09-22-2012, 17:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Lumia 800 Connection Refused Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! Total Elapsed Time 00:00:03 |
09-22-2012, 18:55 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @noor012345 It is not possible to check your pinouts by your pictures. Only you can check it. Make sure your wires are not Longer than 5 inches. Make sure you put the correct Wire Connection on the RJ-45 head. Most Problems I have see is not due to the solderings on the Phone PCB, but was caused by very long wires and wrong wire connections. Check this Post: http://forum.gsmhosting.com/vbb/f609...nside-1537519/ |
09-22-2012, 21:51 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Today i got same but "Connection Refused 0x01" 2nd thing no soldering error 3rd i used this cable successfully in previous 7 lumia 800 |
11-01-2012, 08:41 | #7 (permalink) | |
Registered User Join Date: Feb 2008 Location: Belarus
Member: 703203 Status: Offline Thanks Meter: 3 | Quote:
11-01-2012, 09:39 | #8 (permalink) |
Registered User Join Date: Aug 2000 Location: Hungary
Member: 1815 Status: Offline Thanks Meter: 3 | same error at me with TOSHIBA flash chip i also tried very short wires, but same error with Hynix flash, tp unlock work maybe supporters knows the answer for TOSHIBA flash chip problem... regards Tom |
11-01-2012, 09:45 | #9 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Quote:
Which box do you have ? ATF Lightning/Nitro or the Big one? Also, Toshiba flash chip was supported already in v9.12 or newer. Somtime we need click on Reset Box and after Test connection once again, however, mostly its TP soldering problem... BR | |
11-01-2012, 10:52 | #11 (permalink) |
Member: 1815 Status: Offline Thanks Meter: 3 | I use ATF big I clicked reset box before Test connection I made same steps when i unlock lumia800 with Hynix flash chip I got always this error: 21:43:25 : ================================================== ==== 21:43:25 : Lumia Test Point Connection Module 21:43:25 : ================================================== ==== 21:43:25 : ================================================== ==== 21:43:25 : 21:43:25 : 1. DO NOT USE THE PHONE"S BATTERY 21:43:25 : 2. Connect the Soldered TP Connections to ATF Box 21:43:25 : 3. Disconnect the USB Cable and Wait until the 21:43:25 : the ATF Software will tell you to Connect the USB. 21:43:25 : 21:43:31 : 21:43:31 : Interface Reset OK! 21:43:31 : Reading Platform Information... 21:43:31 : Selecting Active Handle... 21:43:31 : Select Handle OK! 21:43:31 : Sending Ping... 21:43:32 : Ping Reply OK! 21:43:32 : 21:43:34 : ERROR: Connection Refused 0x06 21:43:34 : Check your Test Point Soldering! when i desolder yellow wire (only red wire connected) 21:45:33 : Interface Reset OK! 21:45:33 : Reading Platform Information... 21:45:33 : Selecting Active Handle... 21:45:33 : Select Handle OK! 21:45:33 : Sending Ping... 21:45:33 : Ping Reply OK! 21:45:33 : 21:45:33 : 21:45:33 : Storage Device Information 21:45:33 : Manufacturer ID: 00 21:45:33 : Application ID : 0000 21:45:33 : Product Name : 21:45:33 : Product Rev : 00 21:45:33 : Product SN : 00000400 21:45:33 : 21:45:33 : Protection Information 21:45:33 : Write Protect A: OFF 21:45:33 : Write Protect B: OFF 21:45:33 : 21:45:34 : 21:45:34 : Dumping AMSS FAT16 Region 21:45:34 : Please wait for 2-4 Minutes... 21:45:34 : ERROR: Dump Aborted, Too much CRC Failures! 21:45:34 : 21:45:34 : Total Elapsed Time 00:00:02 Ofcourse TP soldering is ok, I use microscope and very short wires and no pcb/resistor damage. btw phone working fine no emmc chip damage when i got this error (toshiba chip) i used 9.12 version, tried all vccio voltage, same result regards Tom |
11-03-2012, 09:23 | #13 (permalink) | |
Member: 1815 Status: Offline Thanks Meter: 3 | Quote:
I tried as you said, only red wire, no success I removed the marked component, now: 09:15:05 : ERROR: Connection Refused 0x03 09:15:26 : ERROR: Connection Refused 0x06 09:17:11 : ERROR: Connection Refused 0x04 same error when i combine red and yellow wires... Before the component removed with only red wires i got this log: 21:48:06 : Storage Device Information 21:48:06 : Manufacturer ID: 00 21:48:06 : Application ID : 0000 21:48:06 : Product Name : 21:48:06 : Product Rev : 00 21:48:06 : Product SN : 00000400 21:48:06 : 21:48:06 : Protection Information 21:48:06 : Write Protect A: OFF 21:48:06 : Write Protect B: OFF 21:48:06 : 21:48:06 : 21:48:06 : Dumping AMSS FAT16 Region 21:48:06 : Please wait for 2-4 Minutes... 21:48:06 : ERROR: Dump Aborted, Too much CRC Failures! Any idea for TOSHIBA flash chip? regards Tom | |
11-03-2012, 15:41 | #14 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 41
Member: 170313 Status: Offline Thanks Meter: 46 | Quote:
11-04-2012, 06:50 | #15 (permalink) |
Member: 1815 Status: Offline Thanks Meter: 3 | Hi, Someone unlocked lumia800 with toshiba chip? I can't communicate with toshiba flash, only Hynix type unlockable.... I use ATF big Tried all combination that product supporters suggested, and no success, Need any tip or help from team please! regards Tom |
