07-26-2013, 15:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | Repair Lumia 900 Error: Phone not detect (CMD1) I repair Lumia 900 bricked by format Qualcomm boot I use GPG Lumia TP cable |
07-26-2013, 16:02 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, use soldering to TP. It maybe user TP cable problem. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
07-28-2013, 06:26 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ Hoayeu105 Which cable you are using as TP cable ? PC LAN cable ? if yes then use Nokia FBUS cable Br - srinibas |
07-28-2013, 16:26 | #9 (permalink) | |
Member: 1012390 Status: Offline Thanks Meter: 95 | Quote:
Three day ago, i don't get this problem. I have 4 of Lumia 800 and 1 of Lumia 900 here. And now all the phone can not detect. Three day ago, i repair good 3 of Lumia 800. I use GPG Lumia TP cable. Now still those devices, but i can not detect. What is up? This is my thread that i posted all Lumia 800 that i repaired successful, i done with more than 15 devices before Nokia Lumia 800 repair boot & Jailbreak OK My friend, who has nick name @lanphuong88 also get same problem with v10.0. He and me discuss downgrade to V9.70 and he successfull with reparing Lumia 900. | |
07-30-2013, 10:40 | #12 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Hoayeu105 Here are the logs from Lumia 800 unlocking with ATF v10.00 and Box Firmware v10.3.70: Test Connection: SP Unlock: SP Unlock Done: |
08-02-2013, 11:17 | #14 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, no - it doesn't have anything to do with Important Files. But with your Test Point soldering. I also got an error: CMD2 at first, then I adjust TP wires and separte TP wire, then it worked. So something related to TP soldering/wire... BR |
08-14-2013, 10:38 | #15 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | even Ali bhai we have GPG TP cable but donot have gutz to fix on pcb to unlock,,lolz so i try to find 800 TP cable vdo how to fix on pcb,,,700 is much easier than 800 pcb. BR |
