05-04-2015, 18:14 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Repair TOTALLY DEAD i9300/N7100 Without Removing eMMC - WITH PICTURES for pinouts try to search on google i use 2.8v on vcc and vccq and select 3.3v in software dont ask me for how to make tool see the picture and think about it... scan emmc if you gett this error ----------------- ERROR: EMMC WAS NOT Detected! (CMD1) 17:43:27 : Check your Test Point Soldering! 17:43:27 : CMD1 Reply: 0x5E5E5E5E its mean your all conection are perfect now try TP --------------------------------------------------------- after detect emmc remove tp pin. Firmware upgrade +formate Write boot1,boot2, ans user area while selecting speed 15mhz https://mega.co.nz/#!0YkjQJyK!tgv0h_...C1dm1_6oLSJW5Y Write EXT_CSD file https://mega.co.nz/#!tIkWgCaK!vXpXDL...Rwq8vEZpJr79u0 Change default boot partation Last step before put back emmc to board read boot1 size 32mb Open this file in notepad you will get this here is done. before show white lcd and no product name and cant flash Last edited by Advance-Box; 05-10-2015 at 15:08. |
The Following 27 Users Say Thank You to chand_gee For This Useful Post: |
05-05-2015, 11:26 | #3 (permalink) |
Junior Member Join Date: Feb 2013 Location: hyderabad
Member: 1882373 Status: Offline Sonork: ikkks Thanks Meter: 2 | i have 1 question where to put pin for tp and in last step u are saying Last step before put back emmc to board read boot1 size 32mb but ur thread title is without removing emmc not understand this. adn its better if u post clear pin outs pictures which avaialable on google is not clear. |
05-05-2015, 11:49 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Test point where? Hahaha. Good tutorial, but incomplete. |
The Following User Says Thank You to toninhosantos For This Useful Post: |
05-05-2015, 11:58 | #6 (permalink) |
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Whitout remove emmc, but why put back emmc in board? ??????? |
05-05-2015, 12:47 | #8 (permalink) |
Member: 1882373 Status: Offline Sonork: ikkks Thanks Meter: 2 | I M GETTING THIS ERROR IT SAYS ITS NOT SAMSUNG EMMC BUT IT WRITTEN ON EMMC IS KMVTU000LM-B503 ALSO ITS ASK ME TO HOLD SHIFT KEY FOR FORCE WRITE EMMC FIRMWARE. 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 Task Selected: Samsung eMMC Firmware Update ================================================== ==== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ================================================== ==== Please Manually Select the Correct Part Number of your eMMC Device. ================================================== ==== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ================================================== ==== ================================================== ==== Loading ATF eMMC Firmware File... (Please Wait) ================================================== ==== File Author: ATF Team @ X-Shadow Date Created: 21/02/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMVTU000LM-B503 eMMC Product Name: VTU00M eMMC Product Rev: 15.7 Preparing eMMC for Firmware Update... ERROR: CUSTOM_VENDOR_COMMAND FAILED 0x03 Total Elapsed Time 00:00:00 |
05-05-2015, 14:36 | #11 (permalink) | |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
about pinouts search on google and click image u will see alot yes you can read boot1 to make sure emmc working or not... | |
The Following User Says Thank You to chand_gee For This Useful Post: |
05-05-2015, 14:42 | #12 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i think you did not see EMMC before here is link for TP http://forum.gsmhosting.com/vbb/f609...e-pin-1936304/ |
05-05-2015, 14:46 | #13 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | @shine007 ------ ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 ---------------------- your EMMC is not conected check your wire soldering ----------------------------------------------------- read this--------- scan emmc if you gett this error ERROR: EMMC WAS NOT Detected! (CMD1) 17:43:27 : Check your Test Point Soldering! 17:43:27 : CMD1 Reply: 0x5E5E5E5E its mean your all conection are perfect now try TP --------------------------------------------------------- |
05-05-2015, 14:49 | #14 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | Quote:
05-05-2015, 15:13 | #15 (permalink) | |
Member: 1882373 Status: Offline Sonork: ikkks Thanks Meter: 2 | Quote:
bro u said without remove emmc than how could we give tp while emmc is on board ?? in ur pic nidle is there and emmc is soldered on board where did u connect nidle for tp and what about now ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E ================================================== ==== This eMMC is NOT a SAMSUNG eMMC!!! If you want to FORCE Firmware Update on this eMMC, Press and Hold the "SHIFT" Key on your PC KeyBoard then click the "EXECUTE" Button Again... ================================================== ==== | |
The Following User Says Thank You to shine007 For This Useful Post: |
