10-02-2012, 15:11 | #16 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Sure you have not soldered the TP properly . Check the TP picture - C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX Post result Br - srinibas | |
10-02-2012, 21:58 | #19 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 562132 Status: Offline Thanks Meter: 86 | Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 019F2CE0 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:40 |
10-02-2012, 22:29 | #20 (permalink) |
No Life Poster Join Date: May 2001 Location: Lazarevac,SRBIJA Age: 48
Member: 4772 Status: Offline Thanks Meter: 556 | ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 086A05CA Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:06:19 But sim pin isn't 00000000? What is wrong? 10x Regards |
10-03-2012, 06:05 | #21 (permalink) | |
Br - srinibas | |
11-07-2012, 19:27 | #22 (permalink) | |
Junior Member Join Date: Nov 2012
Member: 1836368 Status: Offline Thanks Meter: 0 | Quote:
Hello, I want to unlock my lumia 800 locked on T-mobile of Austria, but it's not simple, it's difficult for me to do it with these 4 step!!! Could you please give more details, what’s the tool that I need to use, what is “TP wires”? “ TEST connection from TP services tab » ? where can I find « SP Unlock button”? so please give more detail, I already downloaded and installed the “navifirmplus_1.7” but nothing to do with to unlock my phone. Best regards, Med | |
11-08-2012, 17:15 | #23 (permalink) | |
thanks a lot in advance, | |
11-10-2012, 02:16 | #26 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Direct Link for 9.15 http://174.120.45.27/atfupdate/advan...AdvanceBox.exe | |
11-10-2012, 08:33 | #27 (permalink) | |
file downloded ( ~4,6 Mo), when I launch the install, I get by the begining the error "Cannot find 'ftd2xx.dl', please re-install this applicatiojn" | |
11-12-2012, 12:23 | #30 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Advance Turbo Flasher - By Advance Team - ATF Lightning - ATF Nitro - Fastest Flasher in world - Nokia flasher - ATF Samsung - First in the world Find your nearest reseller, buy ATF Box. BR |
