09-15-2012, 10:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | [Q]How to unlock lumia 800 V9.10 step by step Please help to unlock nokia lumia 800 with new setup v9.10 step by step. All guidance will be highly appreciated . thanks and regards, |
09-15-2012, 10:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @NsNobel2 Its simple ... 1. Select Model from Windows Phone tab 2. Connect TP wires according to TP image 3. TEST connection from TP services tab, if connection is OK and phone detected 4. Press SP Unlock button BR |
The Following 12 Users Say Thank You to ..::Angel::.. For This Useful Post: |
09-15-2012, 10:46 | #3 (permalink) | |
Member: 1713296 Status: Offline Thanks Meter: 67 | Quote:
Thanks for your quick support. But don't know which cable use to for testpoint. I have spare Nokia 1110 cable . Can I use it for this purpose? Its jeck shows me color details following from right to left 1-White 2-Red 3-Yellow 4-Skin 5-Green 6-Black 7-Brown 8-Blue its color scheme is different than your tp pic. So I am confused . Please guide me which wires I have to solder on the board by the above color sequence. Thanks and regards, | |
09-15-2012, 12:52 | #5 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 997544 Status: Offline Thanks Meter: 71 | Lumina 800 Unlock Problem Hi Mate i have try to unlock the lumina 800 this is the massg : ================================================== ==== 00:21:43 : ================================================== ==== 00:21:43 : Lumia Test Point Connection Module 00:21:43 : ================================================== ==== 00:21:43 : ================================================== ==== 00:21:43 : 00:21:43 : 1. DO NOT USE THE PHONE"S BATTERY 00:21:43 : 2. Connect the Soldered TP Connections to ATF Box 00:21:43 : 3. Disconnect the USB Cable and Wait until the 00:21:43 : the ATF Software will tell you to Connect the USB. 00:21:43 : 00:21:57 : 00:21:57 : Interface Reset OK! 00:21:57 : Reading Platform Information... 00:21:57 : Selecting Active Handle... 00:21:57 : Select Handle OK! 00:21:57 : Sending Ping... 00:21:57 : Ping Reply OK! 00:21:57 : 00:21:57 : Lumia 800/800C Detected 00:21:57 : 00:21:57 : Storage Device Information 00:21:57 : Manufacturer ID: 90 00:21:57 : Application ID : 014A 00:21:57 : Product Name : HYNIX 00:21:57 : Product Rev : 5C 00:21:57 : Product SN : 07FF833B 00:21:57 : 00:21:57 : Protection Information 00:21:57 : Write Protect A: OFF 00:21:57 : Write Protect B: OFF 00:21:57 : 00:21:58 : 00:21:58 : Dumping AMSS FAT16 Region 00:21:58 : Please wait for 2-4 Mintues... 00:26:13 : Patch Bit Found... 00:26:13 : Total Patch Bits Found: 1 00:26:13 : Patching AMSS... 00:26:13 : Patch OK! 00:26:13 : 00:26:13 : SP Unlock Done! 00:26:13 : 00:26:14 : PIN: 00000000 00:26:14 : PUK: 0000000000 00:26:14 : 00:26:14 : Total Elapsed Time 00:04:31 i try to enter the pin its give incorrect pin. please help me to unlock my lumina 800. Thankas |
09-15-2012, 15:43 | #7 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Quote:
here is the navifrm+ link.. http://forum.gsmhosting.com/vbb/8619211-post8.html bro | |
09-19-2012, 17:02 | #8 (permalink) |
Junior Member Join Date: Jul 2008
Member: 813990 Status: Offline Thanks Meter: 5 | Lumia 800/800C Detected Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 4A5315C0 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... ERROR: Dump Aborted, Too much CRC Failures! any solution? |
The Following User Says Thank You to Secadj For This Useful Post: |
09-20-2012, 17:40 | #10 (permalink) | |
Registered User Join Date: Jul 2005
Member: 158277 Status: Offline Thanks Meter: 6 | Quote:
09-26-2012, 11:04 | #11 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
In case you missed it, the problem was resolved in ATF v9.12. Your phone have TOSHIBA chip inside, and from ATF v9.12 all are supported for unlock. BR | |
10-02-2012, 14:58 | #15 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 185255 Status: Offline Thanks Meter: 42 | lumnia 800 unlock 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Phone WAS NOT Detected! Check the GREEN WIRE Connection pls help on connection to fbus port?? |
