Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-27-2016, 06:53   #5956 (permalink)
iOS_Shakil's Avatar
Member: 2441719
Thanks Meter: 2,033
Nokia Rm-689 Phone Lock Done By ATF
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted after 5 attempts...
START INFINEON BUS CHECK
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
INFINEON BUS CHECK DONE
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Old 12-28-2016, 07:12   #5957 (permalink)
Member: 1732025
Sonork: 100.1615024
Thanks Meter: 354
6101 unlock done
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
MCU: V 03.36 29-06-05 RM-77 (c) Nokia.
IMEI: 356642000962125
Model : Nokia 6101
Product Serial Number: RYF553199
Product Code : 0525914
Module Code : 0202528
Basic Production Code: 0527776
PPM SW Version : V 03.36 29-06-05 RM-76 (c) Nokia. I
MCU SW Version : V 03.36 29-06-05 RM-77 (c) Nokia.
HW Version : 5000
UEM Version : 400
UPP Version : 8514
RFIC Version : 0205
DSP Version : P05w06.v10
LCD Version : SUEZ
********** SIMLOCK INFO **********
CONFIG_DATA : 3027200000000000
PROFILE_BITS : 8000000000000002
ASIC : 2
PROVIDER : Rorges Communications;Canada [GSM]
Block [1] 1:Close
ST_SIMLOCK_TEST : PASSED
ST_LCD_TEST : PASSED
MASTER_CODE : 2512576677
PHONE_MODE : LOCAL
Generating Simlock Table...
Uploading Default Simlock Table...
OK: Simlock Table Accepted
Model : Nokia 6101
HW Version : 5000
UEM Version : 400
UPP Version : 8514
RFIC Version : 0205
LCD Version : SUEZ
CONFIG_DATA : 0010100000000000
ASIC : 2
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
PHONE_MODE : LOCAL
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Old 01-03-2017, 21:04   #5958 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 4,130
Lumia 525 write flash
Windows Phone 8/8.1 Flashing Started
Loading Flash Files Please Wait...
[DEAD BOOT REPAIR SUPPORTED]
          Windows Phone 8/8.1 Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Connect Phone to the USB Port
  2. Press and Hold the VOLUME DOWN and POWER Buttons
  3. Wait until the Phone Vibrates Shortly...
  4. Stop Pressing the Buttons...
If the Phone is DEAD BOOT
  2. Install Correct Drivers:
     "Nokia Emergency Connectivity"
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
Version: 1.1.1.3
Product Code: 059V535
Module Code: 0205952
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E74000
Block ID 0x05 : Nokia.MSM8227.P6137.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100130000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 02010F011C00
UEFI App: FLASH APP
Flash App Protocol Version: 1.15
Flash App Implementation Version: 1.28
Query ROOT KEY HASH...
ROOT_KEY_HASH: 25C0C84AECBD154F817825B24D4EB4BCF5E606E66228BD6A77997ACC54710C5E
Query PUBLIC ID...
PUBLIC_ID: 51C130152FE7378D1130A6DF8E74FD6CAEDCB082
Query eMMC Info...
EMMC Manufacture ID: HYNIX
EMMC Product SN : 00CF034F
EMMC_SIZE: 8 Gigabytes
Query Battery Charge Status...
BATTERY CHARGE_STATUS: 32%
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Fixing Partitions...
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:04:56
Old 01-12-2017, 15:24   #5959 (permalink)
Safyan sufi's Avatar
Member: 2221849
Sonork: offline
Thanks Meter: 144
Nokia N8 RM 596 Flash done
Old 02-08-2017, 09:14   #5960 (permalink)
bright hlatini's Avatar
Member: 1614640
Sonork: 100.1625899
Thanks Meter: 309
NOKIA 210 RM 925 VIBRATING DONE BY FLASHING
Number of Image Files: 3
Processing Image File :
rm925__04.14.mcusw
rm925__04.14.ppm_l
rm925__04.14.image_l_059R7H4
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
Sending SBL...
Setting Transmission Speed Done...
Flash Boot Successful...
Unique Data: 12000409A1103801
Original Product Code: 059T2Q3
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\ATF\AdvanceBox Turbo Flasher\Nokia\Backup\355513050622375\3555130506223 75_105625.rpl
Certificate Block Saved to:
C:\ATF\AdvanceBox Turbo Flasher\Nokia\Backup\355513050622375\3555130506223 75_CERTIFICATE_254C629A.bin
PM Block Saved to:
C:\ATF\AdvanceBox Turbo Flasher\Nokia\Backup\355513050622375\3555130506223 75_PMM_PROT_A27254F8.bin
Security Code: 20150
Data Sections : 04
Current File : rm925__04.14.mcusw
Compile Name: rm925__04.14.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 28839304 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 4C07
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AFE
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: AA22
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41CBFFFE
Start Erasing...
Block Erase Done...
Data Size: 27525120 bytes
Data Checksum: 12B7
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm925__04.14.ppm_l
Compile Name: package_l.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4003116 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41CC0000~0x422FFFFE
Start Erasing...
Block Erase Done...
Data Size: 3999772 bytes
Data Checksum: 548F
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm925__04.14.image_l_059R7H4
Compile Name: package_l_059R7H4.image.fls
Image Type : CONTENT Package
Data Size : 11144464 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42300000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 11141120 bytes
Data Checksum: E7E8
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:03:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 04.14 30-05-13 RM-925 (c) Nokia
IMEI Plain : 355513050622375
IMEI Spare : A355513050622370
IMEI SV : 33555130506223708F
Phone Model: Nokia 210
Category : Phone
Phone Type : RM-925
Extended Phone Information
Product Serial Number: 2377843BH
Product Code : 059T2Q3
Module Code : 0205473
Basic Production Code: 059R098
Long Production SN : 0
PPM SW Version : V 04.14 30-05-13 RM-925 (c) Nokia L
BT MCM Version : 19e2-4702D
MCU SW Version : V 04.14 30-05-13 RM-925 (c) Nokia
HW Version : 1201
RFIC Version : 68
LCD Version : TPO
Content Pack Version : Content: l_059R7H4 V 04.14 30-05-13 RM-925 (c) Nokia
Wireless LAN ID : EC:F3:5B:21:4E:0D
Bluetooth ID : EC:F3:5B:20:B1:CD
CS Type : GSM900, GSM1800
PROFILE_BITS : 800000000004000B
ASIC : 11
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SECURITY_TEST : PASSED
SECURITY_CODE : 20150
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 115B6002
DCC Ver: 004020
Status : OK
OK
OK
OK
OK
OK
OK
RESET LIFE TIMER TO : 0000:00
OK
Old 02-08-2017, 09:14   #5961 (permalink)
Member: 1614640
Sonork: 100.1625899
Thanks Meter: 309
rm925__04.14.mcusw
rm925__04.14.ppm_l
2. Insert USB.
Sending PBL...
Sending SBL...
Plain RPL saved to:
PM Block Saved to:
Data Sections : 04
Start Erasing...
Block Erase Done...
Data Checksum: 4C07
Start Erasing...
Block Erase Done...
Data Checksum: 7AFE
Start Erasing...
Block Erase Done...
Data Checksum: AA22
Start Erasing...
Block Erase Done...
Data Checksum: 12B7
Start Erasing...
Block Erase Done...
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: 548F
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: E7E8
Start Erasing...
Block Erase Done...
Category : Phone
Phone Type : RM-925
HW Version : 1201
RFIC Version : 68
LCD Version : TPO
ASIC : 11
PHONE_MODE : TEST
DCC ID : 115B6002
DCC Ver: 004020
Status : OK
OK
OK
OK
OK
OK
OK
OK
Old 02-12-2017, 06:43   #5962 (permalink)
iOS_Shakil's Avatar
Member: 2441719
Thanks Meter: 2,033
nokia 101 flash done by ATF box..............
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
Processing Image File: K:\Nokia\phoenix\products\RM-769\rm769_008.100
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Block Erase Done...
Data Size: 24576 bytes
Data Checksum: F5BE
IMAGE Data Blocks uploaded to phone...
Processing Section 02 of 03
IMAGE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: 676D
Processing Section 03 of 03
IMAGE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 2FCD
Start Data Verification... (Please wait)
Processing Image File: K:\Nokia\phoenix\products\RM-769\rm769_008.10mg
Data Block Found...
Number of Sections: 01
Processing Section 01 of 01
IMAGE Erase Block: 0x00100000~0x005FE53E
Start Erasing...
Block Erase Done...
Data Size: 5236032 bytes
Data Checksum: 2715
Processing Image File: K:\Nokia\phoenix\products\RM-769\rm7690_nai08.10mg_nlt
Data Block Found...
IMAGE Erase Block: 0x00E60000~0x00F49FFE
Start Erasing...
Block Erase Done...
Data Size: 958464 bytes
Data Checksum: 095F
Exit Flash Mode Done...
Time Elapse : 00:04:24
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 08.10 02-04-13 RM-769 (c) Nokia
IMEI: 354582056499303
Product Serial Number: C1FA25FAH
Product Code : 059H0H2
Module Code : 0204883
Basic Production Code: 059P5G1
PPM SW Version : V 08.10 02-04-13 RM-769 (c) Nokia MG
ADSP Version : p+V 08.10\n02-04-13\nRM-769\n(c) NMP\nmg_nlt
MCU SW Version : V 08.10 02-04-13 RM-769 (c) Nokia
HW Version : 1000
UEM Version : 1328
UPP Version : 8850
LCD Version : WIN:BARACOAv95 NT39121
PROFILE_BITS : 0000000000040002
ASIC : 11
OK
OK
OK
OK
OK
OK
Old 02-14-2017, 13:14   #5963 (permalink)
Member: 942321
1. Make sure JTAG Connection is 100% OK
2. DO NOT Connect a USB Cable to the phone
3. Connect RJ-45 JTAG Cable to ATF Box
4. Connect Phone BATTERY and POWER ON the Phone
5. Wait until WP7 OS is FULLY LOADED showing Main Menu
6. Check that Phone IMEI is valid via *#06#
7. If IMEI is valid, Click READ CODES button then wait...
Initializing Connection
Connected 1 device(s)!
Halting Core...
Halted Device xxxxxxxxxxxx
Searching for PIN/PUK Unlock Codes...
Please wait for a while...
Codes Found!
PIN LEVEL 1: 93304639 - LOCKED
PUK LEVEL 1: 10423081 - LOCKED
PIN LEVEL 2: 66067208
PUK LEVEL 2: 01955449
PIN LEVEL 3: 31883971
PUK LEVEL 3: 95855595
PIN LEVEL 4: 81487770
PUK LEVEL 4: 59784147
PIN LEVEL 5: 84807204
PUK LEVEL 5: 82975312
Reading Unlock Codes Done!
Old 02-16-2017, 09:09   #5964 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 889
NOKIA 520 DEAD RECOVERED WITH ATF WITH OUT JTAG
ONLY BY FLASHING
Windows Phone 8/8.1/10 Flashing Started
[DEAD BOOT REPAIR via USB is SUPPORTED]
Windows Phone 8/8.1/10 Lumia Flasher
"Nokia Emergency Connectivity" Located at:
C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\
Recovery Handle Found! - (WinUSB)
Sending Factory Loader...
Loader Upload Done!
Executing Loader...
Start Loader Done!
Waiting for USB Cycle...
USB Cycle OK!
Device Factory Mode OK!
USB Reconfiguration Done...
eMMC Detected OK...
Extracting Partitions from FFU...
Looking for SBL1...
SBL1 OK
Looking for SBL2...
SBL2 OK
Looking for SBL3...
SBL3 OK
Looking for UEFI...
UEFI OK
Looking for RPM...
RPM OK
Looking for TZ...
TZ OK
Looking for WINSECAPP...
WINSECAPP OK
Extracting Partitions Done!
Start Writing eMMC Blocks at : 0x00000000
Start Writing eMMC Blocks at : 0x01000000
Start Writing eMMC Blocks at : 0x01200000
Start Writing eMMC Blocks at : 0x01400000
Start Writing eMMC Blocks at : 0x01600000
Start Writing eMMC Blocks at : 0x01A00000
Start Writing eMMC Blocks at : 0x01C00000
Start Writing eMMC Blocks at : 0x01E00000
eMMC Write OK!
Closing Partition...
Partition Close OK!
BOOT WRITE DONE!
USB Cycle OK!
Rebooting Phone...
Version: 1.1.1.3
Product Code: 059S1N6
Module Code: 0205435
Block ID 0x05 : Nokia.MSM8227.P6036.1.2
Secure FFU Mode :
UEFI App: FLASH APP
ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
Query PUBLIC ID...
PUBLIC_ID: 32F02993ADBD28074737FE692D33124CD2C76920
Query eMMC Info...
EMMC Product SN : 00BFF6E7
BATTERY CHARGE_STATUS: 38%
Flashing Done!
Total Flashing Time : 00:04:10
Old 02-28-2017, 18:44   #5965 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,502
Nokia Lumia 610 Unlock code read done..
Re-Connect USB Cable to Phone...
Connect USB Cable to Phone...OK
USB Connected! Waiting for First Event...OK
Disconnect USB Cable Now...OK
Waiting for Device Connection 10 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Retrieving Unlock Codes...OK
Service Provider Unlock Codes Found
Level 1 PIN: 66034271 ACTIVE
Level 1 PUK: 22045089 ACTIVE
Level 2 PIN: 16485383
Level 2 PUK: 19272632
Level 3 PIN: 82799145 ACTIVE
Level 3 PUK: 51229020 ACTIVE
Level 4 PIN: 34743549
Level 4 PUK: 79048117
Level 5 PIN: 70590109
Level 5 PUK: 53110552
Old 03-04-2017, 06:03   #5966 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 198
Nokia Asha A200 Flashing Done
rm761__11.95.mcusw
rm761__11.95.ppm_mec
rm761__11.95.image_mec_059J4X3
2. Insert USB.
Sending PBL...
Sending SBL...
Flash Chip Manufacturer: Intel Electronics Corp.
Unique Data: 120020122B051831
Original Product Code: 059J4X1
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353255053984244\3532550539842 44_105237.rpl
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353255053984244\3532550539842 44_CERTIFICATE_14FE5ACC.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353255053984244\3532550539842 44_PMM_PROT_B1614C27.bin
Security Code: 12345
Data Sections : 04
Current File : rm761__11.95.mcusw
Compile Name: rm761__11.95.mcusw_ebl_psi.fls
Data Size : 26480008 Bytes
Start Erasing...
Block Erase Done...
Data Checksum: C1BC
Start Erasing...
Block Erase Done...
Data Checksum: 7A7A
Start Erasing...
Block Erase Done...
Data Checksum: 9313
FIRMWARE Erase Block: 0x40280000~0x41A7FFFE
Start Erasing...
Block Erase Done...
Data Size: 25165824 bytes
Data Checksum: 769C
Start Erasing...
Block Erase Done...
Data Sections : 01
Current File : rm761__11.95.ppm_mec
Compile Name: package_mec.ppm_ebl_psi.fls
Data Size : 6916608 Bytes
PPM Erase Block: 0x41A80000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 6913264 bytes
Data Checksum: DB27
Data Sections : 01
Current File : rm761__11.95.image_mec_059J4X3
Compile Name: package_mec_059J4X3.image.fls
Data Size : 16387344 Bytes
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16384000 bytes
Data Checksum: B1CD
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:05:32
MCU Version: V 11.95 19-12-12 RM-761 (c) Nokia
IMEI Plain : 353255053984244
IMEI Spare : A353255053984240
IMEI SV : 33532550539842412F
IMEI (2nd) : 353255053984251
IMEI Spare : A353255053984250
IMEI SV : 33532550539842512F
Phone Model: Nokia 200
Category : Entry Phone
Phone Type : RM-761
Product Serial Number: 9B9916BAH
Product Code : 059J4X1
Module Code : 0204895
Basic Production Code: 059F7N6
PPM SW Version : V 11.95 19-12-12 RM-761 (c) Nokia MEC
BT MCM Version : 19e2-47026
MCU SW Version : V 11.95 19-12-12 RM-761 (c) Nokia
HW Version : 1002
RFIC Version : Dummy RFIC version
LCD Version : TPO
Content Pack Version : Content: mec_059J4X3 V 11.95 19-12-12 RM-761 (c) Nokia
Bluetooth ID : A4:E7:31:CD:01:A2
PROFILE_BITS : 800000000003000B
ASIC : 11
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SECURITY_CODE : 12345
PHONE_MODE : TEST
DCC ID : 06150123
DCC Ver: 008027
Status : OK
Selected VPL File:
RM761_059J4X3_11.95_018.vpl
Variant Details : RM-761 NDT MEA9 ARABIC AQUA
Software Version : 11.95
Product Type : RM-761
Product Code : 059J4X3
Variant Version : 018
OK
OK
OK
OK
OK
OK
OK
Old 04-09-2017, 03:52   #5967 (permalink)
-=C.J.S=-'s Avatar
Member: 669596
Sonork: 1657504
Thanks Meter: 108
Nokia 502 Security Code DONE via ATFBox..
 rm921_14.0.6.mcusw.fpsx
CMT Type : XG223
CMT Algorithm : XG223_V0 ALG
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  81
Entry Point:  0x293D
Page Format : -1
MAX PAGE : 0x00080000
 rm921_14.0.6_059S601_m2.rofs.fpsx
CMT Type : XG223
Number of Blocks :  15
Entry Point:  0x00B5
Page Format : -1
 rm921_14.0.6_059S601_m2.image.fpsx
CMT Type : XG223
Number of Blocks :  47
Entry Point:  0x00B8
Page Format : -1
2. Insert USB.
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82  (0x52) bytes returned
Number of Sub Blocks 5 (0x05)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000C20
     ID DWORD    1 : 16100040
     ID DWORD    2 : C9822409
     ID DWORD    3 : 8A94657C
     ID DWORD    4 : 6DA95DBB
  2  PUBLIC_ID 12
     ID DWORD    0 : 6F21E6F3
     ID DWORD    1 : 43A388B7
  3  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  4  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79
  5  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 53588225
     CRC         1 : 2F54C676
CMT Secondary Loader: C:\GSMFiles\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg
Secondary Loader Sent....
CMT Algorithm Loader: C:\GSMFiles\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg
Algorithm Loader Sent....
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
IMEI: 35814----------
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI 1         : 35814----------
IMEI 2         : 35814----------
PRODUCT CODE   : 059S601
WLAN ID        : FC:92:3B:30:8B:EC
BLUETOOTH ID   : FC:92:3B:2D:7E:AC
PUBLIC_ID      : 6F21E6F343A388B7C98224098A94657C6DA95DBB
PAPUB_KEYS_HASH: 7EC22006F565793C24924878FBAB9CA6CBE42C35
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
 Plain RPL saved to:
 C:\GSMFiles\AdvanceBox Turbo Flasher\Nokia\Backup\358149056933883\358149056933883_104110.rpl
PA PUBLIC KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Reading : ISA-USER... OK!
PPM HASH   : 4e5a15fde5ee49db7b9e93413d482f18a7832b04
PPM VERSION: 11.1.1
PHONE FIRMWARE VERSION:
11.1.1
Flash File Firmware Version cannot be Checked!
Use VPL files to support Firmware Version Check.
ImagePath: C:\Users\S.H.I.E.L.D\Desktop\059S601\
ImageFilename: rm921_14.0.6.mcusw.fpsx
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x26  (38)
ERASE Blocks :  0x01  (1)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x23 (35)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x00 NOR
            Device Index     : 0x00
               0             : 40000000-4003FFFF
               1             : 47E00000-47E3FFFF
               2             : 40060000-426FFFFF
               3             : 47E40000-47F1FFFF
ERASE_REQUEST_BB5  : 5004120B000000400000004003FFFF120B00000047E0000047E3FFFF120B00000040060000426FFFFF120B00000047E4000047F1FFFF61
Successfully Erased...
Total blocks to write : 81
>>  CMT Rootkey Hash CERT : ISSW
>>  CMT Rootkey Hash CERT : MEMSET
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : LOADER
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS [7EC22006F565793C24924878FBAB9CA6CBE42C35]
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : MCUSW
ImageFilename: rm921_14.0.6_059S601_m2.rofs.fpsx
StartErase_DCT5...
BlockLength  :  0x0E  (14)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 42700000-437FFFFF
ERASE_REQUEST_BB5  : 5001120B00000042700000437FFFFF6F
Total blocks to write : 15
>>  CMT Rootkey Hash CERT : PPM
ImageFilename: rm921_14.0.6_059S601_m2.image.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 43800000-47DFFFFF
ERASE_REQUEST_BB5  : 5001120B0000004380000047DFFFFFFA
Total blocks to write : 47
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
FlashInfo.RestartMode : Test Mode
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:47
SW: V 14.0.6 10-07-14 RM-921 (c) Nokia
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
SIMLOCK STATE :  Not Locked
SUPER_DONGLE_TEST  : PASSED
               SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
 OK
 OK
 OK
 OK
 OK
 OK
 OK
Old 04-14-2017, 17:31   #5968 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 313
Wink
nokia 808 rm-807 hang on logo solved by flashing done
Number of Image Files: 4
 RM-807_113.010.1508_79u_prd.core.fpsx
CMT Type : BB5
CMT Algorithm : XSR 1.6
Program Sending Speed      : 13000000Hz
Number of Blocks :  586
Entry Point:  0x025A
Page Format : -1
MAX PAGE : 0x00040000
 RM-807_113.010.1508_10.01_MEA_A_79u_prd.rofs2.fpsx
CMT Type : BB5
Number of Blocks :  229
Entry Point:  0x014B
Page Format : -1
 RM-807_113.010.1508_C00.01_79u_prd.rofs3.fpsx
CMT Type : BB5
Number of Blocks :  6
Entry Point:  0x0153
Page Format : -1
MAX PAGE : 0x00001C00
 RM-807_113.010.1508_U02.01_79u.uda.fpsx
CMT Type : BB5
Number of Blocks :  945
Entry Point:  0x014B
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96  (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 03032108
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00000C35
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00000C30
  4  PUBLIC_ID 12
     ID DWORD    0 : 0C3C0000
     ID DWORD    1 : FFFB7C40
     ID DWORD    2 : 11B6C49E
     ID DWORD    3 : 7A64E79B
     ID DWORD    4 : C0087F69
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Hash          :  3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
  7  ROM_ID 15
     CRC         0 : 2CAC45E2
     CRC         1 : 3BC33C8B
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0060 -> Type not in database
   Revision ID       : 0032
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0060
   Revision ID       : 0000
   Size              : 40000000 (1024 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
FUR control Ok
IMEI: 351965050728178
Reading : PARTNERC... OK!
IMEI           : 351965050728178
PRODUCT CODE   : 059M7N8
WLAN ID        : D0:DB:32:AC:86:CF
BLUETOOTH ID   : D0:DB:32:A7:A4:CF
PUBLIC_ID      : 0C3C0000FFFB7C4011B6C49E7A64E79BC0087F69
PAPUB_KEYS_HASH: 17AC758130EC0A40BAB0A0E31B342A01D17B8EC0
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\351965050728178\351965050728178_61723.rpl
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
113.010.1507
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-807\
ImageFilename: RM-807_113.010.1508_79u_prd.core.fpsx
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Certificate 5
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00020000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00140000
            Partition    2
              ID              : 00000004  DEMANDONOS
              Start Address   : 02F00000
            Partition    3
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 17100000
            Partition    4
              Start Address   : 3E600000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF0000000400000003000000020014000002DC0000000000040000000202F0000014200000000000080000000117100000275000000000000A000000013E60000000400000C8
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x4F  (79)
ERASE Blocks :  0x02  (2)
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00040000-0007FFFF
               1             : 000C0000-008BFFFF
               2             : 010C0000-170FFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x03000000
            Format Info      : 000000000000000A0000000000000002000000640018000000000002000000010000000000000000
ERASE_REQUEST_BB5  : 5003120B000300000400000007FFFF120B000300000C0000008BFFFF120B000300010C0000170FFFFFCD
FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000000200000064001800000000000200000001000000000000000025
Total blocks to write : 586
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : SOS+PMML
>>  CMT Rootkey Hash CERT : SOS+DECOMP
>>  CMT Rootkey Hash CERT : PAPUBKEYS [17AC758130EC0A40BAB0A0E31B342A01D17B8EC0]
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : SOS+IVE3A
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : LDSP
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-807_113.010.1508_10.01_MEA_A_79u_prd.rofs2.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 0D1C0000-135BFFFF
ERASE_REQUEST_BB5  : 5001120B0003000D1C0000135BFFFF49
Total blocks to write : 229
>>  CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM-807_113.010.1508_C00.01_79u_prd.rofs3.fpsx
StartErase_DCT5...
BlockLength  :  0x16  (22)
            Block Length     : 0x13 (19)
            Device Index     : 0x00
               0             : 01678000-0169FFFF
               1             : 135C0000-170FFFFF
ERASE_REQUEST_BB5  : 5002120B000300016780000169FFFF120B000300135C0000170FFFFFDA
Total blocks to write : 6
>>  CMT Rootkey Hash CERT : SOS+ROFS3
>>  CMT Rootkey Hash CERT : SOS+IVE3B
ImageFilename: RM-807_113.010.1508_U02.01_79u.uda.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 17100000-3E5FFFFF
ERASE_REQUEST_BB5  : 5001120B000300171000003E5FFFFF1C
Total blocks to write : 945
STATUS_REQUEST_BB5...
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000004
          Additional Bad    :  00000003
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:51
SW: V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia
SIMLOCK TABLE :
               SL3 Phone detected
 OK
 OK
 OK
 OK
 OK
 OK
 OK
Old 04-15-2017, 15:12   #5969 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 40
nokia c7-00 flash done
Old 04-15-2017, 15:14   #5970 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 40
nokia 1280 dead recover done
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
Page generated in 0.30369 seconds with 9 queries
