01-31-2019, 10:49 | #6046 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
01-31-2019, 16:28 | #6047 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | full flash nokia 206 done link flash file Code: Number of Image Files: 3 Processing Image File : rm872__03.58.mcusw Processing Image File : rm872__03.58.ppm_m2 Processing Image File : rm872__03.58.image_m2_059R6D9 []: Found 1 active devices. [Nokia X2-02 USB Phonet]: Opening Connection [Nokia X2-02 USB Phonet]: Port opened OK! START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\\USB_FULL_BACKUP____134411.pm Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 4220080592032833 Original Product Code: 059Q426 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359197052320125\359197052320125_134423.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359197052320125\359197052320125_CERTIFICATE_9D59E416.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359197052320125\359197052320125_PMM_PROT_FE06AD7D.bin Security Code: 65050 Data Sections : 04 Current File : rm872__03.58.mcusw Compile Name: rm872__03.58.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: AFC6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 5169 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: 3E66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.ppm_m2 Compile Name: package_m2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4051052 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x420FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4047708 bytes Data Checksum: D443 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.image_m2_059R6D9 Compile Name: package_m2_059R6D9.image.fls Image Type : CONTENT Package Data Size : 15600912 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42100000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15597568 bytes Data Checksum: D1A2 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:16 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.58 05-12-12 RM-872 (c) Nokia IMEI Plain : 359197052320125 IMEI Spare : A359197052320120 IMEI SV : 33591970523201205F IMEI (2nd) : 359197052320133 IMEI Spare : A359197052320130 IMEI SV : 33591970523201305F Phone Model: Ką 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: 442CE2FBH Product Code : 059Q426 Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 03.58 05-12-12 RM-872 (c) Nokia M2 BT MCM Version : 19b5-22012 MCU SW Version : V 03.58 05-12-12 RM-872 (c) Nokia HW Version : 1601 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m2_059R6D9 V 03.58 05-12-12 RM-872 (c) Nokia Bluetooth ID : 70:8D:09:B1:58:7F CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 65050 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0FD00F22 DCC Ver: 004004 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
02-04-2019, 16:48 | #6049 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | Nokia 107 User Code Done Via Advance Turbo Box Nokia 107 User Code Done Via Advance Turbo Box Here are logs Youtube Link https://www.youtube.com/watch?v=U9XqJj9mdWc |
The Following User Says Thank You to umarnlw For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
