09-15-2012, 19:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Libya-Tripoly
Member: 565230 Status: Offline Thanks Meter: 22 | problem unlocking lumia 800 but in second phone the ATF software says SP Unlock Done! but it's still locked Code: ====================================================== ====================================================== Lumia Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 80 Application ID : 0000 Product Name : Product Rev : 0C Product SN : 02008820 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:41 but still locked . pls help B R |
09-16-2012, 03:14 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @GsmOwar Flash it with same version as the first phone you got. Scan phone with ATF Software will show you exact version which you can match with navifirm. Normally, one would think the lower versions will have a bigger chance of getting unlocked. I think the current phone version you have is 1600.2483.8107.11501, because it only found 1 patch Bit Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! Anyway, try other versions or same version as the first phone you unlocked. You can also post here what that version is so that other people will avoid getting the same problems. B.R. |
09-16-2012, 04:17 | #5 (permalink) |
Member: 565230 Status: Offline Thanks Meter: 22 | @Advance-Box thank you for your reply i dont flash the first phone,i do unlock without flash it,and the customer has take it, my second , i do unlock >not done then i flash it with older version,as you sayed >(I think the current phone version you have is 1600.2483.8107.11501, because it only found 1 patch Bit) yes it's true then i flash it with new firmware and the software found 2 patch really i don't know what's happen but i will try with all versions tomorrow and we will see \thank you B R |
09-16-2012, 10:51 | #6 (permalink) |
Freak Poster Join Date: Oct 2004 Location: 03453007200
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | Wrong pin code I tried to unlock 1 lumia 800 with version 11451, but after successful unlocking it still locked and ask for correct pin. wanted to know whether its version mismatch or some other issue, should i flash it with some newer firmware or may be with some older version? help would really be appreciate. Tnanx |
