05-10-2017, 13:28 | #5986 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 1202 Factory Reset Done Code: MCU: V 03.10 21-01-09 RH-112 (c) NMP IMEI: 357984030974731 Product Serial Number: IMP612938 Product Code : 0562307 Module Code : 0204036 Basic Production Code: 0558505 PPM SW Version : V 03.10 21-01-09 RH-112 (c) NMP IJ ADSP Version : p V 03.10\n21-01-09\nRH-112\n(c) NMP\nij MCU SW Version : V 03.10 21-01-09 RH-112 (c) NMP HW Version : 2004 UEM Version : 1328 UPP Version : 8851 RFIC Version : 0700 DSP Version : ICPR81_08w31_UPP LCD Version : INLX:SERIv81 NT7542 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED MASTER_CODE : 6770131365 PHONE_MODE : LOCAL Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
05-12-2017, 06:54 | #5987 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | NOKIA XL EAD BOOT REPAIR DON Best Regards |
The Following 6 Users Say Thank You to niaz muhammad For This Useful Post: |
05-14-2017, 07:21 | #5989 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bd+
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Nokia 103 Rm-647 Phone lock Remove By Advance-ATF Box ================================================== ========= Best Regards iOS Shakil |
05-22-2017, 08:51 | #5990 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 101 Flashing Done Code: Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-769\rm769_008.100 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: 676D Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 2FCD Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-769\rm769_008.10ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00100000~0x005BFF7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4980608 bytes Data Checksum: D837 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-769\rm7690_nai08.10ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00E60000~0x00F1217E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 729472 bytes Data Checksum: 9BDE Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:11 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 08.10 02-04-13 RM-769 (c) Nokia IMEI: 358975052276046 Product Serial Number: 3C82175BH Product Code : 059G7N6 Module Code : 0204883 Basic Production Code: 059R3M2 PPM SW Version : V 07.70 18-10-12 RM-769 (c) Nokia IJ ADSP Version : p V 07.70\n18-10-12\nRM-769\n(c) NMP\nij MCU SW Version : V 08.10 02-04-13 RM-769 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
05-24-2017, 05:21 | #5991 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | nokia 105 flashing done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: J:\Nokia\RM-908\rm908_02.700 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: J:\Nokia\RM-908\rm908_02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: J:\Nokia\RM-908\rm908_nai02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:50 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 354257063864621 Product Serial Number: 6336E04BH Product Code : 059R496 Module Code : 0205453 Basic Production Code: 059V9B8 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
05-25-2017, 13:36 | #5993 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 1280 Flashing Done Code: Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 2 attempts... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-647\rm647_007.000 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: FC95 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2073472 bytes Data Checksum: 1426 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-647\rm647_007.00ia Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x00355BFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1334272 bytes Data Checksum: EBE4 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-647\rm6470_nai07.00ia Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F055BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 349632 bytes Data Checksum: 0841 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:36 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 07.00 11-09-12 RM-647 (c) Nokia IMEI: 356317054140908 Product Serial Number: F042C99AH Product Code : 0592303 Module Code : 0204496 Basic Production Code: 059R059 PPM SW Version : V 07.00 11-09-12 RM-647 (c) Nokia IA ADSP Version : p V 07.00\n11-09-12\nRM-647\n(c) NMP\nia MCU SW Version : V 07.00 11-09-12 RM-647 (c) Nokia HW Version : 1005 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:SERI:91 NT7542 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
05-29-2017, 02:01 | #5995 (permalink) |
Insane Poster Join Date: Mar 2017 Location: GSMFORUM
Member: 2695040 Status: Offline Thanks Meter: 101 | Nokia 101 Flashing Done Nokia 101 Flashing Done Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 2 attempts... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_008.100 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: 676D Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 2FCD Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_008.10mg Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00100000~0x005FE53E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5236032 bytes Data Checksum: 2715 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai08.10mg_nlt Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00E60000~0x00F49FFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 958464 bytes Data Checksum: 095F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:08 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 08.10 02-04-13 RM-769 (c) Nokia IMEI: 356343057986923 Product Serial Number: A5B5331BI Product Code : 059P7M3 Module Code : 0204874 Basic Production Code: 059R3M2 PPM SW Version : V 08.10 02-04-13 RM-769 (c) Nokia MG ADSP Version : p+V 08.10\n02-04-13\nRM-769\n(c) NMP\nmg_nlt MCU SW Version : V 08.10 02-04-13 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
05-29-2017, 08:03 | #5996 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 1616 Reset All Done Nokia 1616 Reset All Done Code: MCU: V 03.61 29-01-10 RH-125 (c) Nokia IMEI: 351977040797445 Product Serial Number: DWK771160 Product Code : 0588620 Module Code : 0204373 Basic Production Code: 0583104 PPM SW Version : V 03.61 29-01-10 RH-125 (c) Nokia IA ADSP Version : p V 03.61\n29-01-10\nRH-125\n(c) NMP\nia MCU SW Version : V 03.61 29-01-10 RH-125 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BOHAIv93 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
06-07-2017, 05:27 | #6000 (permalink) |
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Nokia 105 Flashing done by .::Mustafa::. VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: J:\Nokia\RM-908\rm908_02.700 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: J:\Nokia\RM-908\rm908_02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: J:\Nokia\RM-908\rm908_nai02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:53 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 353033064374857 Product Serial Number: F7EDFA3BI Product Code : 059R467 Module Code : 0205453 Basic Production Code: 059T865 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 2000 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
