09-17-2012, 09:27 | #1 (permalink) |
Registered User Join Date: Sep 2006 Location: viet nam
Member: 350201 Status: Offline Thanks Meter: 52 | Problem Dead Boot Nokia Lumia 710 ! - [SOLUTION INSIDE] |
09-22-2012, 14:43 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | change usb port also .... sometime u face this problem because of usb port even your TP are ok .... so change usb ports one by one |
09-22-2012, 15:02 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | use 0.10 mm Gauge Coated Jumper Wires... Use RJ 45 8pin wire & keep small length in size 0.10mm Copper Wire,Buy Quality 0.10mm Copper Wire from Manufacturers and Suppliers on Alibaba.com Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
09-22-2012, 15:39 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | You should correct it this way: 1. Change BLACK with BROWN 2. Change BROWN with RED 3. Change RED with ORANGE 4. Change ORANGE with YELLOW 5. Change YELLOW with GREEN B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-27-2013, 13:11 | #14 (permalink) |
Registered User Join Date: May 2005 Location: alg-mosta Age: 42
Member: 149476 Status: Offline Sonork: 100.1637076 Thanks Meter: 19 | Dead Boot Nokia Lumia 710 ok done 10000000%100 ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 094E8B62 Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing DBL... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:01:40 Last edited by patchi; 05-27-2013 at 13:13. Reason: Dead Boot Nokia Lumia 710 ! |
07-11-2013, 11:24 | #15 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: rewa (mp) india
Member: 495453 Status: Offline Thanks Meter: 22 | Lumia Test Point Connection Module after boot repare Quote:
after boot repare phon flash r not | |
The Following User Says Thank You to mahesh verma For This Useful Post: |
