06-30-2015, 09:39 | #1 (permalink) |
Crazy Poster Join Date: Feb 2014 Location: VIET NAM
Member: 2128671 Status: Offline Thanks Meter: 47 | repair boot-unbrick sky a870l by ATF 00:12:41 : eMMC Access Type: SECTOR MODE 00:12:41 : eMMC Supported Voltage Range: 00:12:41 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:12:41 : 00:12:41 : CID : 1501004D42473447411439093F4840A9 00:12:41 : CSD : D02701320F5903FFF6DBFFFF8A404007 00:12:41 : 00:12:42 : eMMC Boot Information 00:12:42 : Revision 1.5 (for MMC v4.41) 00:12:42 : BOOT PARTITION : NOT BOOT ENABLED 00:12:42 : PARTITION ACCESS : R/W USER PARTITION 00:12:42 : PERM_BOOT_CFG_PROT : DISABLED 00:12:42 : PWR_BOOT_CFG_PROT : DISABLED 00:12:42 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 00:12:42 : RESET BUS WIDTH : ENABLED 00:12:42 : eMMC FirmW UPDATE : DISABLED 00:12:42 : EMMC CACHE SIZE : 0 KB 00:12:42 : SUPER PAGE SIZE : 3584 KB 00:12:42 : HC ERASE GROUP SIZE: 512 KB 00:12:42 : USER AREA SIZE : 31268536320 BYTES 00:12:42 : BOOT PARTITION SIZE: 2048 KB 00:12:42 : RPMB PARTITION SIZE: 128 KB 00:12:42 : 00:12:42 : 00:12:42 : eMMC Device Information 00:12:42 : Manufacturer ID: SAMSUNG 00:12:42 : Device Type : Embedded BGA 00:12:42 : Application ID : 00 00:12:42 : Product Name : MBG4GA 00:12:42 : Product Rev : 1.4 00:12:42 : Product SN : 39093F48 00:12:42 : Manufactured : April 1997 00:12:42 : 00:12:42 : Card Specific Data 00:12:42 : CSD_STRUCTURE : Extended 00:12:42 : SPEC_VERS : Version 4.1/4.2/4.3 00:12:42 : TAAC : 13 ns 00:12:42 : TRAN_SPEED : 4000000 KHz 00:12:42 : READ_BL_LEN : 512 Bytes 00:12:42 : C_SIZE : HIGH CAPACITY 00:12:42 : WP_GRP_ENABLE : YES 00:12:42 : WRITE_BL_LEN : 512 Bytes 00:12:42 : CONTENT_PROT_APP : NO 00:12:42 : PERM_WRITE_PROTECT: NO 00:12:42 : TMP_WRITE_PROTECT : NO 00:12:42 : 00:12:42 : Extended CSD Saved: 00:12:42 : 1501004D42473447411439093F4840A9.ext_csd 00:12:42 : Backup Directory: 00:12:42 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 00:12:42 : 00:12:43 : 00:12:43 : Task Selected: Samsung Factory Format 00:12:43 : ================================================== ==== 00:12:43 : For eMMC Revision 1.5 (for MMC v4.41) and LOWER 00:12:43 : --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries 00:12:43 : For eMMC Revision 1.6 (for MMC v4.5) and HIGHER 00:12:43 : --> This will ONLY ERASE USER AREA 00:12:43 : ================================================== ==== 00:12:43 : This eMMC is: Revision 1.5 (for MMC v4.41) 00:12:43 : 00:12:43 : Samsung Factory Format Start... 00:12:45 : Format Done! 00:12:45 : 00:12:45 : ================================================== ==== 00:12:45 : WARNING - WARNING - WARNING - WARNING - WARNING 00:12:45 : ================================================== ==== 00:12:45 : 1. WRITE Back EXT_CSD Backup if Needed 00:12:45 : 2. WRITE BOOT1 Image if Needed 00:12:45 : 3. WRITE BOOT2 Image if Needed 00:12:45 : 4. WRITE USER AREA Image if Needed 00:12:45 : ================================================== ==== 00:13:08 : Start Writing 0x00100000 Blocks at 0x00000000 00:13:08 : Partition Selected: USER AREA 00:27:20 : 00:27:20 : Total Elapsed Time 00:14:12 00:27:20 : Write Success! |
