06-09-2017, 19:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algéria
Member: 484595 Status: Offline Thanks Meter: 39 | probleme micro sd for af bif i have teste two two micro sd same probleme SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... ERROR: Micro SD Card is NOT READY... |
06-16-2017, 18:05 | #2 (permalink) |
Member: 484595 Status: Offline Thanks Meter: 39 | i have this probelme can you help me pleas Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x04 Application ID : A Product Name : SMISD Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: September 2011 Card CID: 041641534D495344000000000000B96F Card CSD: 00000000000000000000000000000000 Card SCR: 0000000000000000 Card OCR: 00C0FF8000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity ================================================== ==== Total Elapsed Time 00:00:08 ERROR: WRITE FAILED! ERROR: Invalid Block Input ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity i have sd card for 8 go |
