10-27-2014, 02:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Repair dead I9505 - (SOLVED!!! - SOLUTION via USB INSIDE) I connect in usb cable only qualcomm hs-usb qdloader 9008, I try repair with galaxy_S4_9505 recovery but no repair. |
10-27-2014, 15:24 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @turca You can repair this via USB. I can prepare beta software for you if you still have the phone with you. I normally write 4.4.2 boot via hs qdloader 9008... |
The Following 6 Users Say Thank You to Advance-Box For This Useful Post: |
10-29-2014, 13:03 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. Download This: http://174.120.45.27/tmp/GT-i9505_USB.rar 2. Extract this RAR file to your ATF Installation folder... (C:\AdvanceBox Turbo Flasher\) 3. Run AdvanceBox_GT-i9505.exe Do this: 4. This should finish after 15 minutes... Then you can make phone enter download mode and flash it via ODIN with same version flash file "I9505XXUGNG4" or higher. **** You need to install Drivers for Device Detected when you connect your GT-i9505 to your PC. You can use driver C:\AdvanceBox Turbo Flasher\Driver\EmergencyDownloadDriver.msi |
The Following 8 Users Say Thank You to Advance-Box For This Useful Post: |
10-29-2014, 13:08 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | If ever your phone firmware inside was higher than I9505XXUGNG4, then you need to wait for me to finish downloading "I9505XXUGNI2" Then I will make new "BOOT" files for USB to write for your phone. |
10-29-2014, 14:53 | #9 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | Quote:
Only HS-USB QDLOADER 9008 is detected. Please i really need boot file 4.4.2 to write the the phone because it was the version that was in the phone before it bricked. Please Help me sir you are my only hope now Thanks in advance | |
10-29-2014, 15:11 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @duncan99 Do not hi-jack other people's thread. Just make sdc file for your phones using 4.4.2 flash files. Do not be lazy, search google and download the flash files you need. We already provided sdc files for these phones... if that does notwork for you, then better make your own. By any case, I can support it via jtag easily, but this phone will work with sdc for sure. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
10-29-2014, 15:58 | #11 (permalink) | |
This phones has been with me for months no solution. Please if you can show me how to make SDC files using the flash file i will appreciate it so much i have the 4.2.2 odin files already because i was the one that upgraded the phone before the owner messed with the bootloader. i have tired so so many debrick images online but none worked it. even when i tried riff Jtag it was successful,but still no download mode.so i searched and find out that its because my phone is having 4.4.2 bootloader. all my attempt to get the debrick or dump file from people here in forum failed. Please Sir i really need your help | |
The Following User Says Thank You to duncan99 For This Useful Post: |
10-29-2014, 16:45 | #13 (permalink) |
Member: 1322701 Status: Offline Thanks Meter: 127 | here is my new thread http://forum.gsmhosting.com/vbb/f609.../#post10645871 |
10-29-2014, 23:34 | #14 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | I reinstall driver battery full, 1. Connect Battery to Phone... 2. Connect USB Cable to Phone... Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! ERROR: Qualcomm Device NOT Detected! |
