08-12-2015, 20:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Repair IMEI Nokia X always fail with root access :mad: I just repair a Nokia X RM-980 alive back from hardbrick, but its imei & baseband null/null So i try to repair imei but ATF always fail with an error: ROOT Access Failed! Although the phone rooted Code: C:\Users\Trong>adb shell shell@aosp:/ $ su su root@aosp:/ # Code: ====================================================== Nokia X/X+/XL/XL4G/X2 Factory Programming ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options ====================================================== SW Version : 1.2.4.21 Phone Model : Nokia_X Phone Type : RM-980 SW Version : 1.2.4.21 Serial Number : 42afdca1 ================================================ Extended Phone Information ================================================ Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140707.102621 test-keys Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140707.102621:user/test-keys Android OS Version : 4.1.2 Product Platform : Nokia X software platform 1.2 Remounting System... Rebooting Device... Please Wait for Phone to Finish Booting... Entering Programming Mode... Make Sure to Install Correct Drivers from F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\ and F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\ ERROR: ROOT Access Failed! ====================================================== Nokia Android Root Kit 1.5 ====================================================== Fully Tested Phones: Nokia X - RM-980 : All Versions Nokia X - RM-981 : All Versions Nokia X+ - RM-1053 : All Versions Nokia X2 - RM-1013 : All Versions Nokia XL - RM-1030 : All Versions Nokia XL - RM-1042 : All Versions Nokia XL 4G - RM-1061 : All Versions Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Chainfire - author of SuperSU.zip ====================================================== Starting Connection... Checking ROOT Status... ROOT Status: OFF Preparing Local Directory... Starting Connection... Copying Files... Task Done! Total Rooting Time : 00:00:05 Shutting Down ADB Server... If your Phone is still not detected by ATF Software, manually End Process adb.exe in Windows Task Manager... ====================================================== Nokia X/X+/XL/XL4G/X2 Factory Programming ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options ====================================================== SW Version : 1.2.4.21 Phone Model : Nokia_X Phone Type : RM-980 SW Version : 1.2.4.21 Serial Number : 42afdca1 ================================================ Extended Phone Information ================================================ Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140707.102621 test-keys Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140707.102621:user/test-keys Android OS Version : 4.1.2 Product Platform : Nokia X software platform 1.2 Remounting System... Rebooting Device... Please Wait for Phone to Finish Booting... Entering Programming Mode... Make Sure to Install Correct Drivers from F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\ and F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\ ERROR: ROOT Access Failed! Shutting Down ADB Server... If your Phone is still not detected by ATF Software, manually End Process adb.exe in Windows Task Manager... ====================================================== Nokia X/X+/XL/XL4G/X2 Factory Programming ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options ====================================================== SW Version : 1.2.4.21 Phone Model : Nokia_X Phone Type : RM-980 SW Version : 1.2.4.21 Serial Number : 42afdca1 ================================================ Extended Phone Information ================================================ Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140707.102621 test-keys Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140707.102621:user/test-keys Android OS Version : 4.1.2 Product Platform : Nokia X software platform 1.2 Remounting System... ERROR: System Remount Failed! ====================================================== Nokia X/X+/XL/XL4G/X2 Factory Programming ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options ====================================================== SW Version : 1.2.4.21 Phone Model : Nokia_X Phone Type : RM-980 SW Version : 1.2.4.21 Serial Number : 42afdca1 ================================================ Extended Phone Information ================================================ Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140707.102621 test-keys Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140707.102621:user/test-keys Android OS Version : 4.1.2 Product Platform : Nokia X software platform 1.2 Remounting System... Rebooting Device... Please Wait for Phone to Finish Booting... Start Writing Phone Identity... Task Done! ====================================================== Nokia X/X+/XL/XL4G/X2 Factory Programming ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options ====================================================== SW Version : 1.2.4.21 Phone Model : Nokia_X Phone Type : RM-980 SW Version : 1.2.4.21 Serial Number : 42afdca1 ================================================ Extended Phone Information ================================================ Build Description : msm8625-user 4.1.2 JZO54K eng.ZYC.20140707.102621 test-keys Build Fingerprint : qcom/msm8625/msm8625:4.1.2/JZO54K/eng.ZYC.20140707.102621:user/test-keys Android OS Version : 4.1.2 Product Platform : Nokia X software platform 1.2 Remounting System... Rebooting Device... Please Wait for Phone to Finish Booting... Entering Programming Mode... Make Sure to Install Correct Drivers from F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\ and F:\5.Mobile\Box\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\ ERROR: ROOT Access Failed! |
