I have repaired Boot by JTAG
Flash proce make according to your Product code, the first few times gave me error, then insisting Full flash, but it stuck in the logo.
Log Boot-EFS-IMEI
Default language ID 0x200A
JTAG Interface Connected, S/N 0xB2783E44
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 07/12/2013 10:33:00 p.m.
Phone Type : Lumia 900 RM-808, RM-823
CPU Type : Qualcomm MDM9200 (MODEM)
Storage TYpe: NAND 128MB
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Resetting and Exploring JTAG chain...2 Device(s)
Device #1 ID 0x100590E1 IR7
Device #2 ID 0x203F10E1 IR4
Restore Boot...
Waiting for Device Connection 60 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB
Testing Device Memory...OK
Sending Flash Loader...OK
Bad Blocks Request...OK
Restoring Partition #1...OK
Restoring Partition #2...OK
Restoring Partition #3...OK
Restoring Partition #4...OK
Restoring Partition #5...OK
Restoring Partition #6...OK
Restoring Partition #7...OK
Restoring Partition #8...Flash Write Error at 0x00BF0000, Bad Answer from Loader 0x0, 0x1D04
Restore Boot...
Halting Core...OK
Restoring Partition #8...OK
Restoring Partition #9...OK
Restoring Partition #10...OK
Restoring Partition #11...OK
Boot Restore Done!
Assemble Phone and Start Normally
If Phone cannot Start, perform USB Firmware Update Procedure
Completed in 0h 5m 31s. Code Download Speed 382 KiB/sec.
AFP revision 4, compiled 11/12/2013 10:38:00 a.m.
Fix Type : Repair Stuck at Logo Boot
Restore Boot...
Halting Core...OK
Boot Restore Done!
Completed in 0h 0m 19s. Code Download Speed 293 KiB/sec.
AFP revision 4, compiled 03/02/2014 02:05:00 a.m.
Fix Type : Restore Original IMEI
Halting Core...OK
Restoring IMEI 3597460428XXXX...OK
Log FLASH:
Windows Phone Flashing Started
ADSP File Found:
RM808_13w10_prod_generic_adsp.esco
AMSS File Found:
RM808_13w10_prod_generic_amss.esco
WPOS File Found:
RM808_13w10_prod_attus.esco
USER AREA ERASE File Found:
RM808_13w10_prod_generic_user_area_erase.esco
MDM AMSS File Found:
RM808_13w10_prod_generic_mdm_amss.esco
MDM DSP1 File Found:
RM808_13w10_prod_generic_mdm_dsp1.esco
MDM DSP2 File Found:
RM808_13w10_prod_generic_mdm_dsp2.esco
WARNING: OSBL File is not Loaded
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
Sending AMSS Certificate
HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980
Certificate Size: 449 Bytes
Status : WRITE AMSS CERTIFICATE SUCCESS
Sending AMSS Data Blocks
(Please Wait for 25 Seconds...)
Status : AMSS WRITE SUCCESS
Sending ADSP Certificate
Status : WRITE ADSP CERTIFICATE SUCCESS
Sending ADSP Data Blocks
Status : ADSP WRITE SUCCESS
Sending MDM AMSS Certificate
Certificate Size: 447 Bytes
Status : WRITE MDM AMSS CERTIFICATE SUCCESS
Sending MDM AMSS Data Blocks
Status : MDM AMSS WRITE SUCCESS
Sending MDM DSP1 Certificate
Status : WRITE MDM DSP1 CERTIFICATE SUCCESS
Sending MDM DSP1 Data Blocks
Status : MDM DSP1 WRITE SUCCESS
Sending MDM DSP2 Certificate
Status : WRITE MDM DSP2 CERTIFICATE SUCCESS
Sending MDM DSP2 Data Blocks
(Please Wait for 100 Seconds...)
Status : MDM DSP2 WRITE SUCCESS
Sending WPOS Certificate
Certificate Size: 1412 Bytes
Status : WRITE WPOS CERTIFICATE SUCCESS
Sending WPOS Data Blocks
[BLOCK 1 0x00000000~0x00FFFFFF]
Data Size: 0x01000000 Bytes
SHA-256 : 1837FDB8312AD70870E46763E85A01D7
---------- : 7656D71D3043C3C15F48C5BA99BFFA08
Status : WPOS WRITE SUCCESS
[BLOCK 2 0x01000000~0x016573FF]
Data Size: 0x00657400 Bytes
SHA-256 : 0FBCA994E5431EAE3AFC187E9E5C41C5
---------- : 0559F7F6018D3EAC1C34CE3B1CC4CE26
[BLOCK 3 0x01697400~0x01FFFFFF]
Data Size: 0x00968C00 Bytes
SHA-256 : 2147F706685319A0D7D6D855AFBB2A89
---------- : 5651003D0B7F0835C219914425307D57
[BLOCK 4 0x02000000~0x02FFFFFF]
SHA-256 : CF375D7A29A19655E1E4803C3427664B
---------- : 511632C1CE14C947008C0D60A63DFF94
[BLOCK 5 0x03000000~0x03FFFFFF]
SHA-256 : 3AB4F4C67D4D8CAB0757E57E25E42FD8
---------- : 1B3FBB87540BE6C38FAB76B94F5F5731
[BLOCK 6 0x04000000~0x04FFFFFF]
SHA-256 : FC053DE4CADB258B03D36FA58131FB1C
---------- : 6EF15856E1CE0699CBD3BB4F78AB51E4
[BLOCK 7 0x05000000~0x05FFFFFF]
SHA-256 : DE90861B2A1E1CEA76349A9A132C3D11
---------- : 56B4958A62CF9F93F0EA9E32202F6025
[BLOCK 8 0x06000000~0x06FFFFFF]
SHA-256 : DD1E362B16B2B3D2106FB1C98333C6C5
---------- : 87C18B8C0567BB6D5A0D20D22C708E16
[BLOCK 9 0x07000000~0x07FFFFFF]
SHA-256 : 28B4B9AB86636E63228ACDD3A2F3EA2D
---------- : DDFF0D9A30CB00955F92ADD1A4298B07
[BLOCK 10 0x08000000~0x08FFFFFF]
SHA-256 : C965454871000C39A561ECB8B0651561
---------- : 2F53CBDFA0E667FD7B05580447559BB8
[BLOCK 11 0x09000000~0x09FFFFFF]
SHA-256 : CAD505E081F2C5004AC59386F66D5154
---------- : C2AC5112895E9EB30F6A645F00E43B45
[BLOCK 12 0x0A000000~0x0AFFFFFF]
SHA-256 : B111A4B26A32DB56C6C721C8EDFA993F
---------- : C87A5629020410B75A642699AAA45568
[BLOCK 13 0x0B000000~0x0BFFFFFF]
SHA-256 : 302E400A8CB9C5B4515BBC6B59E4F94B
---------- : 67798265EBFCC87E07E7AEE39F9F46C9
[BLOCK 14 0x0C000000~0x0CFFFFFF]
SHA-256 : EAFDC6A5DF5A1105804A218BC8F9727B
---------- : 15FAAD29A152B7C4257803252EE2784E
[BLOCK 15 0x0D000000~0x0DFFFFFF]
SHA-256 : 321EFA30C38B48BC51F9B6837B8BD3AC
---------- : F041652966E34492DE389602D643626D
[BLOCK 16 0x0E000000~0x0EFFFFFF]
SHA-256 : 8834437A3922DB0B9E57F608B555CC23
---------- : B1F5EC7E310A5DE87232B42821D5AFCC
[BLOCK 17 0x0F000000~0x0FFFFFFF]
SHA-256 : 19A68327642BB3D73FD8A3D35B1ECC79
---------- : E37007E7AA42A338F4D5F2D083FA3F19
[BLOCK 18 0x10000000~0x10FFFFFF]
SHA-256 : E81047312DBBB4FD447F96E22216E289
---------- : EA296E8DC2B60B6DA0F7782920DC8B8F
[BLOCK 19 0x11000000~0x11FFFFFF]
SHA-256 : A102337D2F97E8EF5A39C3611C19B436
---------- : 3FA4CA541CF628A00B046ADCEDA91047
[BLOCK 20 0x12000000~0x12FFFFFF]
SHA-256 : 5C99CB9220059CBE8189694B4C290806
---------- : EA806CC2330777B2973B76F81738B7C5
[BLOCK 21 0x13000000~0x1325DBFF]
Data Size: 0x0025DC00 Bytes
SHA-256 : 4E02D8A45EA00FA1DE80ECBB80DC14DC
---------- : 2DA097D56CB11474534AC30CF467D8E5
Sending USER AREA ERASE Certificate
Certificate Size: 396 Bytes
Status : WRITE ERASE CERTIFICATE SUCCESS
Erasing USER AREA
Status : ERASE SUCCESS
Flashing Done!
Total Flashing Time (Erase + Flashing) : 00:05:47
Then proceeded to give the ATF TP Boot Services according to this image
I detected quite right at first, when selecting the boot and give Repair, gave me error, I forgot to copy the log but it takes capture.
Check points, verify that they are well, they made land 4-6 when connecting the USB cable, fix it, the time to give again, repair everything.
While the capture is not the end I wrote the DBL file all right.
Upon Convey the Flash gives me error, download several times to verify that was not damaged, but still gives error.
I add that it is not possible to fix the BOOT via JTAG as the points 6 and 4 were detached from much solder and where it could not be welded.
I can only via TP Services for ATF.
I appreciate the trouble taken to help me, and sorry for the extensive Post.
