01-08-2016, 06:42 | #91 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | I repaired emmc by tp method <i use saving blade for tp> and i write boot 1 bbot 2 user data and all process done which should be done.now my is alive and show download mode. I flashed it but when i power on my set after flashing it restart on only logo. I flashed it different file but same condition restart on logo. Any one can help me?? MY SET IS S3 AND IT WAS TOTALY DEAD |
01-10-2016, 15:07 | #92 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
01-29-2016, 11:59 | #94 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Please Tell Me How To Connect This Mobile Because i have I9300 In Fully Dead Condition My Old Post http://forum.gsmhosting.com/vbb/11585860-post15.html |
01-29-2016, 14:32 | #95 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Yashbanswara, Sorry but you are hard for understand. Read Carefully First post of this Thread, find also all Files and full procedure for Shorting NAND point in emmc to GND first of "Factory Reset+Update Fw". Loock Big Photo in Post #37 and many others, moving one little. Here procedure for shorting and reset BRAND NEW you EMMC also totally Dead: step-step-repair-totally-dead-emmc-via-nand_re-pin PURCHASE ATF 4 in 1 ADAPTER V2/3 from SmartGsm if want work in peace!!!! BR allumts |
01-29-2016, 16:08 | #97 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
It's all BR allumts | |
01-30-2016, 21:47 | #99 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Yashbanswara, sorry but at this point i think really that's this isn't work for you. Have helped in all mode and too i see what have said....please change field and send to one good shop for these type of repair, listen me BR allumts |
05-10-2016, 19:17 | #103 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | Hi i need some help please, I am trying to repair a dead emmc from a S3, but keep having issues to write user area, boot1 and boot2 can be written fine. please check the log... ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726589D CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726589D.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing 0x001EC209 Blocks at 0x00000000 Partition Selected: USER AREA Write Block Error Total Elapsed Time 00:22:17 ERROR: WRITE FAILED! |
05-12-2016, 12:00 | #104 (permalink) | |
BR allumts | |
