05-23-2015, 12:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | Repaire boot Lumia 930 RM-1045? On W7 64bit it is seen as QHusb and i have installed Nokia Conectivity driver, qualcomm 9006 and others but no detection by ATF driver. Only on windows 7 32 bit i can install from folder NOKIA_X2_USB_DRIVERS\MANUAL_INSTALL nokia emergency driver and the same is not detected. I've seen there is a possibility to repair it via emmc direct but no pictures for the connections. Anybody can share this information for emmc direct? Or how to repair it via usb? |
05-24-2015, 06:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | You need to learn how to install Nokia Emergency Drivers. If you cannot install them, then it is not possible to repair via USB by any software. About how to install it, use google and check how to install drivers and forced windows to use drivers you want. |
05-24-2015, 07:55 | #3 (permalink) | |
Member: 1722871 Status: Offline Thanks Meter: 116 | Quote:
I just said I've tried w7 64 and 32 bit and only on 32 bit it say emergency drivers. It doesn't show any error on device manager but atf doesn't connect to the phone. Can you point witch folder contains the correct drivers for emergency so that we are clear that i've installed the corect drivers and I will post a video with ATF not working? I know how to disable signed drivers but it doesn't help. Second if I can't connect via USB and you say you have emmc direct connect for this phone, you can't share the pin out for this? | |
05-24-2015, 12:20 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | You need to read what I write in post number 2 and clear your mind of sarcasm. I was trying to tell you that the problem is when your windows already installed Qualcomm drivers for your phone. Since you were not clear on this matter, I suggested you check in google how to FORCE windows to select Nokia Emergecy Drivers inside "Nokia X2" driver folder. It is not easy even for expert windows users to FORCE new drivers to a device which already have drivers installed... because windows will keep on "suggesting" that you already have the proper drivers installed even if you DONT want the current drivers which is already installed. On other times, windows will even give you "file not found" errors when you force it to install Nokia Connectivity Drivers... This of course is a problem with Windows and not a problem with ATF software. If you want to make it clear to me what your problem is, do: Screenshot Device Manager showing usb device detected as you phone + Screenshot USB Device properties showing VID/PID of phone detected as 9006 If PID is 9006, then this is not the mode which will accept Nokia Emergency Drivers. |
05-25-2015, 11:03 | #6 (permalink) | |
I attached the picture with the drivers and atf not conecting to the phone i have the VID/PID also and it dosen't show anywere 9006 | |
05-26-2015, 03:11 | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
This is not correct VID PID of dead phone. Do you see "Qualcomm" device in your "COM and LPT" Port section? If so then I can send you new exe which support Qualcomm drivers. B.R. | |
05-27-2015, 20:28 | #10 (permalink) | |
I've tried on a new pc and this had also the same VID\PID. | |
07-20-2018, 09:34 | #11 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hey supports.. thread is maybe old but pb is new. what can be pb..? Code: Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ====================================================== Windows Phone 8/8.1/10 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: G:\GsM\ALL_BOX\ATF\AdvanceBox Turbo Flasher_12.06\Driver\NOKIA_X2_USB_DRIVERS\ ====================================================== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... Validation is enabled. EMMC: size_in_sectors:61071360, mfr_id:21, oem_id:0, prod_rev:2, mfr_date:5/2014 ERROR: error code= 10 value= Reported UEFI error code: 5678ffff ERROR: Flashing Failed! |
