PPM HASH : ba066ecbe24fbebd4c30344e6da130f93501284a PPM VERSION: 10.0.2 ====================================================== PHONE FIRMWARE VERSION: 10.0.2 ====================================================== ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_14.0.6.mcusw.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x26 (38) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 40000000-4003FFFF 1 : 47E00000-47E3FFFF 2 : 40060000-426FFFFF 3 : 47E40000-47F1FFFF ERASE_REQUEST_BB5 : 5004120B000000400000004003FFFF120B00000047E0000047E3FFFF120B00000040060000426FFFFF120B00000047E4000047F1FFFF61 Successfully Erased... Total blocks to write : 81 >> CMT Rootkey Hash CERT : ISSW >> CMT Rootkey Hash CERT : MEMSET >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : LOADER >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_14.0.2_059R3B3_i1_239_02_452067.rofs.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 42700000-437FFFFF ERASE_REQUEST_BB5 : 5001120B00000042700000437FFFFF6F Successfully Erased... Total blocks to write : 20 >> CMT Rootkey Hash CERT : PPM ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_14.0.2_059R3B3_i1_239_02_452067.image.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 43800000-47DFFFFF ERASE_REQUEST_BB5 : 5001120B0000004380000047DFFFFFFA Successfully Erased... Total blocks to write : 62 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) FlashInfo.RestartMode : Test Mode Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:43 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 14.0.6 10-07-14 RM-902 (c) Nokia IMEI: 357898053088080 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Wbr, AniAXN |
06-11-2015, 09:16 | #5456 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia Asha 309 Flash Done !! Code: Number of Image Files: 3 Processing Image File : rm843__08.22.mcusw CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 93 Entry Point: 0x037D Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm843__08.22.ppm_a CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 15 Entry Point: 0x0369 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm843__08.22.image_a_059N763 CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 108 Entry Point: 0x00B5 Page Format : -1 MAX PAGE : 0x00080000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned Number of Sub Blocks 5 (0x05) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C20 ID DWORD 1 : 16100040 ID DWORD 2 : 49922E09 ID DWORD 3 : B26A1430 ID DWORD 4 : F01E0B00 2 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 59152DB5 ID DWORD 1 : 0634D1C8 ID DWORD 2 : 49922E09 ID DWORD 3 : B26A1430 ID DWORD 4 : F01E0B00 3 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 4 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 53588225 CRC 1 : 2F54C676 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg Secondary Loader Sent.... CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg Algorithm Loader Sent.... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 352841052755734 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 352841052755734 PRODUCT CODE : 059Q758 WLAN ID : C8:3D:97:89:8D:F5 BLUETOOTH ID : C8:3D:97:88:07:55 PUBLIC_ID : 59152DB50634D1C849922E09B26A1430F01E0B00 PAPUB_KEYS_HASH: 42E7CDDAAE2ACD72926AC996E98AEC576D7840C3 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059Q758 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 59152DB50634D1C849922E09B26A1430F01E0B00 PRODUCT CODE : 059Q758 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352841052755734\352841052755734_14342.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 42E7CDDAAE2ACD72926AC996E98AEC576D7840C3 Reading : ISA-USER... OK! ====================================================== PHONE FIRMWARE VERSION: V 05.85 23-10-12 RM-843 (c) Nokia ====================================================== ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-843\ ImageFilename: rm843__08.22.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x2E (46) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 40000000-4003FFFF 1 : 47E00000-47E3FFFF 2 : 400A0000-4251FFFF 3 : 42520000-4261FFFF 4 : 47E40000-47F1FFFF ERASE_REQUEST_BB5 : 5005120B000000400000004003FFFF120B00000047E0000047E3FFFF120B000000400A00004251FFFF120B000000425200004261FFFF120B00000047E4000047F1FFFF28 Successfully Erased... Total blocks to write : 93 >> CMT Rootkey Hash CERT : ISSW >> CMT Rootkey Hash CERT : MEMSET >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : LOADER >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [42E7CDDAAE2ACD72926AC996E98AEC576D7840C3] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-843\ ImageFilename: rm843__08.22.ppm_a StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 42620000-42FFFFFF ERASE_REQUEST_BB5 : 5001120B0000004262000042FFFFFFFE Successfully Erased... Total blocks to write : 15 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-843\ ImageFilename: rm843__08.22.image_a_059N763 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 43000000-47DFFFFF ERASE_REQUEST_BB5 : 5001120B0000004300000047DFFFFF7A Successfully Erased... Total blocks to write : 108 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) FlashInfo.RestartMode : Test Mode Flashing Done... Total Flashing Time (Erase + Flashing) : 00:01:00 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 08.22 11-07-13 RM-843 (c) Nokia IMEI: 352841052755734 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 99999 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Wbr, AniAXN |
06-11-2015, 09:46 | #5457 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia C2-02 Flash Done !! Code: Number of Image Files: 3 Processing Image File : rm692__07.57.mcusw Processing Image File : rm692__07.57.ppm_mh2 Processing Image File : rm692__07.57.image_mh2_059P4Z6 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 04B080898C165C00 Original Product Code: 059H0R7 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357005041712371\357005041712371_20637.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357005041712371\357005041712371_CERTIFICATE_691D7A0B.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357005041712371\357005041712371_PMM_PROT_945685D1.bin Security Code: 12345 Data Sections : 04 Current File : rm692__07.57.mcusw Compile Name: rm692__07.57.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 29363592 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 20BF Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7AB2 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 9BB6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41DBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 28049408 bytes Data Checksum: 6B01 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm692__07.57.ppm_mh2 Compile Name: package_mh2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5160764 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41DC0000~0x424BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5157420 bytes Data Checksum: CAEB Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm692__07.57.image_mh2_059P4Z6 Compile Name: package_mh2_059P4Z6.image.fls Image Type : CONTENT Package Data Size : 13896976 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x424C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 13893632 bytes Data Checksum: 79D7 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:21 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 07.57 22-06-12 RM-692 (c) Nokia IMEI Plain : 357005041712371 IMEI Spare : A357005041712370 IMEI SV : 33570050417123720F Phone Model: K C2-02 Category : Phone Phone Type : RM-692 ================================================ Extended Phone Information ================================================ Product Serial Number: A50B10BAI Product Code : 059H0R7 Module Code : 0204666 Basic Production Code: 0593195 Long Production SN : 0 PPM SW Version : V 07.57 22-06-12 RM-692 (c) Nokia MH2 BT MCM Version : 19b5-22012 MCU SW Version : V 07.57 22-06-12 RM-692 (c) Nokia HW Version : 2000 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: mh2_059P4Z6 V 07.57 22-06-12 RM-692 (c) Nokia Bluetooth ID : AC:81:F3:C4:37:D5 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 094B2F01 DCC Ver: 008015 Status : OK ====================================================== Selected VPL File: RM692_059P4Z6_07.57_031.vpl ====================================================== Variant Details : RM-692 INDIA_MH2_BLACK_HINDI_IN Software Version : 07.57 Product Type : RM-692 Product Code : 059P4Z6 Variant Version : 031 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Wbr, AniAXN |
06-12-2015, 14:06 | #5458 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nokia XL Nokia XL Hang @ Logo Code: ====================================================== 14:50:40 : Nokia Android Firmware Flasher 14:50:40 : ====================================================== 14:50:40 : 14:50:40 : If the Phone is ALIVE 14:50:40 : 1. Power On the Phone and Connect it to the USB Port 14:50:40 : 14:50:40 : If the Phone is DEAD 14:50:40 : 1. Press and Hold the VOLUME DOWN button 14:50:40 : 2. Connect it to the USB Port while still Pressing 14:50:40 : the VOLUME DOWN button 14:50:40 : 3. Continue to Press the VOLUME DOWN button for 15 14:50:40 : more seconds 14:50:40 : ====================================================== 14:50:40 : 14:51:36 : Establishing Connection... 14:51:36 : Device is in Recovery Mode 14:51:36 : Phone Info cannot be Read... 14:51:36 : 14:51:36 : Rebooting to Bootloader... 14:51:38 : Waiting for Bootloader... 14:51:52 : 14:51:52 : Processing QCSBL CONFIG 14:51:52 : Initiating File Download... 14:51:52 : Start Sending Blocks... 14:51:52 : All Blocks Sent: OK 14:51:52 : Writing to eMMC... 14:51:52 : All Blocks Written: OK 14:51:52 : Processing QCSBL 14:51:52 : Initiating File Download... 14:51:52 : Start Sending Blocks... 14:51:52 : All Blocks Sent: OK 14:51:52 : Writing to eMMC... 14:51:53 : All Blocks Written: OK 14:51:53 : Processing MODEM 14:51:53 : Initiating File Download... 14:51:53 : Start Sending Blocks... 14:51:55 : All Blocks Sent: OK 14:51:55 : Writing to eMMC... 14:52:00 : All Blocks Written: OK 14:52:00 : Processing OEMSBL HEADER 14:52:00 : Initiating File Download... 14:52:00 : Start Sending Blocks... 14:52:00 : All Blocks Sent: OK 14:52:00 : Writing to eMMC... 14:52:00 : All Blocks Written: OK 14:52:00 : Processing OEMSBL 14:52:00 : Initiating File Download... 14:52:00 : Start Sending Blocks... 14:52:00 : All Blocks Sent: OK 14:52:00 : Writing to eMMC... 14:52:01 : All Blocks Written: OK 14:52:01 : Processing APPSBOOT HEADER 14:52:01 : Initiating File Download... 14:52:01 : Start Sending Blocks... 14:52:01 : All Blocks Sent: OK 14:52:01 : Writing to eMMC... 14:52:01 : All Blocks Written: OK 14:52:01 : Processing APPSBOOT 14:52:01 : Initiating File Download... 14:52:01 : Start Sending Blocks... 14:52:01 : All Blocks Sent: OK 14:52:01 : Writing to eMMC... 14:52:01 : All Blocks Written: OK 14:52:01 : Processing BOOT 14:52:01 : Initiating File Download... 14:52:01 : Start Sending Blocks... 14:52:01 : All Blocks Sent: OK 14:52:01 : Writing to eMMC... 14:52:03 : All Blocks Written: OK 14:52:03 : Processing RECOVERY 14:52:03 : Initiating File Download... 14:52:03 : Start Sending Blocks... 14:52:04 : All Blocks Sent: OK 14:52:04 : Writing to eMMC... 14:52:05 : All Blocks Written: OK 14:52:05 : Processing PERSIST 14:52:05 : Initiating File Download... 14:52:05 : Start Sending Blocks... 14:52:06 : All Blocks Sent: OK 14:52:06 : Writing to eMMC... 14:52:07 : All Blocks Written: OK 14:52:07 : Processing SYSTEM 14:52:07 : Initiating File Download... 14:52:07 : Start Sending Blocks... 14:52:54 : All Blocks Sent: OK 14:52:54 : Writing to eMMC... 14:54:55 : All Blocks Written: OK 14:54:55 : Processing VARIANT 14:54:55 : Initiating File Download... 14:54:55 : Start Sending Blocks... 14:54:57 : All Blocks Sent: OK 14:54:57 : Writing to eMMC... 14:55:04 : All Blocks Written: OK 14:55:04 : Processing CACHE 14:55:04 : Initiating File Download... 14:55:04 : Start Sending Blocks... 14:55:05 : All Blocks Sent: OK 14:55:05 : Writing to eMMC... 14:55:07 : All Blocks Written: OK 14:55:07 : Processing USERDATA 14:55:07 : Initiating File Download... 14:55:07 : Start Sending Blocks... 14:55:09 : All Blocks Sent: OK 14:55:09 : Writing to eMMC... 14:55:19 : All Blocks Written: OK 14:55:19 : Processing UDISK 14:55:19 : Initiating File Download... 14:55:19 : Start Sending Blocks... 14:55:24 : All Blocks Sent: OK 14:55:24 : Writing to eMMC... 14:55:35 : All Blocks Written: OK 14:55:35 : Processing PRELOAD 14:55:35 : Initiating File Download... 14:55:35 : Start Sending Blocks... 14:56:17 : All Blocks Sent: OK 14:56:17 : Writing to eMMC... 14:58:07 : All Blocks Written: OK 14:58:07 : 14:58:07 : Flashing Done! 14:58:07 : Total Flashing Time (Erase + Flashing) : 00:06:14 14:58:07 : 14:58:07 : Rebooting to Normal Mode... |
06-20-2015, 15:04 | #5459 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia Lumia 800 Unlock done.... FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 1 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x01D4CFFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:24 |
06-20-2015, 15:47 | #5460 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Indonesia
Member: 2155369 Status: Offline Thanks Meter: 706 | Nokia X RM-980 21:03:30 : ================================================ 21:03:30 : Advance Turbo Flasher Found 21:03:30 : ================================================ 21:03:30 : Driver Version : 00021000 21:03:30 : Library Version : 00030207 21:03:31 : Box Type : ATF Nitro 21:03:31 : Box Firmware : LogiCore 11.0.10 21:03:31 : Software Version : v12.31 21:03:31 : AdvanceBox SN : CE190E9CABF01DD0CEE57650 21:03:31 : Box Status : ACTIVATED 21:03:32 : ================================================ 21:03:32 : Box Successfully Initialized 21:03:32 : ================================================ 21:03:32 : 21:03:32 : VBATT Powering Down <<<< 21:03:35 : VBATT Powering Up >>>> 21:03:36 : SET VCCIO Level Done 21:03:36 : SET BSI Load Done 21:03:36 : 21:03:36 : 21:03:36 : 21:03:36 : ///////// /// /// /////// /////// ///////// 21:03:36 : /// /// /// /// // /// /// /// /// 21:03:36 : /// /// /// /////// /////// /// /// 21:03:36 : /// /// /// /// /// /// /// /// /// 21:03:36 : /// ///// /// /// /////// ////// 21:03:36 : 21:03:36 : ======================================= 21:03:36 : /// /// /// ///////// /////// ////// 21:03:36 : ///// /// /// /// /// // /// /// 21:03:36 : /// ///// /// /// /////// /// /// 21:03:36 : /// //// /// /// /// /// /// /// 21:03:36 : /// /// /// /// /// /// ////// 21:03:36 : ======================================= 21:03:36 : 21:09:06 : 21:09:06 : ================================================== ==== 21:09:06 : Selected VPL File: 21:09:06 : RM980_059T991_1.2.4.1_136.vpl 21:09:06 : ================================================== ==== 21:09:06 : Variant Details : RM-980 NDT APAC ID ERA 21:09:06 : Software Version : 1.2.4.1 21:09:06 : Product Type : RM-980 21:09:06 : Product Code : 059T991 21:09:06 : Variant Version : 136 21:09:06 : 21:09:17 : Shutting Down ADB Server... 21:09:17 : 21:09:17 : If your Phone is still not detected by 21:09:18 : ATF Software, manually End Process adb.exe 21:09:18 : in Windows Task Manager... 21:09:18 : 21:09:18 : 21:09:18 : ================================================== ==== 21:09:18 : Flash File Checksum Verification 21:09:18 : ================================================== ==== 21:09:18 : RM980_1.2.4.1_boot.img: CHECKSUM PASSED 21:09:18 : RM980_1.2.4.1_cache.img: CHECKSUM PASSED 21:09:18 : RM980_1.2.4.1_emmc_appsboot.mbn: CHECKSUM PASSED 21:09:18 : RM980_1.2.4.1_emmc_appsboothd.mbn: CHECKSUM PASSED 21:09:18 : RM980_1.2.4.1_persist.img: CHECKSUM PASSED 21:09:18 : RM980_1.2.4.1_recovery.img: CHECKSUM PASSED 21:09:25 : RM980_1.2.4.1_system.img: CHECKSUM PASSED 21:09:25 : RM980_1.2.4.1_userdata.img: CHECKSUM PASSED 21:09:25 : RM980_1.2.4.1_oemsblhd.mbn: CHECKSUM PASSED 21:09:25 : RM980_1.2.4.1_oemsbl.mbn: CHECKSUM PASSED 21:09:26 : RM980_1.2.4.1_qcsblhd_cfgdata.mbn: CHECKSUM PASSED 21:09:26 : RM980_1.2.4.1_qcsbl.mbn: CHECKSUM PASSED 21:09:26 : RM980_1.2.4.1_fat.bin: CHECKSUM PASSED 21:09:27 : RM980_1.2.4.1_udisk.bin: CHECKSUM PASSED 21:09:33 : RM980_1.2.4.1_preload.img: CHECKSUM PASSED 21:09:33 : RM980_1.2.4.1_059T991_APAC_ID_ERA_variant.img: CHECKSUM PASSED 21:09:33 : ================================================== ==== 21:09:33 : Verification Done... 21:09:37 : Nokia Android Phone Flashing Started 21:09:37 : 21:09:37 : 21:09:37 : ================================================== ==== 21:09:37 : Nokia Android Firmware Flasher 21:09:37 : ================================================== ==== 21:09:37 : 21:09:37 : If the Phone is ALIVE 21:09:37 : 1. Power On the Phone and Connect it to the USB Port 21:09:37 : 21:09:37 : If the Phone is DEAD 21:09:37 : 1. Press and Hold the VOLUME DOWN button 21:09:37 : 2. Connect it to the USB Port while still Pressing 21:09:37 : the VOLUME DOWN button 21:09:37 : 3. Continue to Press the VOLUME DOWN button for 15 21:09:37 : more seconds 21:09:37 : ================================================== ==== 21:09:37 : 21:10:17 : 21:10:17 : ================================================== ==== 21:10:17 : ERROR: Active Phone Handle was NOT DETECTED 21:10:17 : ================================================== ==== 21:10:17 : 21:10:17 : 1. Make Sure USB Drivers are Installed! 21:10:17 : 21:10:17 : 2. Make Sure Battery is Fully Charged! 21:10:17 : ================================================== ==== 21:10:48 : 21:10:48 : ================================================== ==== 21:10:48 : Flash File Checksum Verification 21:10:48 : ================================================== ==== 21:10:48 : RM980_1.2.4.1_boot.img: CHECKSUM PASSED 21:10:48 : RM980_1.2.4.1_cache.img: CHECKSUM PASSED 21:10:48 : RM980_1.2.4.1_emmc_appsboot.mbn: CHECKSUM PASSED 21:10:48 : RM980_1.2.4.1_emmc_appsboothd.mbn: CHECKSUM PASSED 21:10:48 : RM980_1.2.4.1_persist.img: CHECKSUM PASSED 21:10:48 : RM980_1.2.4.1_recovery.img: CHECKSUM PASSED 21:10:50 : RM980_1.2.4.1_system.img: CHECKSUM PASSED 21:10:52 : RM980_1.2.4.1_userdata.img: CHECKSUM PASSED 21:10:52 : RM980_1.2.4.1_oemsblhd.mbn: CHECKSUM PASSED 21:10:52 : RM980_1.2.4.1_oemsbl.mbn: CHECKSUM PASSED 21:10:52 : RM980_1.2.4.1_qcsblhd_cfgdata.mbn: CHECKSUM PASSED 21:10:52 : RM980_1.2.4.1_qcsbl.mbn: CHECKSUM PASSED 21:10:55 : RM980_1.2.4.1_fat.bin: CHECKSUM PASSED 21:10:56 : RM980_1.2.4.1_udisk.bin: CHECKSUM PASSED 21:11:10 : RM980_1.2.4.1_preload.img: CHECKSUM PASSED 21:11:12 : RM980_1.2.4.1_059T991_APAC_ID_ERA_variant.img: CHECKSUM PASSED 21:11:12 : ================================================== ==== 21:11:12 : Verification Done... 21:11:13 : Nokia Android Phone Flashing Started 21:11:13 : 21:11:13 : 21:11:13 : ================================================== ==== 21:11:13 : Nokia Android Firmware Flasher 21:11:13 : ================================================== ==== 21:11:13 : 21:11:13 : If the Phone is ALIVE 21:11:13 : 1. Power On the Phone and Connect it to the USB Port 21:11:13 : 21:11:13 : If the Phone is DEAD 21:11:13 : 1. Press and Hold the VOLUME DOWN button 21:11:13 : 2. Connect it to the USB Port while still Pressing 21:11:13 : the VOLUME DOWN button 21:11:13 : 3. Continue to Press the VOLUME DOWN button for 15 21:11:13 : more seconds 21:11:13 : ================================================== ==== 21:11:13 : 21:11:13 : Establishing Connection... 21:11:13 : SW Version : 11.1.1 21:11:14 : Phone Model : Nokia_X 21:11:14 : Phone Type : RM-980 21:11:14 : SW Version : 11.1.1 21:11:14 : IMEI #2 Plain : 352373060971111 21:11:14 : IMEI #1 Plain : 352373060471138 21:11:14 : Product Code : 059T991 21:11:14 : Serial Number : 9ddb6102 21:11:14 : 21:11:14 : ================================================ 21:11:14 : Extended Phone Information 21:11:14 : ================================================ 21:11:14 : Baseband Version : 8X25-SSRSKOLYM-3070 21:11:14 : Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140307.164931 test-keys 21:11:14 : Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140307.164931:user/test-keys 21:11:14 : Android OS Version : 4.1.2 21:11:14 : Product Platform : Nokia X software platform 1.1 21:11:14 : 21:11:14 : Rebooting to Bootloader... 21:11:22 : Waiting for Bootloader... 21:11:32 : Establishing Connection... 21:11:32 : 21:11:32 : ================================================ 21:11:32 : Extended Phone Information 21:11:32 : ================================================ 21:11:32 : 21:11:32 : Rebooting to Bootloader... 21:11:32 : Waiting for Bootloader... 21:11:43 : Establishing Connection... 21:11:43 : 21:11:43 : ================================================ 21:11:43 : Extended Phone Information 21:11:43 : ================================================ 21:11:43 : 21:11:43 : Rebooting to Bootloader... 21:11:43 : Waiting for Bootloader... 21:11:53 : Establishing Connection... 21:11:53 : 21:11:53 : ================================================ 21:11:53 : Extended Phone Information 21:11:53 : ================================================ 21:11:53 : 21:11:53 : Rebooting to Bootloader... 21:11:53 : Waiting for Bootloader... 21:12:08 : 21:12:08 : Processing QCSBL CONFIG 21:12:08 : Initiating File Download... 21:12:08 : Start Sending Blocks... 21:12:08 : All Blocks Sent: OK 21:12:08 : Writing to eMMC... 21:12:08 : All Blocks Written: OK 21:12:08 : Processing QCSBL 21:12:08 : Initiating File Download... 21:12:08 : Start Sending Blocks... 21:12:08 : All Blocks Sent: OK 21:12:08 : Writing to eMMC... 21:12:08 : All Blocks Written: OK 21:12:08 : Processing MODEM 21:12:09 : Initiating File Download... 21:12:09 : Start Sending Blocks... 21:12:11 : All Blocks Sent: OK 21:12:12 : Writing to eMMC... 21:12:17 : All Blocks Written: OK 21:12:17 : Processing OEMSBL HEADER 21:12:17 : Initiating File Download... 21:12:17 : Start Sending Blocks... 21:12:17 : All Blocks Sent: OK 21:12:17 : Writing to eMMC... 21:12:17 : All Blocks Written: OK 21:12:17 : Processing OEMSBL 21:12:17 : Initiating File Download... 21:12:18 : Start Sending Blocks... 21:12:18 : All Blocks Sent: OK 21:12:18 : Writing to eMMC... 21:12:18 : All Blocks Written: OK 21:12:18 : Processing APPSBOOT HEADER 21:12:18 : Initiating File Download... 21:12:18 : Start Sending Blocks... 21:12:18 : All Blocks Sent: OK 21:12:18 : Writing to eMMC... 21:12:18 : All Blocks Written: OK 21:12:18 : Processing APPSBOOT 21:12:18 : Initiating File Download... 21:12:18 : Start Sending Blocks... 21:12:18 : All Blocks Sent: OK 21:12:18 : Writing to eMMC... 21:12:18 : All Blocks Written: OK 21:12:18 : Processing BOOT 21:12:18 : Initiating File Download... 21:12:18 : Start Sending Blocks... 21:12:19 : All Blocks Sent: OK 21:12:19 : Writing to eMMC... 21:12:20 : All Blocks Written: OK 21:12:20 : Processing RECOVERY 21:12:20 : Initiating File Download... 21:12:20 : Start Sending Blocks... 21:12:21 : All Blocks Sent: OK 21:12:21 : Writing to eMMC... 21:12:23 : All Blocks Written: OK 21:12:23 : Processing PERSIST 21:12:23 : Initiating File Download... 21:12:23 : Start Sending Blocks... 21:12:24 : All Blocks Sent: OK 21:12:24 : Writing to eMMC... 21:12:25 : All Blocks Written: OK 21:12:26 : Processing SYSTEM 21:12:27 : Initiating File Download... 21:12:27 : Start Sending Blocks... 21:13:23 : All Blocks Sent: OK 21:13:23 : Writing to eMMC... 21:15:21 : All Blocks Written: OK 21:15:21 : Processing VARIANT 21:15:21 : Initiating File Download... 21:15:21 : Start Sending Blocks... 21:15:22 : All Blocks Sent: OK 21:15:22 : Writing to eMMC... 21:15:23 : All Blocks Written: OK 21:15:23 : Processing CACHE 21:15:23 : Initiating File Download... 21:15:23 : Start Sending Blocks... 21:15:24 : All Blocks Sent: OK 21:15:24 : Writing to eMMC... 21:15:26 : All Blocks Written: OK 21:15:26 : Processing USERDATA 21:15:26 : Initiating File Download... 21:15:26 : Start Sending Blocks... 21:15:30 : All Blocks Sent: OK 21:15:30 : Writing to eMMC... 21:15:40 : All Blocks Written: OK 21:15:40 : Processing UDISK 21:15:40 : Initiating File Download... 21:15:40 : Start Sending Blocks... 21:15:45 : All Blocks Sent: OK 21:15:45 : Writing to eMMC... 21:15:58 : All Blocks Written: OK 21:15:58 : Processing PRELOAD 21:15:59 : Initiating File Download... 21:15:59 : Start Sending Blocks... 21:16:46 : All Blocks Sent: OK 21:16:46 : Writing to eMMC... 21:18:28 : All Blocks Written: OK 21:18:29 : 21:18:29 : Flashing Done! 21:18:29 : Total Flashing Time (Erase + Flashing) : 00:06:20 21:18:29 : 21:18:29 : Rebooting to Normal Mode... |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
