01-31-2015, 17:29 | #1 (permalink) | ||
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Problem occured after Update 11.90 and box fw - SOLUTION INSIDE Quote:
The Following User Says Thank You to omi17 For This Useful Post: |
02-01-2015, 07:57 | #3 (permalink) |
Insane Poster Join Date: Feb 2011 Location: Pakistan Punjab Okara Hujra
Member: 1522023 Status: Offline Thanks Meter: 37 | ATF Box 11.90 update problem atf box work fine at 11.88 but when i update 11.90 me box goon ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers Please Chack what i do but no suesscc RESTORE EEPROM RESTORE BOX UPDATE FIRMWARE Open Port Success... Exit code = 0... Status: Firmware Update was a Success! Elapsed time = 00:04:42 click update firmware button Programming Rlock... Programming SILSIG... Advance-Box Secure AES-128 Channel Open Port Success... Exit code = 0... Status: Firmware Update was a Success! Elapsed time = 00:03:58 but not ok box say PLEASE UPDATE BOX FIRMWARE HELPE PLEASE |
02-01-2015, 08:12 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. DISCONNECT ATF BOX from USB Port 2. Run AdvanceBox.exe version 11.90 without BOX Connected 3. Go to "Product Support" ----> "Box Tools" 4. Makes sure "ATF Nitro / Light" is selected on the right side *** NOW CONNECT ATF BOX TO USB PORT *** 5. Click "Restore Box" and wait 2 to 5 minutes... *** After Restore Box is Done, it will tell you to UPDATE FIRMWARE 6. Click "Update Firmware" and wait 2 to 5 minutes... This way, box will be FULLY RESTORE Just like Brand New from Factory. Last edited by Advance-Box; 02-01-2015 at 08:22. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
