09-05-2013, 16:46 | #1 (permalink) |
Junior Member Join Date: Jun 2008 Location: egypt
Member: 801592 Status: Offline Sonork: Fady4neT Thanks Meter: 0 | Problem with lumia 920 RM-821 jtag - [SOLVED] Default language ID 0x0C01 JTAG Interface Connected, S/N 0x9FC0A3AF Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 1, compiled 25/07/2013 09:18:00 ص ================================================== ======== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0009 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x706B40E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! what about of that ???!!!! |
09-05-2013, 17:51 | #4 (permalink) |
Member: 801592 Status: Offline Sonork: Fady4neT Thanks Meter: 0 | Done! Thank you @Advace-BOX new log : Loading AFP (Please Wait)...OK AFP revision 1, compiled 27/08/2013 01:44:00 م ================================================== ======== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0009 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x706B40E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Toshiba 032G94, 29.12 GiB Testing Device Memory...OK Sending Flash Loader...OK Analizing Partitions Data...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== Fady4neT ACTGSM TEAM |
09-09-2013, 06:21 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | Here is another successful JTAG Limua 920 ================================================== ======== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0009 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x706B40E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Toshiba 032G94, 29.12 GiB Testing Device Memory...OK Sending Flash Loader...OK Analizing Partitions Data...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
The Following User Says Thank You to MPhoneClinic For This Useful Post: |
