07-03-2015, 18:28 | #5477 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia Lumia 510 Unlock code read done... Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 53157093 ACTIVE Level 1 PUK: 99587108 ACTIVE Level 2 PIN: 55661873 Level 2 PUK: 39319180 Level 3 PIN: 23763505 ACTIVE Level 3 PUK: 16764926 ACTIVE Level 4 PIN: 40235121 Level 4 PUK: 19802130 Level 5 PIN: 52080197 Level 5 PUK: 10447296 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== Saving "..\Logs\Screenshots\2015-07-03_17-12-41.jpg"...OK |
07-06-2015, 09:46 | #5481 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lumia 710 rm-809 tmobile unlock done Code: FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 1 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:50 |
07-13-2015, 10:28 | #5487 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | X A110 Flash Repair Done Code: Nokia Android Phone Flashing Started ====================================================== Nokia Android Firmware Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ====================================================== Processing QCSBL CONFIG Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing QCSBL Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing MODEM Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing OEMSBL HEADER Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing OEMSBL Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing APPSBOOT HEADER Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing APPSBOOT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing BOOT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing RECOVERY Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing PERSIST Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing SYSTEM Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing VARIANT Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing CACHE Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing USERDATA Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing UDISK Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Processing PRELOAD Initiating File Download... Start Sending Blocks... All Blocks Sent: OK Writing to eMMC... All Blocks Written: OK Flashing Done! Total Flashing Time (Erase + Flashing) : 00:05:09 Rebooting to Normal Mode... Br Palash Ahammad
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
07-14-2015, 12:23 | #5488 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | REPAIR EMMC DONE N7000 N7100 N8000 I9300 I9100 G7102 eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB |
07-14-2015, 14:22 | #5490 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
