01-03-2016, 22:46 | #1 (permalink) |
Insane Poster Join Date: Aug 2015 Location: indonesia
Member: 2438055 Status: Offline Sonork: rusdi26 Thanks Meter: 20 | repair emmc samsung s5282 done ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010053355530304D02020A84A770DB CSD : D02701320F5903FFF6DBFFE18E404029 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3909091328 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : S5U00M Product Rev : 0.2 Product SN : 020A84A7 Manufactured : July 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010053355530304D02020A84A770DB.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
The Following User Says Thank You to RUSDI26 For This Useful Post: |
01-26-2016, 09:25 | #2 (permalink) | |
Product Manager Join Date: Jul 2008 Location: usa/india/canada
Member: 821431 Status: Offline Thanks Meter: 77 | Quote:
