02-24-2016, 18:56 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Italy
Member: 302110 Status: Offline Thanks Meter: 6 | Problem with boot repair via usb Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! Any idea? |
02-25-2016, 16:57 | #3 (permalink) |
Member: 302110 Status: Offline Thanks Meter: 6 | Sorry but i read this: USB BOOT Repair Public Discussion Thread: Lumia WP8/WP8.1 BOOT Repair via USB is now Supported for Retail Lumia Phones: Lumia 920 (RM-820, RM-821, RM-867) Lumia 820 (RM-824, RM-825) Lumia 620 (RM-846) Lumia 928 (RM-860) Lumia 1020 (RM-875, RM-876, RM-877) Lumia 720 (RM-885, RM-887) Lumia 925 (RM-892, RM-893, RM-910, RM-955) Lumia 520 (RM-913, RM-914, RM-915, RM-917) Lumia 625 (RM-941, RM-942, RM-943) Lumia 1320 (RM-994, RM-995, RM-996) Lumia 525 (RM-997, RM-998) The procedure is very simple, just Flash the Phone like you Normally would without clicking any more additional options. ATF will detect your phone's current STATE and will perform the necessary Tasks to Revive it. Please make sure that YOU MUST USE ONLY the 'Nokia Emergency Connectivity" Drivers because as for now, any other 9008 drivers such as Qualcomm and Zeus (Sony) it not supported for USB BOOT Repair. You must also click "UPDATE IMPORTANT FILES" so that you will be able to download the MPRG Loaders that will be used for USB BOOT Repair. I tought it was without jtag.... |
02-25-2016, 20:29 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Yeah, normally is possible to repair phones by just USB cable. But this one phone have eMMC Write Protection enabled. Which must be repaired via eMMC Test Points. Then it will accept the flash file. How to do this - use search button. |
02-26-2016, 08:32 | #5 (permalink) |
Member: 302110 Status: Offline Thanks Meter: 6 | Boot repaired via eMMC Test point (done succesfully) but when i flash file same error: Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
02-26-2016, 10:48 | #6 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
02-26-2016, 11:06 | #7 (permalink) |
Member: 302110 Status: Offline Thanks Meter: 6 | I 've just remove write protection via eMMC Test Point and everything goes well (success for every step). But when i flash phone same error. I'm sure flash file is good. |
