Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-06-2013, 13:41   #31 (permalink)
Member: 411207
Thanks Meter: 164
lumia 610 unlock done
Old 12-06-2013, 16:15   #32 (permalink)
rico1's Avatar
Member: 5397
Thanks Meter: 38
work in lumia 610
Regards
Rico GSM
Old 12-06-2013, 18:06   #33 (permalink)
Member: 1677266
Thanks Meter: 90
Originally Posted by Advance-Box View Post
@Movileuropa
Can you should me picture of your soldered up phone?
Possible, you used wrong TP... maybe you used eMMC TP and not JTAG TP.
If you are sure you used JTAG 7 wire connection, try using V2 Unlock.
http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar
Check my Post here:
http://forum.gsmhosting.com/vbb/9931899-post2.html
B.R.
thanks bro the archive did work i did the job.
the first time was ok.
Uploaded with ImageShack.us
Old 12-08-2013, 01:58   #34 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Lumia 900 counters resset and read unlocking codes
Thanks to ATF team.
Old 12-08-2013, 17:07   #35 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Old 12-09-2013, 09:56   #36 (permalink)
fazi52's Avatar
Member: 904326
Thanks Meter: 62
lumina 510 unock done great atf team
Old 12-09-2013, 18:14   #37 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 82
Unlock Lumia 900 ATT
Old 12-10-2013, 13:43   #38 (permalink)
raja16sep's Avatar
Member: 765990
Sonork: 100.1582347
Thanks Meter: 207
Hi to all,
1st Lumia 610 Unlock with the help of Sir Angel (The Great).
Phone Type : Lumia 610 RM-835 - Supported
: Lumia 610 RM-849 - Supported
: Lumia 610C RM-836 - Supported
: Lumia 510 RM-889 - Supported
: Lumia 510 RM-898 - Supported
: Lumia 505 RM-923 - Supported
Unlock Type : Read PIN and PUK Unlock Codes
Other Notes : Disconnect USB Cable before Reading Codes
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect RJ-45 JTAG Cable to ATF Box
4. Disconnect USB Cable from the Phone
5. DO NOT click RESET JTAG button
6. Click RESTORE BOOT button to Start Reading Unlock Codes
Waiting for Device Connection 10 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...
Searching for PIN/PUK Unlock Codes...
Please wait for a while...
Codes Found!
PIN LEVEL 1: 28668574 - LOCKED
PUK LEVEL 1: 64706286 - LOCKED
PIN LEVEL 2: 72876732
PUK LEVEL 2: 14155954
PIN LEVEL 3: 13904097
PUK LEVEL 3: 52554189
PIN LEVEL 4: 70961082
PUK LEVEL 4: 08532887
PIN LEVEL 5: 30016975
PUK LEVEL 5: 79271041
Reading Unlock Codes Done!
1. Remove JTAG Connection and Assemble Phone
2. Insert SIM Card from different Provider into the Phone
3. Power ON the Phone
4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it
5. After Code is accepted, wait 30 seconds until Operator Signal Appears
Write Down 8-digit PIN CODE on a piece of paper and attach
it to the phone under the battery. This will allow the owner
of the phone to unlock this phone again if he will flash the
phone firmware in the future.
All Done!OK
Saving "..\Logs\Screenshots\2013-12-10_17-28-59.jpg"...OK
Thanks to ATF and Sir Angel
Br, Raja
Old 12-11-2013, 06:30   #39 (permalink)
delax2006's Avatar
Member: 305365
Thanks Meter: 90
Lumia 610
Old 12-12-2013, 06:28   #40 (permalink)
Member: 1012390
Thanks Meter: 95
Lumia 610 RM-835 unlock okie
6. Click RESTORE BOOT button, then Connect USB Cable
Halting Core...OK
  1. Disconnect USB Cable from Phone
  2. Reconnect USB Cable to Phone
  3. Wait for 15 Seconds after First Vibration <--- Very Important
  4. Disconnect USB Cable from Phone
  5. Click RESTORE BOOT Button Again
OK
Halting Core...OK
Codes Found!
PIN LEVEL 1: 57830318 - LOCKED
PUK LEVEL 1: 12855178 - LOCKED
PIN LEVEL 2: 97988962
PUK LEVEL 2: 55273211
PIN LEVEL 3: 09133943
PUK LEVEL 3: 34680635
PIN LEVEL 4: 55206330
PUK LEVEL 4: 82531735
PIN LEVEL 5: 89833951
PUK LEVEL 5: 81293107
Old 12-12-2013, 18:46   #41 (permalink)
Member: 411207
Thanks Meter: 164
other 610 unlocked
Old 12-13-2013, 16:36   #42 (permalink)
minkoi's Avatar
Member: 55342
Sonork: 100.1619358
Thanks Meter: 281
lumija 610 unlock ok
first time no good code Attachment 318798
second okAttachment 318799
BR.
minkoi
Old 12-13-2013, 17:27   #43 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 235
Old 12-14-2013, 15:01   #44 (permalink)
SiLver GSM's Avatar
Member: 210304
Sonork: 100.1573283
Thanks Meter: 1,455
Again Unlock Lumia 610
JTAG Interface Connected,
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x106210E1 IR4
Halting Core...OK
Codes Found!
PIN LEVEL 1: 95817892 - LOCKED
PUK LEVEL 1: 37609033 - LOCKED
PIN LEVEL 2: 95892031
PUK LEVEL 2: 66958211
PIN LEVEL 3: 69968410
PUK LEVEL 3: 60179399
PIN LEVEL 4: 13785389
PUK LEVEL 4: 53400639
PIN LEVEL 5: 82705160
PUK LEVEL 5: 17148837
Old 12-15-2013, 09:08   #45 (permalink)
Member: 2074328
Sonork: 1647694:habib
lumia 510 atf jatag unlock prossing filer after power off but not on phone how to do and then after unlock i need before phone stan by on its idei its boot repier or
i try io flash vol- down hold to usb but not flash the phone atf best others
Page generated in 0.95325 seconds with 10 queries
