07-18-2015, 15:07 | #137 (permalink) | ||
Major Poster Join Date: Aug 2005 Age: 45
Member: 174181 Status: Offline Thanks Meter: 21 | Quote:
but my EMMC is dead, log after TP : Quote:
in ATF, I don`t find this firmware, so I need KMVYL000LM-B503.emmc_fw THANKS | ||
07-18-2015, 17:51 | #138 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Where is DEAD?....why not have write "Update Firmware + Format"? Connection is Ok, so try first, (save Full Dump first for to be sure), "Update Firmware + Format" ..if not write is becouse of 80/90% of these EMMC working only with NAND#RE TP, use this Procedure for you EMMC and his fw and has solved: http://forum.gsmhosting.com/vbb/f609...m-n-o-1936304/ BR allumts |
07-18-2015, 22:20 | #139 (permalink) | |
07-19-2015, 11:28 | #140 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, now you post that have this type of EMMC....and if you have just write and used these BOOT1/2 and USER AREA HERE: http://forum.gsmhosting.com/vbb/f609...85/index2.html Sorry but for this EMMC need to wait when X-Shadow or other user Upload Full Dump of working phone for this type of EMMC... For sure i'm lucky but i've repaired 4 pieces of these I9100 w/o TP and only with above files...and Right Connection... BR |
07-25-2015, 02:20 | #143 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | If i solder wrong data in wrong risestor it can killed emmc or not After i read boot1/2and userarea tab not power on and when i chek emmc is ok |
08-03-2015, 23:56 | #144 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
answer is no no no replace resister clk data ad data one by one there is must b someone is damage hope you understand | |
