09-25-2013, 05:46 | #1 (permalink) | |||
No Life Poster Join Date: Jul 2007 Location: earth
Member: 538815 Status: Offline Thanks Meter: 161 | problem emmc repair cherry mobile.. Quote:
then it will restart in atf to this Quote:
an so on....but no progress.. | |||
09-25-2013, 06:11 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @frooze_angel In atf 10.20, try to change VCCIO voltage until you see progress. You removed resistor right? |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-25-2013, 07:36 | #7 (permalink) | |
Member: 538815 Status: Offline Thanks Meter: 161 | this is the log in others pinout.. Quote:
09-25-2013, 07:46 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @frooze_angel Your phone is not acting normal. You did not use battery right? Anyway, via ATF JTAG you need to connect back the resistor you removed. Either solder wire or put back resistor. |
