03-30-2013, 17:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: A Thousand Suns Age: 41
Member: 1792564 Status: Offline Thanks Meter: 109 | problem flash i have box atf and i can flash with usb but i can not flash with fbus last ver:9.70 and restore box and update frimware but again not flash with fbus thanks |
03-31-2013, 10:53 | #3 (permalink) |
Member: 1792564 Status: Offline Thanks Meter: 109 | Booting Phone via FBUS... Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED |
03-31-2013, 12:07 | #4 (permalink) |
Member: 1792564 Status: Offline Thanks Meter: 109 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.50 Software Version : v9.70 AdvanceBox SN : D21780A8A85ADD0684F92565 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-31-2013, 16:00 | #6 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231949 Status: Offline Sonork: 12 Thanks Meter: 42 | @tirazhe_m did you try with another phone , try wih another phone FBUS and post the log here without the log, we can't do anything |
The Following User Says Thank You to hadjimi For This Useful Post: |
